Old 02-09-2010, 05:24 AM   #3556
The Teacher's Avatar
Trader Rating: 47 (100%+)
Nice pic Schreff....when did Larry get long blond hair and a nice set of twins...
The Teacher is offline   Reply With Quote
Old 02-09-2010, 10:17 AM   #3557
Nova F1 Racer's Avatar
R/C Tech Charter Subscriber
Originally Posted by tallyrc View Post
my diff bolt was protruding well past my diff nut.. nearly an eigth of an inch.. using less beveled washers will only cause the nut to retreat.. i guess i could have used a thicker collar on the thrust side. funny even the cad drawing shows the tip of the bolt protruding.. the end of mine was shinny where it had been rubbing.. i see the blades are "out of stock". i must not be alone..
[QUOTE=Ron Goetter;6977190]If your still running the original 45mm dog bones and trying to run more then 1.5* of rear camber that's how there breaking. If you go to the 44.5mm pick up the CVD collars at the same time. They really help free up the dog bones.
QUOTE]
Ron is correct, either install the shorter dog bones or add 1.5mm to the rear will solve this.
This is DICK!!! And you're NOT!
RC Tech member #11
Aussie Rules Footy, Brisbane LIONS!!
[url]http://www.pitter-pat.com/[/url] for pet care needs in Northern Virginia
Nova F1 Racer is offline   Reply With Quote
Old 02-09-2010, 03:53 PM   #3558
tallyrc's Avatar
[QUOTE=Nova F1 Racer;6980425]
QUOTE]
I've got some v2 and v3 bones in steel and aluminum. Which are the short ones? From which points can the installed ones be measured? Thanks for all the good info guys.
WWW.STORMERHOBBIES.COM helping keep pan cars alive!
Turns out not where, but who your with that really matters... DMB
tallyrc is offline   Reply With Quote
Old 02-09-2010, 09:48 PM   #3559
olhipster1's Avatar
Trader Rating: 94 (100%+)
Send a message via Yahoo to olhipster1
Default Shave and Cut
Is it me or does it seem like Schreff went down to the 'Birds
with a new hair dew (cut) and shaved....
seems like someone knew he was going to be taking pics with the girls!!!!
20 oz steak is due to the winner.....lot'so Oniooanss...
Congrats to the Top Team ...well deserved
Congrats to the Goat...time for a TOP shirt. wealth of knowledge
everything is Cause and effect
every Action has a reaction.
"I drank too much wine - I must take a p!ss"
CAUSE and EFFECT
olhipster1 is offline   Reply With Quote
Old 02-10-2010, 04:43 AM   #3560
pmc
hello
which is the difference in using this parts camber link plate 1.25 mm or 2.5 mm?
has some benefit in the behavior of the car?
Best regards:
Pedro silva
pmc is offline   Reply With Quote
Old 02-10-2010, 05:04 AM   #3561
[QUOTE=tallyrc;6981988]
T.O.P Racing Products 44.5mm Aluminum Universal Shaft Set (Red) (2)
[TRP-PO-SDT027RD]
http://www.amainhobbies.com/product_...haft-Set-Red-2
or just the shaft
http://www.amainhobbies.com/product_...sal-Bone-Red-1
These are the ones I was tslking about.
RC Tech member #11
Old 02-10-2010, 03:05 PM   #3562
BagofSkill's Avatar
Is there a place where we can find out about the latest option parts that are coming out?
I see there is a new 'black' layshaft that looks like it has something at the end, maybe to key it in to the supports?
And there are are few other things... What's the difference between the Ally and Ti Axle pin holders? Is there much in the weight? Are there any strength issues with the Ally?
Where are the resources for this stuff?
BagofSkill is offline   Reply With Quote
Old 02-10-2010, 09:10 PM   #3563
cliferton's Avatar
Trader Rating: 21 (100%+)
Anyone got a used photon to let go of? I am in need of a second class car, but with limited funds getting all the equipment needed leaves buying a new kit out for me. LMK
Forget the small things I'm just here to wheel!!!!
Part of the tripod
cliferton is offline   Reply With Quote
Old 02-11-2010, 10:06 AM   #3564
You break another chassis in half again Clif?
Dondor is offline   Reply With Quote
Old 02-11-2010, 01:15 PM   #3565
RC MARKET's Avatar
Last shipment Rubber Kit had updated Centre pulley shaft !
RC MARKET is offline   Reply With Quote
Old 02-11-2010, 02:11 PM   #3566
What is changed on the center pulley shaft?
http://www.mikky32.com
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
mikky32 is offline   Reply With Quote
Old 02-11-2010, 06:27 PM   #3567
cliferton's Avatar
What you doing pokin round the top thread for thomas? Looking for an UPGRADE??
Part of the tripod
Old 02-11-2010, 07:18 PM   #3568
Actually what I should do is get away from Red or Orange and get something else different. Like that pink car.
Wait that wouldn't work either.. Justin likes pink.
You guys smoke me bad this year... and I will start looking at it.
Old 02-11-2010, 10:05 PM   #3569
RC MARKET's Avatar
Yes !
Old 02-11-2010, 11:57 PM   #3570
Yes !
he asked what is the difference.
or may be someone from the TOP team can explain what is the new center pulley shaft?
TOP Racing
krat is offline   Reply With Quote
