Old 04-19-2010, 08:41 AM   #4216
Right, my scanner dont want to work so ill just type this out
General
Caster 4*
Front Drive Spool
Wheelbase FF 1mm FR 2.5mm, RF 2.5 RR 1
Toe 1* out
Front and rear wing Rubber Asphalt
Vertical Ackerman Middle
Radial Ackerman 10
Top deck Rubber Ashpahlt
Front
Camber 1.5
Droop 35.5mm
Top shock hole 4
Bottom Hole 2
2mm inside link, 0mm outside in hole 3 on standard plate
2.5mm ARB link (mounts upside down)
1.5mm front roll bar
FF 0mm (if more mid corner needed go to 0.5mm)
FR 0mm
inside hole on steering block
Rear
Camber 2
Droop 33.5mm
Top shock hole 3
Bottom hole 2
1.5mm inside link, 1mm outside (want to try 1.5mm) hole 3 standard plate
1.25mm rear bar
RF 1mm (prostock i run 0.5-0.8mm then 2.5 overall toe)
RR 3.4mm
Roll centers Mid low all round
Shocks
12.35mm (body to ball joint)
1.1mm piston (tamiya 3)
400CST front and 350cst rear (MM Oil)
3.0 Xray front springs and 2.6 Xray rear
General
SP V3 4.5 turn, geared at 100/26
Muchmore 5200 50c lipo
LTC shell (a must really)
Sorex 32's with tweak
Car was going quite well with this setup and could easyly do low 18's high 17's on a very dusty track.
Craig Morgan - Tamiya 417
Slick990 is offline   Reply With Quote
Old 04-19-2010, 10:15 AM   #4217
General
Caster 4*
Front Drive Spool
Toe 1* out
Radial Ackerman 10
Top deck Rubber Ashpahlt <-- Kit top deck ?
Front
Camber 1.5
Droop 35.5mm
Top shock hole 4
Bottom Hole 2
2.5mm ARB link (mounts upside down) <-- not sure what you mean by upside down ?
FR 0mm
Rear
Camber 2
Droop 33.5mm
Top shock hole 3
Bottom hole 2
1.25mm rear bar
RR 3.4mm
Shocks
General
Thanks, will be trying that setup this weekend all things going well
CPD Racing
chris_dono is offline   Reply With Quote
Old 04-19-2010, 10:18 AM   #4218
Where the ARB mounts to the shock tower. The manual has the cut out towards the bottom screw, i have turned mine round so the cut out is towards the top screw.
Keeps the roll bar flatter.
Yes kit top deck.
Old 04-19-2010, 10:23 AM   #4219
dawgmeat's Avatar
is there a link or pic of the new coming out> thanks in advance
dawgmeat is offline   Reply With Quote
Old 04-19-2010, 10:30 AM   #4220
L.Fairtrace's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to L.Fairtrace
Pic of what?
T.O.P Racing - Awesomatix USA - EaMotorsports - BSR Racing Tires - Orca - TQ Wire - Solaris Racing Tires - Side Piece Racing
Horsham RC. Where champions practice Failing. I'm your everything.....
L.Fairtrace is offline   Reply With Quote
Old 04-19-2010, 10:35 AM   #4221
dawgmeat's Avatar
The new or updated Proton
Old 04-19-2010, 10:37 AM   #4222
There is nothing that is going to look different. I believe its going to have the new shocks which look almost exactly the same. A lipo chassis(no cutouts for nimh) and a couple other small running changes but nothing thats going to look any different as far as I know.
Old 04-19-2010, 10:56 AM   #4223
dawgmeat's Avatar
thanks so is it safe to say that outside weight brace is gone?
Old 04-19-2010, 11:00 AM   #4224
Yes kit top deck.
Ahh yes, I understand where you mean now.. already had them that way up
CPD Racing
Old 04-19-2010, 11:30 AM   #4225
That I do not know about. But you dont have to run it if you dont want.
Old 04-19-2010, 11:53 AM   #4226
locked's Avatar
Roughly what size pinion gear do you think I should use along with the stock 100T 64P spur gear on a med-large track running a 17.5 tekin redline with an RS pro esc?
I'm guessing the number of teeth should be somewhere in the high twenties to low thirties, but I could be way off. Any expert advice would be greatly appreciated.
what is the drivetrain ratio (internal) on a Photon? around 2?
Dave Locke
Team PerformanceHobbies.ca | ORCA RC | Bodies by Brandon | Team Meeting
XRAY T4'15 x2 | XRAY XB4 | XRAY XB8E | XRAY XB8
locked is offline   Reply With Quote
Old 04-19-2010, 12:07 PM   #4227
odpurple's Avatar
20 tooth into 40 tooth=2.0:1 IR
TOP Racing USA--OD Racing--Novak--Power Push--J Spec
odpurple is offline   Reply With Quote
Old 04-19-2010, 12:27 PM   #4228
locked's Avatar
Thanks odpurple. There is still so much I need to learn about this hobby. It's a bit overwhelming.
Dave Locke
Old 04-19-2010, 12:36 PM   #4229
Iam by no means an expert, but run the same set-up at SpeedWorld a med-large track. I started with a 37tooth pinion and had great straightway speed and very nice power in the in-field. It did get hot(175-180), but installed a fan and that cured the heat problem without having to gear down a tooth or two. The ESC is running the 203 software, but Iam not sure what it is set at, one of the fast guys at our track set it up to the standard set-up used at our track. I will be going down a tooth the next time out, but either of these will get you in the ball park in belive. Make sure you keep an eye on the temps.
TheOtherBill is offline   Reply With Quote
Old 04-19-2010, 12:58 PM   #4230
locked's Avatar
So if I calculated this correctly, I should be aiming for a FDR around 5.5 and adjust from there.
Thank you very much Bill
Dave Locke
