Old 03-26-2010, 08:40 AM   #4021
AeRacer805's Avatar
Originally Posted by E.J. Evans View Post
We will have three new chassis to replace the existing chassis. At some point one of these chassis will come standard with the kit.
Chassis 1) 2.25mm Regular Flex
Chassis 2) 2.25mm Medium Flex
Chassis 3) 2.75mm Stiff Flex
The million dollar question is when will the new chassis be avilable to buy. I need one to replace my worn out one (at least that's what the voices in my head tell me) I need to rebuild my car anyways for the Roar region 12 ON-Road coming up on April 24th and 25th (shameless plug)
"When you are not practicing someone else is and when you meet that person they will beat you."
TC6, Top Photon, B4.1, SC10 FT, Orion Motors and Servos, Tekin RS
AeRacer805 is offline   Reply With Quote
Old 03-26-2010, 04:51 PM   #4022
Timmie's Avatar
I've finally been able to drive my Photon on asphalt, and the car is working awesome. Running a similar setup to EJ's and using a 10.5, the car was really stable and rotated well. I felt the car needed more on power steering, so I made some small adjustments and the car feels even better. Something I've noticed in the short amount of time I've had with the car, is that small adjustments can really be felt. This car is a lot of fun
:: Serpent America ::Desoto Racing :: Track Star Racer Services ::Skyrocket Racing::TOP::
Timmie is offline   Reply With Quote
Old 03-26-2010, 06:24 PM   #4023
After seeing a boatload of guys running the TOP car at SpeedWorld last weekend I knew that I had to have one. I picked one up yesterday and have been building it this afternoon, it really is a quality kit great manual and the fit and finish is outstanding. Where are you guys getting the setups from?? Thanks
TheOtherBill is offline   Reply With Quote
Old 03-26-2010, 06:28 PM   #4024
Trader Rating: 28 (100%+)
EJ! Take care of this guy!
Team I'm Over It
racenut123 is offline   Reply With Quote
Old 03-26-2010, 06:55 PM   #4025
mazmo's Avatar
Timmie,
I also use E.J's set up. Its good. What changes did you make to improve on power steering?
Team TOP Australia www.topracing.net.au
TOP Photon EX 17.5 + TOP Photon EX 21.5 + TOP Rebel F1 21.5
ORCA | Tekin RS Pro | Tekin Gen 2 RPM | Ko Pro-Po | EPIC Trinity
mazmo is offline   Reply With Quote
Old 03-26-2010, 06:58 PM   #4026
Thanks John, just when I think Iam out, they pull me back in
Old 03-26-2010, 07:35 PM   #4027
Timmie's Avatar
Here is a website with useful information, including setups from drivers around the world. http://tchub.info/
Old 03-26-2010, 07:43 PM   #4028
Timmie's Avatar
Originally Posted by mazmo View Post
Timmie,
Hi Mazmo,
I reduced the front droop, and added a little anti squat to the rear of the car. Doing these changes, I was able to be at near, or full throttle through the high speed sections of my track.
Old 03-26-2010, 08:20 PM   #4029
Rod M's Avatar
Gear diff is being testing now. Results are good so far, I'll post when more testing is done. This is still a long ways away.
this is the difference between the three chassis
Standard - 2.25mm (anisotropic fiber)
Stiff - 2.25mm (isotropic)
Super Stiff - 2.75 (isotropic)
apparently the chassis kits will be available mid/late April
I am looking forward to the Gear diff
TOPRACING.NET.AU Australian Importer of:
T.O.P. Tokyo Hobbies Optional Parts,
Team Trinity , BL Motors and Tyre compound
Team Tekin , ESC's, motors,
Elangears, Chargers,
Rod M is offline   Reply With Quote
Old 03-26-2010, 08:20 PM   #4030
tallyrc's Avatar
how much anti squat are you running? i just added a bit but havent had the chance to run it since i made the change.. i'm running both mediums but one eccentric up and the rear one down.. guess that's a half mill?
WWW.STORMERHOBBIES.COM helping keep pan cars alive!
Turns out not where, but who your with that really matters... DMB
tallyrc is offline   Reply With Quote
Old 03-27-2010, 03:34 AM   #4031
mazmo's Avatar
Hi Mazmo,
Thanks Timmie I'll give that a try .... will change the droop first.
Old 03-27-2010, 12:37 PM   #4032
Timmie's Avatar
1 degree. I think I will take it down to half a degree later today while I try some things out. Yes, the way you have your eccentrics is half a degree.
Anytime Mazmo Let us know how it turns out.
Old 03-27-2010, 01:16 PM   #4033
Timmie's Avatar
Finally have had the time to paint a body for my car, so I decided to show it off Never had a red paint job, so it seems fitting since the chassis is red.
Also I included a custom fan mount I made up for the car. Maybe it will give someone a idea if they wanted to mount a fan. Keeps the weight low, and is adjustable if I change motor position due to gearing. Enjoy!
[IMG][/IMG] [IMG][/IMG][IMG][/IMG]
Old 03-27-2010, 01:18 PM   #4034
Team STPN's Avatar
Let me know if you need help on the car at Speedworld. This link has EJs set up (http://www.tchub.info/) with other set ups too. I believe the only change on EJs set up for Speedworld is the front shocks are stiffer and the pistons are 1.2s.
Team STPN is offline   Reply With Quote
Old 03-27-2010, 05:58 PM   #4035
Thanks STPN, will do I have the car about built. Waiting on a Servo and ESC, running F-1 tommorow will bring it then. Not quite sure about the cam adjusters on the hinge pin mounts?? Thanks
SEO by vBSEO 3.5.0
