Old 04-14-2010, 02:35 AM   #4171
Default Roll centers
Can some one help i am confuse
When do i use low-med-hig role center bloks.
On traks with high traktion or low traktion
and what is the working of it
I did read about it but every one have his own Idee
IF its gone help whe run out doors asphalt with foam.
HELP please
diffscrew is offline   Reply With Quote
Old 04-14-2010, 02:48 AM   #4172
Originally Posted by RC MARKET View Post
was released over 1 months !
New chassis,was release when?
grouchy is offline   Reply With Quote
Old 04-14-2010, 03:39 AM   #4173
Skitee's Avatar
Not a new chassis just the V2 TOP shocks
Xray T4 2017 ~ ORCA Vritra VX3 ~ Motiv RC 4.5
Xray T4 2017 ~ ORCA Vritra VX3 ~ R1 Wurks 13.5
Xray X12 2016 ~ ORCA Vritra VX3 ~ Orca TX 4.5
POWERED BY SPEEDZONE USA
Skitee is offline   Reply With Quote
Old 04-14-2010, 05:31 AM   #4174
Ok OD is officially on suspension for not telling me about these v2 shocks! OD you know I want these add it on lol!
Schuurspeed / Aero-model / Gear One / LG1
www.OHRCR.com
Gitsum is offline   Reply With Quote
Old 04-14-2010, 06:29 AM   #4175
*SBH*'s Avatar
HELP please
Hi Diffscrew
There are many factors to this, but basicly higher roll center gives more grip, and lower roll center gives less grip.
*SBH* is offline   Reply With Quote
Old 04-14-2010, 06:41 AM   #4176
PitNamedGordie's Avatar
Send a message via AIM to PitNamedGordie Send a message via Yahoo to PitNamedGordie
Originally Posted by *SBH* View Post
Hi Diffscrew
Actually you have that reversed...
Low roll center - the chassis rolls more and you get more grip.
High roll center - the chassis rolls less and you get less grip.
☆ The Track @ Harbor Hobbies ☆ www.harbor-hobby.net ☆
PitNamedGordie is offline   Reply With Quote
Old 04-14-2010, 07:50 AM   #4177
RCFREAK's Avatar
Trader Rating: 17 (100%+)
And if you run a higher roll center, you also may want to soften the front springs
And with a lower roll center you can run slightly harder springs to counteract the roll...
Arv.
RC AMERICA// EA MOTORSPORTS// KO PROPO// ORCA
RCFREAK is offline   Reply With Quote
Old 04-14-2010, 09:42 AM   #4178
I am interested in purchasing a Photon kit but I've been waiting for the specs to "stabilize".
I was under the impression that a major chassis redesign might be included and now I see new shocks coming out.
Can somebody from TOP indicate when the new shocks might be a part of the standard kit and what's the status on a new chassis plate with the newer battery mounts?
Will the chassis be updated at all?
I'm not keen to buy the kit only to find out a major revision just came out a month later.
DM1-S Tekin 2650Kv
MTX-3 MR .12
TA05 IFS-R Tekin 17.5
TA03R Cirtix 17.5 club spec
F109 Tekin 21.5
danketchpel is offline   Reply With Quote
Old 04-14-2010, 09:58 AM   #4179
marcel p's Avatar
Send a message via MSN to marcel p
tis is wat disturbs me also. my kit is old already.
can somone at top make a summary of al parts that bin updated please.
PR racing
Powerstar/futaba 4px
Absima /vr racing
marcel p is offline   Reply With Quote
Old 04-14-2010, 10:00 AM   #4180
marcel p's Avatar
Originally Posted by marcel p View Post
hello
are there difrent arms for the photon.
i got some with 2 times 2 holes for the shocks.
normaly i have 1 hole an 2 holes at the arm
also are there arms off softer material avaleble (more flex)?
can somone give me a answer for this question please
PR racing
Absima /vr racing
Old 04-14-2010, 10:24 AM   #4181
stiltskin's Avatar
Trader Rating: 102 (100%+)
The newer kits are expected any day now and will include the updated shocks. The older shocks had a problem with leaking when using the original o-rings. The kits were updated at that time to include the harder o-rings to help with the leakage. They have now redesigned the shocks and switched factories for their production. The new chassis will also be included in the new kits, but last time I talked to Michael, he was unsure which chassis would be spec'ed in the new kits. The soft 2.25 or medium 2.5 chassis should be standard. The top deck was revised to allow for batteries using corally-style plugs. The car is still relatively new and running changes can be expected. Don't feel like your kit is out-of-date by any means. The car is still uber dialed in whatever form you are running.
Tony Rumple
Team EAM // Gravity RC
stiltskin is offline   Reply With Quote
Old 04-14-2010, 10:29 AM   #4182
stiltskin's Avatar
I don't know of any arms with 4 holes or any softer arms. I'm hoping to speak with OD later today and I'll ask him about them.
Tony Rumple
Old 04-14-2010, 10:50 AM   #4183
marcel p's Avatar
thanks stiltskin
PR racing
Absima /vr racing
Old 04-14-2010, 10:56 AM   #4184
odpurple's Avatar
Damn! There goes the surprise
TOP Racing USA--OD Racing--Novak--Power Push--J Spec
odpurple is offline   Reply With Quote
Old 04-14-2010, 10:57 AM   #4185
RCFREAK's Avatar
Tony.. my latest kit i just built had rear arms that has 4 hole shock positons.. the fronts still have 3 holes.
Gonna order the newer shock set... should be more dialed!
Arv.
Arv.
