Old 05-20-2010, 10:08 AM   #4486
hi-tech-redneck's Avatar
thanks ej,that does clear things up. will be rebuilding mine for this weekends club race with the new lipo chasse/i ordered both the med & stiff!should be in the mail today or tomorrow! i hope!
tularecountyrc.com/the chicken ranch/exeter hobbies/nor-cal hobbies,ripon raceway/hara tcx/losi 22/top photon vta/tekin/reedy/hpi racing/3racing/AT&T/much more/upgrade rc
hi-tech-redneck is offline   Reply With Quote
Old 05-20-2010, 10:54 AM   #4487
TShirt Man's Avatar
I finally got mine. I am working on the build this weekend. Anyone have any assembly tips? Thanks in advance. Rick B. Nich-vegas, KY.
TShirt Man is offline   Reply With Quote
Old 05-20-2010, 10:57 AM   #4488
RC MARKET's Avatar
Originally Posted by mike ivy View Post
Hey RC market,
When will those velcro strap be available/ also who makes that aluminum pully and is that available to?
Next week release !
RC MARKET is offline   Reply With Quote
Old 05-20-2010, 12:58 PM   #4489
pakk's Avatar
Trader Rating: 79 (100%+)
don't over tighten set screws. They strip out of the plastic easily. Where possible, replace set screws with button head screws. They hold up a lot better.
*Photon* *SC10 4x4*
RCRD
pakk is offline   Reply With Quote
Old 05-20-2010, 04:20 PM   #4490
Trader Rating: 23 (100%+)
EJ Evans
Tried your recommended set-up for my foam chassis and med/low roll centers. Did not have the 1.4 sway bar in the rear. The track temp started about 75 then got got down to 65 f. At the end of the day, I have worn a groove on the inside of my tires. I am running the sweep qts-32's. A couple people said I have burnt them up and my set-up is possibly to stiff for the cooler weather. What changes need to be made? Soften the car up? Being new to outdoor aspahlt racing, any help would be greatly appreciated. The track was also treated with sugar water.
Everyone please feel free to offer any suggestions.
bmcallister is offline   Reply With Quote
Old 05-20-2010, 04:43 PM   #4491
stiltskin's Avatar
Trader Rating: 101 (100%+)
Big thanks to Q for solving a diff problem I was having. The diff was very tight and still slipping. The kit came with 9 thrust balls but only 8 are required. ONLY USE 8. Removed 1 and the diff is golden now. Big props.
Tony Rumple
Team EAM // Gravity RC
stiltskin is offline   Reply With Quote
Old 05-23-2010, 04:36 PM   #4492
vabroom's Avatar
Can someone tell the difference between these two bones:
PO-SDT008 Universal Bone V2
PO-SDT020 Universal Shaft Set V3
Which do you use for the spool?
And on the diff end, you use the 44.5mm bone, if you are using more then 4 cone washers. Correct?
RC racing is still trying to prove that two solid objects can be in the same place, at the same time.
vabroom is offline   Reply With Quote
Old 05-23-2010, 06:13 PM   #4493
Jerry P's Avatar
Trader Rating: 44 (100%+)
I just picked up one of the new kits. I was wondering if it's supposed to come with steel front swing shafts?'
Regards
Jerry
Jerry P
Awesomatixusa - Side Piece Racing - LRP - Sweep Racing Tires - Mike L Designs - TQ Wires - Crispy Critters Raceway
www.awesomatixusa.com
Jerry P is offline   Reply With Quote
Old 05-23-2010, 06:16 PM   #4494
stiltskin's Avatar
Regards
Jerry
The kits come with 46mm aluminum drive shafts for the front and 44.5mm aluminum drive shafts for the rear.
Tony Rumple
Old 05-23-2010, 06:20 PM   #4495
stiltskin's Avatar
They are the same driveshafts and work well with the spool. The 44.5mm bones are used in the rear of the car to limit the plunge and avoid breaking the blades.
Tony Rumple
Old 05-23-2010, 07:34 PM   #4496
macdude's Avatar
I have run or should I say I tried to run the aluminum ones with a spool. They do no hold up to the abuse the spool gives. After run number 4 one snapped off. Of course it happened in the main. I was able to drive the rest of the race but the car was not handling very well.
KO Eurus / Orca / MMP / XB2 / 22-4 /
macdude is offline   Reply With Quote
Old 05-23-2010, 07:51 PM   #4497
vabroom's Avatar
Thanks, Stiltskin, it does get confusing (especially for me) when you order spares and you see ver. 2 & 3.
Old 05-23-2010, 09:16 PM   #4498
Trader Rating: 10 (92%+)
ok im going to ask a stupid generic question, but how does this car compare to say an xray?
I had an xray 009 and found it very very good and needed nothing in the 6months of owning it. It steered excellent, yet had heaps of traction at the same time.
is the photon a reliable car? does it need any aftermarket parts?
captain stacker is offline   Reply With Quote
Old 05-23-2010, 10:15 PM   #4499
Goingfast's Avatar
Trader Rating: 29 (100%+)
...Out of the box is dialed..need no hop up...
Everybody is ignorant, only on different subjects.
AE 12R5.1,Tekin RS PRO
17.5 super stock T.O.P PHOTON , TAMIYA M05 Mini
CEFX.. High Velocity Racing Motor
Goingfast is offline   Reply With Quote
Old 05-24-2010, 07:34 AM   #4500
bkspeedo's Avatar
Anyone have a good setup for rubber tire 13.5 low traction asphalt? What's the website where people are posting there Photon setups?
Brent Klingforth
Sponsors: Awesomatix USA ~ Roche USA ~ ORCA ~ AVID Bearings ~ R1 Wurks
TQ Wire ~ ProtoForm ~ BSR Racing Tires ~ 2mm Design
5280raceway.com [Operated by - Colorado On-Road RC Club]
MILE HIGH INDOOR CHAMPS April 20-23rd 2017 @ www.milehighindoorchamps.com
bkspeedo is offline   Reply With Quote
