Old 06-15-2010, 05:54 AM   #4651
RC MARKET's Avatar
OK
RC MARKET is offline   Reply With Quote
Old 06-15-2010, 06:37 AM   #4652
Goingfast's Avatar
Trader Rating: 29 (100%+)
Originally Posted by RC MARKET View Post
OK
I take one ...please...Thanks
Everybody is ignorant, only on different subjects.
AE 12R5.1,Tekin RS PRO
17.5 super stock T.O.P PHOTON , TAMIYA M05 Mini
CEFX.. High Velocity Racing Motor
Goingfast is offline   Reply With Quote
Old 06-15-2010, 07:54 AM   #4653
el salvador's Avatar
Questions?? What % Nitro?
Originally Posted by OVA View Post
Where can I find the latest reedy or Nor-Cal set up for 17.5? thanks
So, Wa-happen?
Login Malfunction?
ARC R8 X2/ Max RP9 or O.S. R2101 ,Capricorn LAB C02-TOP Elite R, ARC R11....
"Every Cemetery in Chicago Votes Democrat!"
el salvador is offline   Reply With Quote
Old 06-15-2010, 08:05 AM   #4654
Goingfast's Avatar
Originally Posted by el salvador View Post
So, Wa-happen?
Login Malfunction?
Old 06-15-2010, 10:22 AM   #4655
hana166's Avatar
Originally Posted by odpurple View Post
No, the id is too small. T.O.P. has a 2x6mm pre-assembled ceramic thrust which fit the Scythe and other cars, but not the Photon
If you want a ceramic thrust use the 1.6mm ceramic balls (PO-CDB408BK) with the stock thrust washers.
Hi I did find a good solution with this...I did order two of these from rc mushroom for only 5 usd before reading this but found that I could use the ceramic race with the original pressure plates..making a really excellent thrust bearing without the inconvenience of loose balls
hana166 is offline   Reply With Quote
Old 06-15-2010, 05:49 PM   #4656
haywood's Avatar
Trader Rating: 48 (100%+)
Default Photon
Looking for some help with my Photon's steering problem. With the outside right front camber link fully tightened my steering binds. If I keep it loose my steering is free. I changed the steering knuckle and it still binds. I then tried to take a little material from the Tie rod end with a body reamer and still binds? What else could it be? Thanks
haywood is offline   Reply With Quote
Old 06-16-2010, 09:01 AM   #4657
Trader Rating: 21 (100%+)
Default Looking for new car
I have been looking for a new car. I owned 2 Type R's and sold them after 360 Speedway closed.
I'm moving to NC in 10 days and was planning to run only oval but there are a few TC tracking in the area.
Now my questions:
1. I will be running mostly on asphalt outdoors and some carpet in the winter, which car should I get rubber or foam?
2. How many changes would I have to make to convert one to the other?
Thanks,
Rick "Blue" Sieboldt - Mooresville, NC
* Associated T5M * Tekin * TQ Wire *
www.tqracing.com/rc_products.htm For all your wire needs
lidebt2 is offline   Reply With Quote
Old 06-16-2010, 10:36 AM   #4658
Goingfast's Avatar
Now my questions:
Thanks,
I would get the rubber version...reason why ,you can set the car on rubber carpet racing ,without buying any more or need parts...
Old 06-16-2010, 11:33 AM   #4659
Thanks, that is what I was thinking but................
Old 06-16-2010, 12:44 PM   #4660
stiltskin's Avatar
Trader Rating: 102 (100%+)
Now my questions:
Thanks,
If you're looking for an older version, the rubber car will work very well on asphalt, but the foam version is much better for rubber tires on carpet. I ran the 2.5 lipo chassis on carpet last year with great success. The new kits come with the 2.25mm stiff lipo chassis and the 2.5mm 6 cell chassis. The rubber car had too much flex on carpet IMO.
Tony Rumple
Team EAM // Gravity RC
stiltskin is offline   Reply With Quote
Old 06-16-2010, 12:51 PM   #4661
Goingfast's Avatar
I don't disagreed your saying ,But I think he said (I will be running mostly on asphalt outdoors)
Old 06-16-2010, 12:58 PM   #4662
stiltskin's Avatar
Agree with you also. Just not sure if he's looking for an older version used car or looking at the new car. The new version does not come as a rubber or foam version. There is only one version. Agreed that the rubber version is better for asphalt though.
Tony Rumple
Old 06-16-2010, 01:07 PM   #4663
DaveW's Avatar
You mentioned a LiPo and 6 cell chassis separately... does that mean the LiPo chassis doesnt have the 6 cell cutouts?
...you better run like im booger flickin...
DaveW is offline   Reply With Quote
Old 06-16-2010, 01:37 PM   #4664
MikeXray's Avatar
Trader Rating: 73 (100%+)
Yes there are no cutouts in a lipo chassis, some have square for bumps, but not for cells.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 06-16-2010, 03:10 PM   #4665
This is why I'm asked:
http://www.amainhobbies.com/product_...-Car-Foam-Spec
And:
http://www.amainhobbies.com/product_...ouring-Car-Kit
Which is the newer one??
