Old 07-08-2010, 04:20 PM   #4831
bkspeedo's Avatar
Originally Posted by stiltskin View Post
I like the 6 cell chassis better than the lipo chassis on asphalt.
Are you talking about the soft Lipo chassis or the stiff?
Brent Klingforth
Sponsors: Awesomatix USA ~ Roche USA ~ ORCA ~ AVID Bearings ~ R1 Wurks
TQ Wire ~ ProtoForm ~ BSR Racing Tires ~ 2mm Design
5280raceway.com [Operated by - Colorado On-Road RC Club]
MILE HIGH INDOOR CHAMPS April 20-23rd 2017 @ www.milehighindoorchamps.com
bkspeedo is offline   Reply With Quote
Old 07-08-2010, 04:23 PM   #4832
hanulec's Avatar
Trader Rating: 23 (100%+)
Maybe u should double check your setup. Fairtrace was killing it last weekend outdoors with the lipo chassis.. but he could probably use a tc4 and be fast too
FJ / ROAR #2-122945 / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 07-08-2010, 04:36 PM   #4833
L.Fairtrace's Avatar
Send a message via AIM to L.Fairtrace
I thought that was the case as well, so last weekend I went to the track with the exact same setup on both cars, except one had the stiff lipo and one had the stock rubber 6 cell chassis on it. My 6 cell car was ok, but my Lipo chassis car was unbelievable. Like real real good. Now I know tracks can vary and such but at a med/med high bite asphalt track like Jackson the stiffer chassis always feels better and faster to me.
It all depends on the level of traction you have on your track. I think the least stiff of the new lipo chassis's and med or carpet topdeck would probably be good on a lower bite track. I like the feel of the car without the battery tray on it.
Keep in mind I didn't run the new battery holder, I just used the old weight braces front and rear stoppers and taped the battery in and balanced it with weights.
T.O.P Racing - Awesomatix USA - EaMotorsports - BSR Racing Tires - Orca - TQ Wire - Solaris Racing Tires - Side Piece Racing
Horsham RC. Where champions practice Failing. I'm your everything.....
L.Fairtrace is offline   Reply With Quote
Old 07-08-2010, 05:56 PM   #4834
OVA
OVA's Avatar
Trader Rating: 72 (100%+)
+1 true
OVA is offline   Reply With Quote
Old 07-08-2010, 06:13 PM   #4835
pcar951's Avatar
Trader Rating: 19 (100%+)
When I built my ltd. ed. car, the lipo chassis in the kit seemed so stiff compared to the TC5R and even the T3, I went straight to the 6 cell. A little flex in the chassis always seems to make the car feel more "locked in" to me. Am I wrong here?
pcar951 is offline   Reply With Quote
Old 07-08-2010, 07:53 PM   #4836
DaveW's Avatar
I like the feel of the car without the battery tray on it. Keep in mind I didn't run the new battery holder, I just used the old weight braces front and rear stoppers and taped the battery in and balanced it with weights.
^^ sounds like a familiar conversation we had a few weeks ago, eh Tony? ^^
...you better run like im booger flickin...
DaveW is offline   Reply With Quote
Old 07-08-2010, 08:54 PM   #4837
MikeXray's Avatar
As larry said, it depends on your track. Sometimes too locked in is just slow. I picked up .3ths in one round with larry's changes, one of which was a thicker top deck
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 07-08-2010, 10:09 PM   #4838
OVA
OVA's Avatar
I like to try Larry set up with Lipo chassis! it is online ?
Old 07-08-2010, 10:44 PM   #4839
Bishop's Avatar
I'm still hoping the LiPo chassis works for me, it just looks so slick, oh and I dropped the $40+ on the mounts so I'm committed to make it work anyway.
Oh and back in the world of gear diffs, I did noticed this today...
http://www.spec-r.com/specrr2/module....php?storyid=8
Being 40T will the Yokomo diff work in a Photon?, or will the width end up being wrong?, I just mention is cause no one is sure yet how good the mini diff will end up being.
QRCCRA
www.qrccra.org.au
www.facebook.com/englandparkraceway
www.myrcm.ch/main?pLa=en&hId[1]=org&dId[O]=4331
Bishop is offline   Reply With Quote
Old 07-08-2010, 11:13 PM   #4840
Rod M's Avatar
Originally Posted by Skitee View Post
Will you have spare parts for rebuilding ?
Originally Posted by RC MARKET View Post
rebuild kit have case , gear & o-ring,
later release !
according to the Manufacturer of the -Pro Diff,
it is preassembled and not rebuildable. and only for Stock classes as the Torque is what wears them out (not the speed),
the high Pitch of the gears is what allowed them to make it so small but also why it does not last in high torque classes.
and it is also not advisable to change the oil from what it comes with it,
basically when it wears out you throw it out an buy a new one,
I should have them in AUS by next week,
TOPRACING.NET.AU Australian Importer of:
T.O.P. Tokyo Hobbies Optional Parts,
Team Trinity , BL Motors and Tyre compound
Team Tekin , ESC's, motors,
Elangears, Chargers,
Rod M is offline   Reply With Quote
Old 07-08-2010, 11:49 PM   #4841
Skitee's Avatar
Good info Rod thanks, so this diff would be best suited from 10.5 to 21.5 then ?
Xray T4 2017 ~ ORCA Vritra VX3 ~ Motiv RC 4.5
Xray T4 2017 ~ ORCA Vritra VX3 ~ R1 Wurks 13.5
Xray X12 2016 ~ ORCA Vritra VX3 ~ Orca TX 4.5
POWERED BY SPEEDZONE USA
Skitee is offline   Reply With Quote
Old 07-09-2010, 12:12 AM   #4842
Rod M's Avatar
in modified they mentioned that it had a MTTF of about 20 runs,
I would still be a little wary with 10.5 and the "turbo" ESC's we are all running now,
I am interested to see feedback as to how long they last with different classes of motors.
Old 07-09-2010, 12:15 AM   #4843
Skitee's Avatar
I've been holding off on getting the LiPo deck, our track has good bite but it is really bumpy in places. Would you suggest the medium lipo deck with a foam top deck or a stiff lipo deck with a rubber top deck ?
Old 07-09-2010, 12:27 AM   #4844
Skitee's Avatar
I assume that's running rubber so that number could be much lower running foam since there's considerably more load on the drive train, in which case would this diff then hold up well to stock classes running foam ?
Old 07-09-2010, 12:30 AM   #4845
vabroom's Avatar
I'm glad I slow and haven't order the gear diff. Even though I race 17.5, it's the not rebuildable and throw it out that I don't like.
I wonder if the spec-r for Yokomo (coming) or either of the two others will work with little mod.
RC racing is still trying to prove that two solid objects can be in the same place, at the same time.
vabroom is offline   Reply With Quote
SEO by vBSEO 3.5.0
