Old 04-17-2010, 11:45 AM   #4201
vabroom's Avatar
Thanks, odpurple, will wait. Will be looking for help at Norcal and Speedworld, once I start racing again.
RC racing is still trying to prove that two solid objects can be in the same place, at the same time.
vabroom is offline   Reply With Quote
Old 04-17-2010, 10:10 PM   #4202
smoke81's Avatar
Send a message via AIM to smoke81 Send a message via Yahoo to smoke81
I'm racing in Denver at the CCC, and on the way out I found out the new shocks came in. I had OD ship them to the track, and they are worth it. For that I gotta think OD. He puts up with my crazy last minute orders all the time. I really appreciate it.
As for the shocks, they are the best shocks I've ever had. So smooooth. Even a couple Tamiya guys made comments about how good they feel. Very nice pieces.
Dustin Layne
smoke81 is offline   Reply With Quote
Old 04-18-2010, 03:42 AM   #4203
Hi,
How do you know the difference between the old and the new?I think they both have the same part numbers.
grouchy is offline   Reply With Quote
Old 04-18-2010, 07:47 AM   #4204
EJ stated a few pages back that the V.2 shocks have a derlin shaft guide that is white for the new shocks. And the shock body size is slightly larger(0.1mm) I belive.
TheOtherBill is offline   Reply With Quote
Old 04-18-2010, 09:32 AM   #4205
stiltskin's Avatar
Trader Rating: 99 (100%+)
Originally Posted by grouchy View Post
Hi,
If you want to order the new shocks and be positive that you are getting the NEW ones, call TOP USA directly. OD is definitely "da man".
Tony Rumple
Team EAM // Gravity RC
stiltskin is offline   Reply With Quote
Old 04-18-2010, 12:23 PM   #4206
Nova F1 Racer's Avatar
R/C Tech Charter Subscriber
OK I looked through this thread and missed which direction the axle pin holder goes on.... Can some one please help an old fart out?
This is DICK!!! And you're NOT!
RC Tech member #11
Aussie Rules Footy, Brisbane LIONS!!
[url]http://www.pitter-pat.com/[/url] for pet care needs in Northern Virginia
Nova F1 Racer is offline   Reply With Quote
Old 04-18-2010, 12:25 PM   #4207
Originally Posted by P2 View Post
Wheel side so they can't slide off.
Opps found it....
RC Tech member #11
Old 04-19-2010, 04:57 AM   #4208
Hey guys,
Are any of the changes or new parts aimed at giving the car more steering ? There's a few of us here in the UK running the car on asphalt and all the setup changes we make are to try and get more steering from the car as it seems that the rear of the car grips so much that it will push all the time.
Any advice appreciated.
Chris
CPD Racing
chris_dono is offline   Reply With Quote
Old 04-19-2010, 05:20 AM   #4209
BagofSkill's Avatar
Hey Chris,
I also found that the USA setups don't work in the UK just massive understeer! I've got a setup on now that I'm VERY happy with, kep points are 344 Front springs with 324 Rear, 2.5 rear toe, and the roll centres and ackerman as suits you.
HTH, Chris.
BagofSkill is offline   Reply With Quote
Old 04-19-2010, 07:00 AM   #4210
Lack of steering in the Uk?
Ive had enough steering lately been tempted to stick it on ebay!
All serious though, where do you want the steering, and what setup are you running?
Craig Morgan - Tamiya 417
Slick990 is offline   Reply With Quote
Old 04-19-2010, 07:29 AM   #4211
Originally Posted by BagofSkill View Post
Hey Chris,
HTH, Chris.
I'm running 2.5 rear toe, 400-500 cst oil, springs ranging from hpi blue up to pink/silver (and many other makes of springs too, tried the top 289's yesterday which were better than stiffer springs)
It needs it everywhere, but mostly in the middle of the corner... it just seems to wash out...
running sorex 32's outdoors
CPD Racing
Old 04-19-2010, 07:32 AM   #4212
What shell you running?
Tried adding a shim to the FF mount to add a little arm sweep? I run about 0.5-1mm there.
Is the car just understeering out, or is the back end wanting to swap mid corner?
And lastly any chance you can get a setup sheet up, or written out and what track. Sorry for all the questions but gives us a better idea then.
The new lower weight really did not suit my car when i first run it but really coming toghether now and was very happy with the car round cotswold.
Old 04-19-2010, 08:36 AM   #4213
Shell: Speed 6 (tried an LTC-R and it rotated too much coming out)
It's understeering out... i really have to wait for it before getting on the power..
I've got a setup sheet at home which was "ok" around aldershot, although needs more steering. Was at west london yesterday, although don't have a sheet for that just yet.
I'm at work at the moment, but will get one up tonight with exact details.
Front:
top shock position 3 (289 spring 400 cst much more oil)
lower shock position 2
Std wing on bulkheads
Ackerman insert 12, saver set so arms are parallel
Steering links in front hole on arms
-1.5 camber
0.5 toe out
medium low roll centre all round
1.4 roll bar
Rear:
top shock position 4 (289 spring 400 cst much more oil)
lower shock position (have tried all 3, but currently in hole 1, so flipped wishbone)
2.5 toe
-1.5 camber
1.2 roll bar
Other:
Medium top deck, tried the kit one and the car felt lazy.
Like i say, the car isn't BAD at all, it just needs more steering, and most of the stuff we've done here has helped without losing rear traction, so that's a great thing !
CPD Racing
Old 04-19-2010, 09:17 AM   #4214
Front:
top shock position 3 (289 spring 400 cst much more oil) Seems a very "light" spring for the front of the car, the top springs do have a tendancy to collapse over bumps which aldershot have quite a few and can make the car wash out...what piston?
Ackerman insert 12, saver set so arms are parallel Seems quite alot there, ive got quite settled on middle and insert 10. Tried insert 9 on saturday and car was lazy
-1.5 camber
0.5 toe out
1.4 roll bar
Rear:
top shock position 4 (289 spring 400 cst much more oil) agian seems very soft
lower shock position (have tried all 3, but currently in hole 1, so flipped wishbone) havent used anything else but 2
2.5 toewhat shims do you use in the RF?
-1.5 camber
1.2 roll bar
Other:
Medium top deck, tried the kit one and the car felt lazy. Ive tried both and dont mind which one i use
Some things that might help you there.....i have a setup sheet i will write up later and you can have a look at that and see if it might point you in a direction. One last question, is this for prostock?
Old 04-19-2010, 09:25 AM   #4215
I tried stiffer springs and it just gave more understeer, settled on those (this was from west london, it was hpi silver all round at aldershot)
no shim in RF, just RR
a sheet would be great, especially for Cotswolds (I'm up there this weekend for the club meet hopefully) , but no this is in mod. working with a mate of mine, who IS running pro stock though, and we're both trying to find the same thing with the car.
I sound like I'm moaning about the car, but i'm not... even with this understeer, it's still a whole lot faster than my old xray
CPD Racing
SEO by vBSEO 3.5.0
