Old 05-12-2010, 05:05 PM   #4411
E.J. Evans's Avatar
Send a message via Yahoo to E.J. Evans
Originally Posted by stiltskin View Post
macdude> If you're having a problem breaking rear hubs, try putting a small set screw into the empty hole. It helps support the ball stud and makes them stronger.
The chassis is changed and allows the diffs to be flipped for better weight balance. The shocks were replaced as well. Both are very nice.
Now that's a nice looking car!!!!!!!!!!! You should send it here to Cali so I can run it at the Reedy. LOL
T.O.P. Racing | APEX Hobbies | R1 | Solaris | NorCal Hobbies |
Solaris Racing Products (SRP) Solaris Spec Tires!
www.solarisrp.com | www.apexhobbies.com | www.topracingusa.com
E.J. Evans is offline   Reply With Quote
Old 05-12-2010, 05:18 PM   #4412
stiltskin's Avatar
Trader Rating: 102 (100%+)
What's your address. This thing could use a good win on it's maiden voyage.
OD was supposed to send some Solaris tires with it.... apparently you don't keep any in your trunk.
Tony Rumple
Team EAM // Gravity RC
stiltskin is offline   Reply With Quote
Old 05-12-2010, 05:58 PM   #4413
29TC's Avatar
Send a message via ICQ to 29TC
Can someone post pics of how the lipo battery mount is installed? I am having a hard time figuring out what the c.s scews are used for and how to adjust to fit my lipo packs.
29TC is online now   Reply With Quote
Old 05-12-2010, 06:20 PM   #4414
macdude's Avatar
Thanks for the tip, I just got the aluminum ones today.
KO Eurus / Orca / MMP / XB2 / 22-4 /
macdude is offline   Reply With Quote
Old 05-12-2010, 07:09 PM   #4415
stiltskin's Avatar
That works too.
Tony Rumple
Old 05-12-2010, 10:23 PM   #4416
Trader Rating: 10 (92%+)
how do you know the kit you will be getting is the latest photon?
captain stacker is offline   Reply With Quote
Old 05-12-2010, 10:59 PM   #4417
vabroom's Avatar
I just got mine and it had the regular chassis and the lupo chassis. The box sleeve had a dot next to the Int'l Ltd. Touring Car Kit. I got from Norcal and they have been out of Photons for a while, so I'm guessing this is the latest. Someone correct me if I'm wrong.
RC racing is still trying to prove that two solid objects can be in the same place, at the same time.
vabroom is offline   Reply With Quote
Old 05-12-2010, 11:12 PM   #4418
ok had a look at rcmarket and its the Int'l Ltd. edition which I should look for, which apparently they will stock in a couple of days.
Old 05-13-2010, 07:04 AM   #4419
macdude's Avatar
I just put one on my standard chassis. The only thing I don't like is how overly complicated these are. But I ended up putting only one screw to hold them to the chassis and not using the spacers on the side. I will post pics when I get home.
Old 05-13-2010, 07:12 AM   #4420
Hopefully this piccy helps
T.O.P. Racing "Photon" 1/10 EP Touring Car-dscf0228.jpg
008-Racer is offline   Reply With Quote
Old 05-13-2010, 08:23 AM   #4421
Those looking for a kit I just posted one in the for sale section. Sorry to hi-jack.
Schuurspeed / Aero-model / Gear One / LG1
www.OHRCR.com
Gitsum is offline   Reply With Quote
Old 05-13-2010, 08:59 AM   #4422
its not a kit.
you had me all excited for nothing
Old 05-13-2010, 09:53 AM   #4423
vabroom's Avatar
Captain, keep checking A Main Hobbies, they should be getting the kits this week. They got the majority of the shipment that TopRacingUSA received last week.
Old 05-13-2010, 09:58 AM   #4424
RC MARKET's Avatar
you can move the mount out side ,
don't need use more washer .
RC MARKET is offline   Reply With Quote
Old 05-13-2010, 01:46 PM   #4425
macdude's Avatar
Right I took all the washers out of mine for the regular chassis. But there is only one hole for mounting. Is that correct? Or should I drill another hole?
