Old 03-25-2010, 03:29 PM   #4006
PitNamedGordie's Avatar
Send a message via AIM to PitNamedGordie Send a message via Yahoo to PitNamedGordie
Originally Posted by Dusttt View Post
I would be seriously intersted in buying one of these cars if they released one with all of this new stuff included.
Ya know I sold my Photon...but if there was a kit with all these upgrades I may buy another. Looks nice.
☆ The Track @ Harbor Hobbies ☆ www.harbor-hobby.net ☆
PitNamedGordie is offline   Reply With Quote
Old 03-25-2010, 03:33 PM   #4007
Mini-Mod's Avatar
Gear diff?
I'm going to have to stick with ball diffs on this one.
E.Albano
Yokomo / Hobbywing / JConcepts / A Main Performance Hobbies / Solaris Racing Products / ProTek RC / Schelle / Boom RC / TNP (TopNotchPaints)
Mini-Mod is offline   Reply With Quote
Old 03-25-2010, 03:37 PM   #4008
Originally Posted by RC MARKET View Post
yes ,
LW alum. outdirve .
lightweight than ball diff !
but this pics car isn't me .
Originally Posted by stiltskin View Post
More consistent, no slip, tunable with different oils for tighter/looser "feel".
Thanks.
That will be the diff for me.
Also the lipo chassis and the spur gear holder.
http://www.mikky32.com
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
mikky32 is offline   Reply With Quote
Old 03-25-2010, 03:47 PM   #4009
E.J. Evans's Avatar
Send a message via Yahoo to E.J. Evans
Default New Lipo Chassis
We will have three new chassis to replace the existing chassis. At some point one of these chassis will come standard with the kit.
Chassis 1) 2.25mm Regular Flex
Chassis 2) 2.25mm Medium Flex
Chassis 3) 2.75mm Stiff Flex
Gear diff is being testing now. Results are good so far, I'll post when more testing is done. This is still a long ways away.
T.O.P. Racing | APEX Hobbies | R1 | Solaris | NorCal Hobbies |
Solaris Racing Products (SRP) Solaris Spec Tires!
www.solarisrp.com | www.apexhobbies.com | www.topracingusa.com
E.J. Evans is offline   Reply With Quote
Old 03-25-2010, 03:53 PM   #4010
I want chassis 1.
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
Old 03-25-2010, 04:01 PM   #4011
mazmo's Avatar
ok
Team TOP Australia www.topracing.net.au
TOP Photon EX 17.5 + TOP Photon EX 21.5 + TOP Rebel F1 21.5
ORCA | Tekin RS Pro | Tekin Gen 2 RPM | Ko Pro-Po | EPIC Trinity
mazmo is offline   Reply With Quote
Old 03-25-2010, 04:27 PM   #4012
locked's Avatar
Thank you for the response Stiltskin. I'll probably wait a bit to see what gets added to new kits.
Oh and to EJ from several pages ago... I think you are right. I need to move near a decent track. Cost of living would probably be lower than where I am too, so I might have more spare money for r/c stuff. I don't know anyone IRL with an R/C car, so starting a club near me could prove difficult.
Dave Locke
Team PerformanceHobbies.ca | ORCA RC | Bodies by Brandon | Team Meeting
XRAY T4'15 x2 | XRAY XB4 | XRAY XB8E | XRAY XB8
locked is offline   Reply With Quote
Old 03-25-2010, 06:03 PM   #4013
JamesReilly's Avatar
Trader Rating: 57 (100%+)
When do the Aluminum ball ends come out?
Thanks,
James
Reilly Paint ([email protected])
JamesReilly is offline   Reply With Quote
Old 03-25-2010, 08:13 PM   #4014
Timmie's Avatar
Wow, gear diff would be neat to play with. I'll be putting mine in the front Tunable spool if you will
:: Serpent America ::Desoto Racing :: Track Star Racer Services ::Skyrocket Racing::TOP::
Timmie is offline   Reply With Quote
Old 03-25-2010, 08:16 PM   #4015
stiltskin's Avatar
Trader Rating: 102 (100%+)
I was thinking the same thing. I'd really like to see how it reacts with some thicker oil in the front.
Tony Rumple
Team EAM // Gravity RC
stiltskin is offline   Reply With Quote
Old 03-25-2010, 08:27 PM   #4016
macdude's Avatar
I have been wanting to try running a diff up front since I started racing again. Last time I was running TC everyone was running a front diff. I suppose you might be able to get a similar effect if you where to run with no balls with the rings really tight to the diff. That way you still get some diff action but almost no slip. Might make the tires wear better. And the car would have much more steering. I think I might have to try that this weekend. _
KO Eurus / Orca / MMP / XB2 / 22-4 /
macdude is offline   Reply With Quote
Old 03-25-2010, 08:30 PM   #4017
Timmie's Avatar
Biggest adjustment I see running the gear diff up front will be off power steering. By tuning with different silicone fluids, it will change the amount of turn in. By being able to tune the differentials lock up, it gives the user the ability to alleviate a major complaint with spools....off power push.
This is going to get interesting
Old 03-25-2010, 08:38 PM   #4018
Timmie's Avatar
Yeah you are right,
Tire wear will go down as well. Not only that, but you won't have spool chatter(though I've noticed it's almost non existent with the Photon) less wear on the front axles, and less chance of bending a axle in a really bad wreck.
On other cars I've made slipper spools before using Traxxas nitro truck spur gear pegs. So if you have a spare ball diff for your car, hit up your local hobby shop for the spur gear pegs. You might have to open up the holes in the pulley some, but then once installed you can lock the ball diff down but adjust a little slip in it.
Old 03-26-2010, 03:33 AM   #4019
sosidge's Avatar
This is basically a "slipper spool" design that a few cars have used before.
You are not getting a true diff action with it - any differential speed between the wheel is caused by slip - and slip slows you down. It's basically a spool with a bit of give to decrease damage. However the Photon is durable enough to cope with a true spool in the front.
A heavy-oiled gear diff in the front would be a very interesting thing to test.
Old 03-26-2010, 06:23 AM   #4020
smilekt's Avatar
yes ,
LW alum. outdirve .
very nice .. when release ? it still using C blade ?
Kuala Terengganu Rc Club Facebook
http://www.facebook.com/group.php?v=wall&gid=357083332025
smilekt is offline   Reply With Quote
