Old 05-11-2010, 06:29 PM   #4396
STLNLST's Avatar
Trader Rating: 17 (100%+)
Originally Posted by E.J. Evans View Post
Here is my setup as a PDF.
Remember this is with the 2.25 lipo chassis stiff. If you are running the standard 2.5 Rubber Chassis then use the medium high roll centers.
What if your chassis is 2.5 What roll center spacers do you use then....LOL
STLNLST is offline   Reply With Quote
Old 05-11-2010, 08:06 PM   #4397
macdude's Avatar
Ok, I just got the new aluminum lipo mounts. But I am little confused. I was told that they would fit on the standard chassis, but I am not seeing how this would work without me drilling some new holes in the chassis.
Also, why are they not a solid piece. There are 10 pieces to put together that could have been accomplished in 2 maybe 3.
Last question is if I do manage to get these bolted on to the chassis. How am I suppose to remove the batter once I get them on?
thanks.
KO Eurus / Orca / MMP / XB2 / 22-4 /
macdude is offline   Reply With Quote
Old 05-11-2010, 10:33 PM   #4398
stiltskin's Avatar
Trader Rating: 99 (100%+)
Originally Posted by pakk View Post
what chassis can you reverse the belts with? I can't do it with the chassis I have.
The new chassis has a larger cutout under the diff pulleys to allow you to flip the belts. I just finished building mine and it looks awesome. These new shocks are amazing as well. Can't wait to get this thing on the track.
Tony Rumple
Team EAM // Gravity RC
stiltskin is offline   Reply With Quote
Old 05-11-2010, 11:43 PM   #4399
Trader Rating: 23 (100%+)
Anyone have a outdoor asphalt setup using the foam 6 cell chassis?
bmcallister is offline   Reply With Quote
Old 05-12-2010, 12:24 AM   #4400
E.J. Evans's Avatar
Send a message via Yahoo to E.J. Evans
You can try my setup I posted a couple pages back. Use the "M" roll centers in the low position.
T.O.P. Racing | APEX Hobbies | R1 | Solaris | NorCal Hobbies |
Solaris Racing Products (SRP) Solaris Spec Tires!
www.solarisrp.com | www.apexhobbies.com | www.topracingusa.com
E.J. Evans is offline   Reply With Quote
Old 05-12-2010, 02:41 AM   #4401
Iceman 69's Avatar
Hey Iceman, I'll post it in a couple days. I have to go look at my car.
Thanks mate really appreciate it
Cheers
Cyclone TC~SP GT pro~10.5????????
Cyclone ~ RS Pro ~ SP13.5 V3
Cyclone ~ Spare
Iceman 69 is offline   Reply With Quote
Old 05-12-2010, 10:39 AM   #4402
Trader Rating: 26 (100%+)
Ok guys I've decided... and the winner is Photon! What are some of the things to look out for, or should I grab when I get my kit? The new shocks are on my list, but not gunna be here for a few weeks.
Can someone tell me what the difference is between the original drive shafts and the ver.2 or ver.3??? which ones come with the kit? Do they/should they be upgraded?
$$$... is offline   Reply With Quote
Old 05-12-2010, 10:40 AM   #4403
L.Fairtrace's Avatar
Send a message via AIM to L.Fairtrace
IF you are getting a new kit it should come with the V2 shocks.
T.O.P Racing - Awesomatix USA - EaMotorsports - BSR Racing Tires - Orca - TQ Wire - Solaris Racing Tires - Side Piece Racing
Horsham RC. Where champions practice Failing. I'm your everything.....
L.Fairtrace is offline   Reply With Quote
Old 05-12-2010, 10:44 AM   #4404
Not really sure how "old" the kit would be, I'd have to ask the distributer here for that answer I guess...
Any input as to the driveshafts???
Old 05-12-2010, 11:49 AM   #4405
Goingfast's Avatar
Trader Rating: 29 (100%+)
What are the improvement from the old and new photon kit?
Everybody is ignorant, only on different subjects.
AE 12R5.1,Tekin RS PRO
17.5 super stock T.O.P PHOTON , TAMIYA M05 Mini
CEFX.. High Velocity Racing Motor
Goingfast is offline   Reply With Quote
Old 05-12-2010, 12:06 PM   #4406
macdude's Avatar
If you are getting the newer kit it should have the lipo chassis. The one I got was the version before the shocks where changed. I haven't really had any issue with them so I have not changed them. The kit comes with 1 extra of every supension part. But from experience the thing you break the most is the steering bellcrank. So get the aluminum one. After 4 broken with and without a saver. I would also get the aluminum rear hubs. Not sure why but any spin out into the boards and the top of the plastic ones just breaks off. I thought I had gotten a bad one the first time it happened. But the other three in the kit all eventually broke with very little impact. The newer kits come with steal out drives for the spool, if you get the foam kit, pick up a spool for rubber tires. I also recommend the ceramic diff balls. Smooth.
For weight I would get the center one piece made by top and a couple of the round weights for front and rear. And they make weights that fit in the battery brace. I just used lead there.
Oh and the kit does not come with grease so if you don't have any I just used the muddslide stuff.
One last thing, pick up a spring kit and a some extra shims the kit doesn't have very many extra's.
Hope this helps
Old 05-12-2010, 03:06 PM   #4407
stiltskin's Avatar
macdude> If you're having a problem breaking rear hubs, try putting a small set screw into the empty hole. It helps support the ball stud and makes them stronger.
The chassis is changed and allows the diffs to be flipped for better weight balance. The shocks were replaced as well. Both are very nice.
T.O.P. Racing "Photon" 1/10 EP Touring Car-sany0702.jpg   T.O.P. Racing "Photon" 1/10 EP Touring Car-sany0703.jpg   T.O.P. Racing "Photon" 1/10 EP Touring Car-sany0698.jpg
Tony Rumple
Old 05-12-2010, 03:22 PM   #4408
Trader Rating: 19 (100%+)
Does anyone know when Amain will have these in stock? Will it come with extra spares too or is it only when you buy it direct at TOP ?
zake540 is offline   Reply With Quote
Old 05-12-2010, 03:26 PM   #4409
stiltskin's Avatar
Amain should have their kits today or tomorrow. They will have the extra parts included.
Tony Rumple
Old 05-12-2010, 03:47 PM   #4410
Thanks Stiltskin!
SEO by vBSEO 3.5.0
