Old 05-16-2010, 12:32 PM   #4441
vabroom's Avatar
Originally Posted by captain stacker View Post
just incase this has not been asked before but
what is the difference b/n the int'l ltd edition kits purchased from US and overseas?
I know you're joking but looks like A Main is already on backorder!
RC racing is still trying to prove that two solid objects can be in the same place, at the same time.
vabroom is offline   Reply With Quote
Old 05-16-2010, 07:13 PM   #4442
Trader Rating: 26 (100%+)
Without seeming to be kicking a dead horse here, and i now realise that the intl ed comes with extra susp parts and both chassis plates... but as far as the actual kit is concerned, is there two versions of the Photon kit? rubber vs foam? and if so can anyone help me out and actually let me know the differences. Are all the molded peices of the same hardness??? is it just a different chassis and top deck??? differentials different??? no spool or one-way???
$$$... is offline   Reply With Quote
Old 05-16-2010, 07:37 PM   #4443
macdude's Avatar
Foam has a thicker chassis and top plate. Has the 3 point wings. Front differential, Front universals are aluminum. Front sway bar, heavy front and rear springs.
Rubber has thinner chassis and top plate. Has the 2 point wings. Front spool steel outdrives, and front steel universals. Front and rear sway bar. Lighter springs
Other than that the suspension parts are the same.
KO Eurus / Orca / MMP / XB2 / 22-4 /
macdude is offline   Reply With Quote
Old 05-16-2010, 07:48 PM   #4444
Thanks mate, that's what I was after.
Old 05-16-2010, 09:19 PM   #4445
Mini-Mod's Avatar
New paint for my TOP cars for the Reedy.
T.O.P. Racing "Photon" 1/10 EP Touring Car-my-body-002.jpg   T.O.P. Racing "Photon" 1/10 EP Touring Car-my-body-003.jpg
E.Albano
Yokomo / Hobbywing / JConcepts / A Main Performance Hobbies / Solaris Racing Products / ProTek RC / Schelle / Boom RC / TNP (TopNotchPaints)
Mini-Mod is offline   Reply With Quote
Old 05-16-2010, 10:28 PM   #4446
Trader Rating: 34 (97%+)
Send a message via AIM to King of B Main
any results on Top Gun race?
King of B Main is offline   Reply With Quote
Old 05-16-2010, 10:29 PM   #4447
Trader Rating: 10 (92%+)
its only been confirmed that the US int'l ed kits come with extra suspension parts. Dont know about HK or anywhere else. But doesnt matter where you get the int'l ed kits, it will obviously come with 2 chassis's.
and yes amain have sold all their 12 kits or so in just 2 days.
captain stacker is offline   Reply With Quote
Old 05-17-2010, 02:00 AM   #4448
xray racer's Avatar
Trader Rating: 22 (100%+)
Hey guys,
Just trying to get some feedback from other Mod racers out there running the photon.
Myself and a few of the other TOP Australian drivers are struggling to get rid of understeer in the car. Is anyone else finding this a problem?
Just as an example on the weekend i was running kit set-up plus:
40wt oil all round
1.4 sway bars
Medium carbon (U-brace) in the rear
Middle ackermann position in the center, and rear on the steering blocks
The car seems to turn into the corner hard, but just understeers wide mid corner, and even more so on throttle. High speed steering is lacking also.
From what i gather on here, most of the o/s guys seem to be running close to kit set-up and everything is going well, but its not translating to our tracks out here.
Typically most of our tracks are low to medium grip by your standards.
Look forward to some feedback
Cheers
Robbie
Robbie Lloyd
Yokomo * HobbyWing * Sanwa
xray racer is offline   Reply With Quote
Old 05-17-2010, 03:48 AM   #4449
Professor's Avatar
Default steering issues
hi robbie
i guess u dont want my suggestion for the steering issue
graham
VBC RACING-R1 WURKS AUS--HOBBYWING--SILVERBACK--MAD GRAPHICS--BLITZ
Professor is offline   Reply With Quote
Old 05-17-2010, 05:29 AM   #4450
mazmo's Avatar
Originally Posted by xray racer View Post
Hey guys,
40wt oil all round
1.4 sway bars
Cheers
Robbie
Hey Robbie,
In 10.5 I have same issues, although just made a couple of changes which seem promising - all seem to give more mid corner steering:
1. Sway bars, 1.4 front & 1.2 rear.
2. Radial ackerman 9mm, middle position in centre, forward on steering blocks
3. Shock position on tower - front 4, rear 3
Some anti-squat in the rear should give more steering on & off power.
Will try next time out.
Cheers
Alan
Team TOP Australia www.topracing.net.au
TOP Photon EX 17.5 + TOP Photon EX 21.5 + TOP Rebel F1 21.5
ORCA | Tekin RS Pro | Tekin Gen 2 RPM | Ko Pro-Po | EPIC Trinity
mazmo is offline   Reply With Quote
Old 05-17-2010, 06:48 AM   #4451
Send a message via AIM to munrath
Robbie - I agree with you on low to medium grip tracks. I'm still looking for more. It's better with some of the changes I've made, but I'd like more.
Mark
Tekno RC (RTM) / RadioPost / Tekin / Pro-Match Racing / AKA / PT Racing Oils/Diff Lube
Races for 2015:
PNB, AMS, E-Nats Warm-up, E-Nats, LCRC North East Challenge, RAC, LCRC Halloween, Badlands, ROAR Region 2 Series, and Local Club Racing
munrath is offline   Reply With Quote
Old 05-17-2010, 08:46 AM   #4452
L.Fairtrace's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to L.Fairtrace
It's hard to gauge what is going on when you only post like 4 things about your setup. If you post full setups I may be able to make some suggestions.
I found this weekend that at my local track I couldn't run ej's setup he posted. It really didnt work very well for me. It was considerably slower than my current setup for the track. I'm sure it had something to do with the asphalt type and traction levels because I hear his setup is really dialed at Norcal. This brings up a great point, that the setups we post may be great for one track and not another, dont be afraid to change and experiment with things to suit your track and driving style.
Also anyone with the old shocks be sure to check the inserts in the bottom of the shocks and also the orings. They may be binding and causing weird handling issues. This is super important.
T.O.P Racing - Awesomatix USA - EaMotorsports - BSR Racing Tires - Orca - TQ Wire - Solaris Racing Tires - Side Piece Racing
Horsham RC. Where champions practice Failing. I'm your everything.....
L.Fairtrace is offline   Reply With Quote
Old 05-17-2010, 09:58 AM   #4453
Larry - I started with your setup that you used for the charity race and found that it would turn in great but then not steer through the middle of the corner. Traction was low to medium and the layout was tight/technical.
I changed the spacing at the rear arms from your FR(2.5) / RR (4) to FR (1) / RR (2.5) and it felt better. I also changed the rear camber shims to the following: 1.5 on the camber plate in the rear and 2mm on the rear hub. I then went to 40wt Losi oil front and rear and used the 306 springs on the front. The car seems to tranistion in the chicane better and give more steering in the middle but I felt like I could still use a little more high speed steering. The last change I made was to go to medium low in the rear with no anti-squat. It may be as simple as making a droop change or trying 6 degree blocks.
I know you're busy with the new job and all. Thanks for the support
Mark
Races for 2015:
Old 05-17-2010, 04:27 PM   #4454
I was looking at the image on redrc.net. On the new LiPO chassis, is there a new servo mounting location that is closer to the edge of the chassis?
cvccsi is offline   Reply With Quote
Old 05-17-2010, 05:00 PM   #4455
GeorgePravata's Avatar
Trader Rating: 104 (100%+)
what is the different in the new shock VS the old shock everything looks like to same in my new kit. The new shocks look just like the old shock with all the parts. Some help would be nice. I have 2 kits I must take a look at the 2nd kit to see the shocks. What did they change on the new shocks
TEAM ASSOCIATED,REEDY POWER, AKA, TQ WIRES, SILLYBOYZ PRODUCTS.
GeorgePravata is offline   Reply With Quote
SEO by vBSEO 3.5.0
