Old 05-18-2010, 11:05 AM   #4471
pakk's Avatar
Trader Rating: 79 (100%+)
I have never even attempted to balance my car on the wheels. I just pick it up by the whole in the shock towers and call it done. A year ago, I didn't even balance my cars. I just put anything where ever. Balancing left to right did help me a lot.
I can order up some scales and give it a shot.
*Photon* *SC10 4x4*
RCRD
pakk is offline   Reply With Quote
Old 05-18-2010, 11:08 AM   #4472
Trader Rating: 15 (100%+)
just send me what electronics you run i probably have the weights already.i can actually tell i have everything if the servo is a ko or futaba
AARON YOUNG is offline   Reply With Quote
Old 05-18-2010, 11:30 AM   #4473
pakk's Avatar
ballistic with heat sink and fan
Tekin RS
Ko 2413
Sr3520(I have a SR 3100 in the car, but I'll be changing it soon)
AMB PT
*Photon* *SC10 4x4*
RCRD
Old 05-18-2010, 11:33 AM   #4474
Trader Rating: 54 (100%+)
Originally Posted by pakk View Post
I couldn't stand the belts the way they are. So I ground the chassis down a bit to make the diffs fit. So the belts are flipped and I was able to move everything a lot closer to the middle. Car balances perfectly as you see it with no weights added.
nice solder job... just messn with ya. Mine isnt much better but the locals find it funny
Jamison R is offline   Reply With Quote
Old 05-18-2010, 11:41 AM   #4475
RC MARKET's Avatar
nice pics !
but will lose some rolling !
RC MARKET is offline   Reply With Quote
Old 05-19-2010, 11:41 PM   #4476
pakk's Avatar
Default axle pin: set screw or aluminum pin holder
I just realized that there are two different methods to holding the axle pin in. There is the set screw and the aluminum pin holding collar.
Is there an advantage to either?
*Photon* *SC10 4x4*
RCRD
Old 05-20-2010, 01:19 AM   #4477
RC MARKET's Avatar
New Product coming !
T.O.P. Racing "Photon" 1/10 EP Touring Car-top-battery-magic-tape.jpg
Old 05-20-2010, 01:34 AM   #4478
mike ivy's Avatar
Trader Rating: 50 (100%+)
Hey RC market,
When will those velcro strap be available/ also who makes that aluminum pully and is that available to?
[-eXpress motorsports-] [-TQ Wire-]
1/12th Fo' Life!!! R.I.P Mike Reedy, R.I.P John Williams
[-Horsham RC-] [-Jackson RC-] [-RC Car World-] [ Black Out Free 2015 ]
mike ivy is offline   Reply With Quote
Old 05-20-2010, 03:40 AM   #4479
stiltskin's Avatar
Trader Rating: 102 (100%+)
The set screw is cheaper. . The axle pin covers relieve the stress on the pin and cvd and the assembly feels more free. Maintenance is easier also and no worries about a set screw backing out.
Tony Rumple
Team EAM // Gravity RC
stiltskin is offline   Reply With Quote
Old 05-20-2010, 06:00 AM   #4480
Rod M's Avatar
the Axle pin covers are very nice,
I use them and don't even bother with the using a set screw,
TOPRACING.NET.AU Australian Importer of:
T.O.P. Tokyo Hobbies Optional Parts,
Team Trinity , BL Motors and Tyre compound
Team Tekin , ESC's, motors,
Elangears, Chargers,
Rod M is offline   Reply With Quote
Old 05-20-2010, 07:01 AM   #4481
smoke81's Avatar
Send a message via AIM to smoke81 Send a message via Yahoo to smoke81
Dustin Layne
smoke81 is offline   Reply With Quote
Old 05-20-2010, 08:18 AM   #4482
hi-tech-redneck's Avatar
Default roll center?
Originally Posted by E.J. Evans View Post
Attached is the right setup.
Hey Guys,
Attached is my setup for the 2.25 lipo (stiff) chassis. This is the setup I used to win the South Africa Nationals and also the same setup I've been using at Norcal Hobbies (home of the 2010 Reedy Race and 2010 Roar Nationals). It's slightly different from my 2009 Reedy Race setup.
If you get a chance give it a try.
If you are using the standard 6 cell rubber chassis then use the Medium High roll centers.
EJ
what is a med high roll center= a bit that go's on the car? are they the plastic parts that capture the hinge pins? if so how do i acheve the med- high setup? i notice that the pieces are marked "l" "m" and"h" but it shows 2 of each on the setup sheet! whats the different between the 1st "H" and the second "H" on the setup sheet when the box is checked. or does it have to do with the inserts placement inside that bit. i noticed when i first built my photon that the inserts can be fliped for different hights.can someone explain this to me. i'm sure its kinda important if i want to try this setup!
tularecountyrc.com/the chicken ranch/exeter hobbies/nor-cal hobbies,ripon raceway/hara tcx/losi 22/top photon vta/tekin/reedy/hpi racing/3racing/AT&T/much more/upgrade rc
hi-tech-redneck is offline   Reply With Quote
Old 05-20-2010, 08:35 AM   #4483
pakk's Avatar
You answered your own question. The holes in the aluminum inserts are off center. So when using a medium mount, it can be medium high or medium low based on how you put the insert in.
Med-high means put the center of the whole lower. This will raise the mount a little.
*Photon* *SC10 4x4*
RCRD
Old 05-20-2010, 09:40 AM   #4484
thanks! i was thinking that direction but it still doesen't explain why on the setup sheet it shows 2 highs followed by 2 mediums followed by 2 lows,on the drawing it dosent look any different between the two highs, like the insert has been fliped. just trying to figure this out!i'm also assuming that high means holes more towards top,low would be hole closer to the groundthat part of the setup sheet has always confused me!
Old 05-20-2010, 09:56 AM   #4485
E.J. Evans's Avatar
Send a message via Yahoo to E.J. Evans
There are 6 roll center options on the car. Like pakk mentioned, we have 3 suspension mounts H/M/L (High/Medium/Low) and the insert that goes inside these are vertically off center. Depending how you insert them they can be in the high or low position. If the line is up, it is in the higher position. If the line is down it is in the lower position.
When talking roll centers I always like to start off with the mount then insert. So if I say my roll center is in the medium/high position, that means I have the "M" suspension mount with the line up.
Hope this helps to clarify.
T.O.P. Racing | APEX Hobbies | R1 | Solaris | NorCal Hobbies |
Solaris Racing Products (SRP) Solaris Spec Tires!
www.solarisrp.com | www.apexhobbies.com | www.topracingusa.com
E.J. Evans is offline   Reply With Quote
