Old 03-14-2010, 12:14 PM   #3871
Just got top car last week and raced it yesterday. I need set up for 17.5 carpet. Track size is about 80x30 using tekin and dou2 with sorex 32. The car has stock setup it seems to start out good but after 3mins the back end spins out
nitroguy408 is offline   Reply With Quote
Old 03-14-2010, 01:15 PM   #3872
Timmie's Avatar
Hi nitroguy,
Is your car the rubber edition? What traction additive are you using? If you have a good groove going at your track, I've noticed that Sorex will pick it up pretty quick on the tires and cause the car to get loose mid run. Especially if your running a tight layout. Look at the rear tires after it starts getting loose and see if they are caked up.
If you do have the rubber edition, the stock front springs are a little soft for higher bite carpet in my opinion. If you go up on your front springs, it should help keep the front end from hooking as hard and may be the fix for your car getting loose later in your run.
And get Solaris tires That might just be the best fix of all
:: Serpent America ::Desoto Racing :: Track Star Racer Services ::Skyrocket Racing::TOP::
Timmie is offline   Reply With Quote
Old 03-14-2010, 01:59 PM   #3873
I got the carpet kit and I use jack the gripper. Forgot to mention I tried the sweep exp 36 last nite and car was better.
Old 03-15-2010, 06:28 PM   #3874
Regional Moderator
mrrcguy's Avatar
Trader Rating: 25 (100%+)
Default TOP GUN SHOOTOUT EVENT FLIER
Get those Photons ready to rumble fellas!
The TOP GUN SHOOTOUT is coming!
Click the link below and then click the TOP GUN logo for all the info.
www.midamericarcraceway.com
T.O.P. Racing "Photon" 1/10 EP Touring Car-tgs-avitar.png
mrrcguy is offline   Reply With Quote
Old 03-15-2010, 06:48 PM   #3875
Timmie's Avatar
What pound springs do you have on your car? They may be too stiff depending on which came with your kit. You should try out the Solaris tires. I'm using them against other drivers locally that use Sorex, RP, Jaco etc and have been very successful with them. TQ and won most of the races I've been in. And for the cost and performance they can't be beat.
Old 03-15-2010, 06:50 PM   #3876
Timmie's Avatar
Cool... Arkansas..that's driving distance from me Sounds like fun.
Old 03-15-2010, 07:02 PM   #3877
Regional Moderator
mrrcguy's Avatar
Cool! I hope you make it. EJ and Michael are coming out all the way from California!
Old 03-15-2010, 07:04 PM   #3878
E.J. Evans's Avatar
Send a message via Yahoo to E.J. Evans
Michael (OD) and I will be there! I'm excited to finally see your facility Q.
T.O.P. Racing | APEX Hobbies | R1 | Solaris | NorCal Hobbies |
Solaris Racing Products (SRP) Solaris Spec Tires!
www.solarisrp.com | www.apexhobbies.com | www.topracingusa.com
E.J. Evans is offline   Reply With Quote
Old 03-15-2010, 07:13 PM   #3879
Timmie's Avatar
Already printed the directions from your site With EJ and Michael going that's even better What time does practice start on the 14th? 10AM like race days?
Oops never mind, I didn't read close enough...says 12 lol
Old 03-15-2010, 07:14 PM   #3880
Regional Moderator
mrrcguy's Avatar
Default Killer Set-Up for harsh conditions
The track in Memphis this past weekend was totally green. It was cold. It was drizzly. But my car was the business. Trampled the TQ by nearly a lap.
Here's the set-up. (This was with the 2.5 Lipo Chassis)
Old 03-15-2010, 07:18 PM   #3881
Regional Moderator
mrrcguy's Avatar
Ill have a ton going on that morning so practice will start at Noon. If there is a real large crowd I will leave practice open until 10pm. We have lights. Not great lighting but decent.
Old 03-15-2010, 07:32 PM   #3882
smoke81's Avatar
Send a message via AIM to smoke81 Send a message via Yahoo to smoke81
Can't wait!
Dustin Layne
smoke81 is offline   Reply With Quote
Old 03-15-2010, 08:59 PM   #3883
Timmie's Avatar
12 sounds good, lets me sleep in from the drive That's cool that your track has lights. If it gets too dark, I have flashlights
Old 03-15-2010, 09:17 PM   #3884
Mini-Mod's Avatar
Can I hitch a ride EJ?
E.Albano
Yokomo / Hobbywing / JConcepts / A Main Performance Hobbies / Solaris Racing Products / ProTek RC / Schelle / Boom RC / TNP (TopNotchPaints)
Mini-Mod is offline   Reply With Quote
Old 03-16-2010, 03:40 AM   #3885
Do you use medium or hard tires?
I ordered Medium Solaris because I used before the Sorex 32. They worked good on the car so now I'm going to use the Solaris to see what they do. They are cheaper.
When come the new black rims for the tires EJ?
http://www.mikky32.com
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
mikky32 is offline   Reply With Quote
SEO by vBSEO 3.5.0
