Old 07-15-2010, 07:33 PM   #4906
OVA
OVA's Avatar
Trader Rating: 74 (100%+)
Originally Posted by Marcos.J View Post
Im using the set up that EJ used i think before the reedy race, with some minor changes.
Do you mind telling me where did you get it and what minor changes is made?
OVA is offline   Reply With Quote
Old 07-15-2010, 08:15 PM   #4907
Super Moderator
Marcos.J's Avatar
Trader Rating: 150 (100%+)
I got the set up a few pages back
i ran a 1.2mm sway bar in the front 1mm in the rear and 344 springs in the front and 306 in the rear
Old 07-15-2010, 09:20 PM   #4908
Originally Posted by E.J. Evans View Post
If you have calipers can you measure the width of the suspension blocks. If all else fails please send it to us and I'll take a look at it. Obviously if there is something wrong we'll warranty it and pay for the shipping.
Thanks for your help. I did call T.O.P and they said the same thing i just wanted to see if any one on the form had the same issue how did they fix it. Thanks again
dex410usa is offline   Reply With Quote
Old 07-15-2010, 10:33 PM   #4909
pcar951's Avatar
Trader Rating: 19 (100%+)
Just received my "standard" lipo chassis, I thought the kit one was too stiff......Wow, the standard is a noodle! Anybody using it??
pcar951 is offline   Reply With Quote
Old 07-17-2010, 12:36 AM   #4910
has anyone had isues with the shocks weeping/leaking , ive renewed the seals and they still leak from the bottom seals ...
i love the car apart from that , just sold one shuey mi4lp to get this photon and am consenplating selling my other shuey to get another for out doors ...
shaun207 is offline   Reply With Quote
Old 07-17-2010, 06:22 AM   #4911
hacker's Avatar
Trader Rating: 140 (100%+)
Default foam to rubber spec
what parts do I need to convert a foam into rubber spec?
hacker is offline   Reply With Quote
Old 07-17-2010, 07:36 AM   #4912
Skitee's Avatar
Did you soak the o-rings in oil before you put them in the shocks, by soak I mean leave them in shock oil for around 20 minutes.
Xray T4 2017 ~ ORCA Vritra VX3 ~ Motiv RC 4.5
Xray T4 2017 ~ ORCA Vritra VX3 ~ R1 Wurks 13.5
Xray X12 2016 ~ ORCA Vritra VX3 ~ Orca TX 4.5
POWERED BY SPEEDZONE USA
Skitee is offline   Reply With Quote
Old 07-17-2010, 09:06 AM   #4913
pcar951's Avatar
Got my gear diffs, they look decent but I wouldn't wanna run mod with them. Glad I got some spares. Interesing, they came in un-marked bags...hmmm?
Jim Chapman
PM Hobbycraft | RCAmerica | Xray | Hudy | Reds Racing
Old 07-17-2010, 09:06 AM   #4914
ive never heard that before , is that soak them in normal shock oil ...
Old 07-17-2010, 09:08 AM   #4915
Trader Rating: 21 (100%+)
Yes
Rick "Blue" Sieboldt - Mooresville, NC
* Associated T5M * Tekin * TQ Wire *
www.tqracing.com/rc_products.htm For all your wire needs
lidebt2 is offline   Reply With Quote
Old 07-17-2010, 09:11 AM   #4916
Skitee's Avatar
Correct, I don't think the weight you use makes any difference.
Old 07-17-2010, 10:03 AM   #4917
smoke81's Avatar
Send a message via AIM to smoke81 Send a message via Yahoo to smoke81
If your going to be racing on carpet I would just suggest getting Rubber Wings and a Spool.
Asphalt I would suggest getting the "Stiff" chassis and a rubber top deck. (rubber wings and spool as well).
Dustin Layne
smoke81 is offline   Reply With Quote
Old 07-17-2010, 10:04 AM   #4918
darrenoakley's Avatar
Hi mate.
I had the same problem when I changed them for muchmore"pro orings" associated green slime on the shafts and orings has cured this problem perfect. Much more also do a shock slime that Terry has in stock. Great stuff.
Xray x11
Xray T3 011
darrenoakley is offline   Reply With Quote
Old 07-17-2010, 12:20 PM   #4919
Anybody try the gear diff yet.
dannybcaitlyn is offline   Reply With Quote
Old 07-18-2010, 02:01 AM   #4920
Bishop's Avatar
Given they only came out last week or so, could be another week or so before the feedback rolls in.
On the same subject, 'if' the Yoko diff fits, we could be golden for choice soon, the SpecR and Yoko brand diffs are supposed to be out real soon, giving up three option in total if they work...
QRCCRA
www.qrccra.org.au
www.facebook.com/englandparkraceway
www.myrcm.ch/main?pLa=en&hId[1]=org&dId[O]=4331
Bishop is offline   Reply With Quote
