Old 06-13-2010, 08:15 AM   #4636
RC MARKET's Avatar
20T center pulley , F Spool & Bell Crank
RC MARKET is offline   Reply With Quote
Old 06-13-2010, 01:35 PM   #4637
hana166's Avatar
Hi
Just got a Photon..need a carpet rubber base set up on Sorex 28
It'd be great if someone could point me in the right direction
hana166 is offline   Reply With Quote
Old 06-13-2010, 03:16 PM   #4638
pmc
Hello
I have two differentials, the two are mounted in the same way I will describe:
Both with ceramic balls 3mm 12 pieces, plates polished with sandpaper with WD40 oil in 1200 and finished with 2000
with seven ceramic balls of 1.6 mm mounted.
with 4 cone washers and are mounted this way )()(
the diff pulley mounted to the deepest part to the side of the screw.
With Associated stealth diff lube.
my problem is when I run the first qualification they work well, then starts making a strange noise when apply full throttle, it seems they are loosened, when tightening the noise is worse.
Maybe some part are mounted bad.
perhaps with new ligth plates can solve the problem.
Help please.
Thanks in advance.
Best regards:
Pedro Silva
pmc is offline   Reply With Quote
Old 06-13-2010, 03:52 PM   #4639
Ron Goetter's Avatar
Trader Rating: 17 (95%+)
Send a message via AIM to Ron Goetter
Originally Posted by pmc View Post
Hello
Help please.
Thanks in advance.
Best regards:
Pedro Silva
Your missing 1 thrust ball. Should be 8 Thrust balls.
The Goat... B-Mainer Fo' life
-Awesomatix USA-ROCHE USA-Team CRC-ORCA-SIDE PIECE RACING-TEAM DAK-EA Motorsports-VP Fuel-Trains and Lanes-CR Graphics-TQ Wire-Horsham RC-rugburn anyone?
Shut up and Race!!!!
Ron Goetter is offline   Reply With Quote
Old 06-13-2010, 04:17 PM   #4640
Trader Rating: 62 (100%+)
Originally Posted by hana166 View Post
Hi
Look here http://www.petitrc.com/index.php?page=setup_sheet
The Wease is offline   Reply With Quote
Old 06-13-2010, 05:05 PM   #4641
VoneSkip's Avatar
Trader Rating: 27 (100%+)
Send a message via MSN to VoneSkip
Originally Posted by hacker View Post
do you/they have the latest kits including the new lipo chassis?
Contact Rod here and he will be only to happy to Help you with any Questions , I believe he was getting the latest kits into Stock ..
Team Destiny-A New Chassis - Top Quality and Value -PM me for further details
Hobbywing- For High performance ,Quality products.
PROAMPS - High performance Batteries and Servos - "When only the best will do"
TWT - For the ultimate Setup and Tweak boards.
S2H Bodies For all your custom Painting needs
VoneSkip is offline   Reply With Quote
Old 06-14-2010, 12:00 AM   #4642
*SBH*'s Avatar
Originally Posted by pcar951 View Post
just ordered a "limited edition" Photon. can anyone tell me if this kit will have all the latest parts or did they just throw in some spares?
Hi there.
Thats the kit I'm driving now and it's great.
Things changed from the "normal" kit: (What I remember)
New chassis and topplate - Especially for LiPo
New shocks - More smooth and doesnt leak oil - Very nice.
New drive shafts in better material and with lasertext on to identify length
New screws for topplate and camberplates - Harder. You need a 2mm wrench
New improved centershaft for the pulleys
New rear arms with more holes for dampers
Possibility to turn the diff and spool so You can move the electronics right
Maybe even more, but thats what I remember without having the car in front of me. :0)
The car is great and so easy to drive
*SBH* is offline   Reply With Quote
Old 06-14-2010, 08:22 AM   #4643
Goingfast's Avatar
Trader Rating: 29 (100%+)
Is there a winning last Reedy Races 17.5 or 13.5 set up ?
Everybody is ignorant, only on different subjects.
AE 12R5.1,Tekin RS PRO
17.5 super stock T.O.P PHOTON , TAMIYA M05 Mini
CEFX.. High Velocity Racing Motor
Goingfast is offline   Reply With Quote
Old 06-14-2010, 08:43 AM   #4644
pcar951's Avatar
Trader Rating: 19 (100%+)
SBH, thanks so much for the detailed info!
Originally Posted by *SBH* View Post
Hi there.
New alloy LiPo battery mounts - Very nice look
New ball heads all over the car - more smooth and You need a 2,5mm wrench
Alloy suspension mount inserts as standard - You save 8 gram
Ceramic diff balls as standard
pcar951 is offline   Reply With Quote
Old 06-14-2010, 04:07 PM   #4645
hana166's Avatar
Originally Posted by The Wease View Post
Thank you so much !
Old 06-14-2010, 04:09 PM   #4646
haywood's Avatar
Trader Rating: 48 (100%+)
Default Photon
When will the gear diff be released? Thanks
haywood is offline   Reply With Quote
Old 06-14-2010, 10:09 PM   #4647
OVA
OVA's Avatar
Trader Rating: 74 (100%+)
Where can I find the latest reedy or Nor-Cal set up for 17.5? thanks
OVA is offline   Reply With Quote
Old 06-14-2010, 10:10 PM   #4648
Bishop's Avatar
I read in another thread that a gear diff is due out within a week or so, not sure that was going to be a TOP or other brand though.
QRCCRA
www.qrccra.org.au
www.facebook.com/englandparkraceway
www.myrcm.ch/main?pLa=en&hId[1]=org&dId[O]=4331
Bishop is offline   Reply With Quote
Old 06-14-2010, 11:46 PM   #4649
RC MARKET's Avatar
New brand name gear diff for Photon,
around next week release !
around 15g only
Old 06-15-2010, 04:00 AM   #4650
GeorgePravata's Avatar
Trader Rating: 106 (100%+)
I need 2 please
TEAM ASSOCIATED,REEDY POWER, AKA, TQ WIRES, SILLYBOYZ PRODUCTS.
GeorgePravata is offline   Reply With Quote
