Old 05-24-2010, 08:41 AM   #4501
RC MARKET's Avatar
Today arrived !
T.O.P. Racing "Photon" 1/10 EP Touring Car-top-pa-bmt01bk.jpg   T.O.P. Racing "Photon" 1/10 EP Touring Car-top-pa-bmt01rd.jpg   T.O.P. Racing "Photon" 1/10 EP Touring Car-top-pa-dr0003.jpg
RC MARKET is offline   Reply With Quote
Old 05-24-2010, 08:49 AM   #4502
Trader Rating: 19 (100%+)
does top or another manufacturer make a composite or aluminum replacement spur gear/pulley set?
MDawson is offline   Reply With Quote
Old 05-24-2010, 09:06 AM   #4503
macdude's Avatar
Originally Posted by captain stacker View Post
ok im going to ask a stupid generic question, but how does this car compare to say an xray?
I had an xray 009 and found it very very good and needed nothing in the 6months of owning it. It steered excellent, yet had heaps of traction at the same time.
is the photon a reliable car? does it need any aftermarket parts?
The car is great out of the box. The only weak point that I would replace it the steering bellcrank. I broke it enough times to finally get an aluminum one. The only other thing that I have broken is the the rear hub carriers. And those are now aluminum too. I did add the ceramic bearing and diff balls. But those are probably less necessary than the other things that I mentioned.
Just about every Xray owner I know is now on the TOP photon and loving it.
KO Eurus / Orca / MMP / XB2 / 22-4 /
macdude is offline   Reply With Quote
Old 05-24-2010, 09:26 AM   #4504
Jerzy JayRO's Avatar
Trader Rating: 38 (98%+)
OTHER THEN AMAIN WHERE CAN I GET TOP PARTS?
WwW.BOSSRCMOTORSPORTS.COM
BOSS POWER!!!!!!!!!!!
WWW.NJSlotSpot.COM
Horsham 2009/2010
CRUSH GRAPHIXS---CUSTOM VINYL LETTERING,ANY SIZE,ANY TIME.....
Jerzy JayRO is offline   Reply With Quote
Old 05-24-2010, 09:28 AM   #4505
vabroom's Avatar
Is the aluminum steering bellcrank a TOP part or an aftermarket one? I don't see it on RC Market or A Main sites.
RC racing is still trying to prove that two solid objects can be in the same place, at the same time.
vabroom is offline   Reply With Quote
Old 05-24-2010, 09:32 AM   #4506
RC MARKET's Avatar
TOP ready release !
Old 05-24-2010, 09:33 AM   #4507
RC MARKET's Avatar
www.rcmarket.com.hk
Thanks !
Old 05-24-2010, 09:49 AM   #4508
E.J. Evans's Avatar
Send a message via Yahoo to E.J. Evans
Mark, it's currently being tested. How did the builds go?
T.O.P. Racing | APEX Hobbies | R1 | Solaris | NorCal Hobbies |
Solaris Racing Products (SRP) Solaris Spec Tires!
www.solarisrp.com | www.apexhobbies.com | www.topracingusa.com
E.J. Evans is offline   Reply With Quote
Old 05-24-2010, 10:45 AM   #4509
bkspeedo's Avatar
Anyone have a good setup for rubber tire 13.5 low traction asphalt? What's the website where people are posting there Photon setups?
Brent Klingforth
Sponsors: Awesomatix USA ~ Roche USA ~ ORCA ~ AVID Bearings ~ R1 Wurks
TQ Wire ~ ProtoForm ~ BSR Racing Tires ~ 2mm Design
5280raceway.com [Operated by - Colorado On-Road RC Club]
MILE HIGH INDOOR CHAMPS April 20-23rd 2017 @ www.milehighindoorchamps.com
bkspeedo is offline   Reply With Quote
Old 05-24-2010, 10:57 AM   #4510
Would like to test that as well. What materials did you guys settle on?
I love the cars. It took your team of fairtrace and sheffler and other TOP guys to convince me -but I am glad to have made the switch.
Always had good power but now I have the right car to get it to the ground. Good luck to you and guys this weekend. Represent in Invite!
Old 05-24-2010, 11:42 AM   #4511
macdude's Avatar
The one I got is made by king headz and sold on Amain for 19.99. I will see if I can find the part number. Or you can wait for the one coming from TOP. Not sure if it will be different from this one or not.
AmainPart
King Headz site
Old 05-24-2010, 11:45 AM   #4512
vabroom's Avatar
Thanks, macdude
Old 05-24-2010, 11:49 AM   #4513
stiltskin's Avatar
Trader Rating: 101 (100%+)
you can call TOP USA directly.
Tony Rumple
Team EAM // Gravity RC
stiltskin is offline   Reply With Quote
Old 05-24-2010, 12:05 PM   #4514
jdearhart's Avatar
Trader Rating: 15 (100%+)
Originally Posted by jdearhart View Post
So, if you can run the HPI orings, how about the HPI shock shafts? The reason i ask is I'd like to run the shock on a pan car and I run a long shaft in my HPI's now. But, I'm always looking for something better. What is the length (in mm) of the Top shaft, and can you get longer ones? Right now I'm running a 36mm HPI.
Anyone??
jdearhart is offline   Reply With Quote
Old 05-24-2010, 02:06 PM   #4515
TShirt Man's Avatar
http://www.tchub.info/
TShirt Man is offline   Reply With Quote
