Old 03-22-2010, 09:46 PM   #3946
Timmie's Avatar
I finally got to race my Photon for the first time yesterday and its dialed! I tq'd, won, and set track record for fast lap on out current carpet layout. Only had one problem with the car, I forgot to tighten the spur gear lay shaft bolts and stripped a spur Lessoned learned, won't happen again
But finally, outdoor season is here! I'm going to run 10.5 for its maiden asphalt run. Does anyone have a suggestion on what front spring to use? If not I plan on just running EJ's 13.5 setup. But I'm just curious to see what others may have used on the front of the car.
Thanks!
:: Serpent America ::Desoto Racing :: Track Star Racer Services ::Skyrocket Racing::TOP::
Timmie is offline   Reply With Quote
Old 03-23-2010, 04:23 AM   #3947
I used the same as in the rear that came with the car but I changed back to the original springs.
http://www.mikky32.com
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
mikky32 is offline   Reply With Quote
Old 03-23-2010, 05:49 AM   #3948
stiltskin's Avatar
Trader Rating: 99 (100%+)
Thanks!
Congrats Timmie. I knew it wouldn't take you long to dial it in, but 1 week is a little arrogant, don't you think? Hope to compare some asphalt setups with you this season.
Tony Rumple
Team EAM // Gravity RC
stiltskin is offline   Reply With Quote
Old 03-23-2010, 06:00 AM   #3949
can someone tell me what servo saver they are using? i got the kimbrough med but dosent seem tall enough. thanks
franc furter is offline   Reply With Quote
Old 03-23-2010, 06:28 AM   #3950
I use the TOP servo saver. Best I ever had.
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
Old 03-23-2010, 07:01 AM   #3951
stiltskin's Avatar
I'm using the kimbrough medium servo saver. You may have to space the servo out a little to get the clearance you need between the arm and servo case.
Tony Rumple
Old 03-23-2010, 07:29 AM   #3952
*SBH*'s Avatar
The motorplate support TC-PCH014RD are perfect for this. Buy 2
*SBH* is offline   Reply With Quote
Old 03-23-2010, 09:48 AM   #3953
gearhead1962's Avatar
Hey that's a really neat paint job! I like it, its different.
Now you need to wear a Karate Kid bandanna when you race and you'll be all set!
Thanks I will look into the bandanna maybe I can wax the drivers stand wile I am up there wax on wax off
gearhead1962 is offline   Reply With Quote
Old 03-23-2010, 10:42 AM   #3954
RC MARKET's Avatar
My Spur gear holder
T.O.P. Racing "Photon" 1/10 EP Touring Car-img_0003.jpg
RC MARKET is offline   Reply With Quote
Old 03-23-2010, 11:02 AM   #3955
stiltskin's Avatar
I mounted my servo using two of the motor mount braces. Instead of using a regular lock nut on the back of the servo saver, I used the Kimbrough medium saver with no holes. I drilled the hole where I wanted it and used a Corally M3 nut (part number COR79417) to keep the saver as close to the top deck as possible. Here's the pic to help explain.
I started doing that a few months ago. They work great.
T.O.P. Racing "Photon" 1/10 EP Touring Car-sany0679.jpg
Tony Rumple
Old 03-23-2010, 11:04 AM   #3956
Originally Posted by RC MARKET View Post
My Spur gear holder
Wow cool. Were can you get them?
Can it be anodized in red?
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
Old 03-23-2010, 11:09 AM   #3957
hi-tech-redneck's Avatar
Default i gotta have one of those!
man i,ve burned two spurs and dammaged the center pully replacing the spur once already,that would be great to have! is it in production yet? where do i buy!my only complaint on the car so far is that piece & the glued together front spool,both kinda depend on your ca skills
tularecountyrc.com/the chicken ranch/exeter hobbies/nor-cal hobbies,ripon raceway/hara tcx/losi 22/top photon vta/tekin/reedy/hpi racing/3racing/AT&T/much more/upgrade rc
hi-tech-redneck is offline   Reply With Quote
Old 03-23-2010, 12:33 PM   #3958
bigbank66's Avatar
Default Bigg Ups to T.O.P
E.J. its Henry....i would like to give a major shout to Evans an the Tops crew for commng out an showing much luv to speedworld....These guys were very helpful wit all of our home track fellas an gave up some great advice about the product...u guys put on a good race an i hope u come back soon...its good to see a company that really help the people....oh yeah we have some racers in sac!!!
bigbank66 is offline   Reply With Quote
Old 03-23-2010, 01:15 PM   #3959
RC MARKET's Avatar
Top ready release a alum. spur gear !
this is my before some months samples ,
wait moment to buy TOP product !!
Old 03-23-2010, 01:28 PM   #3960
ok cool. can't wait till it's there.
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
SEO by vBSEO 3.5.0
