Old 02-06-2010, 08:27 AM   #3526
smoke81's Avatar
Send a message via AIM to smoke81 Send a message via Yahoo to smoke81
Originally Posted by racer x 1 View Post
ive heard that the spec r ones will fit, can anyone confirm this?
Those are the same as the Atomic shafts.
Dustin Layne
smoke81 is offline   Reply With Quote
Old 02-06-2010, 11:00 PM   #3527
racer x 1's Avatar
Trader Rating: 27 (100%+)
im just looking for the easiest ones to modify for my car so what will i need to do to get them to fit properly? anything major?
Matt Bell
Mugen MRX5 Ae R5.2 X6^3 M11x All powered by Speedtech Rc
racer x 1 is offline   Reply With Quote
Old 02-07-2010, 05:56 AM   #3528
AdamD's Avatar
You will need to dremel out the c-hub and remove some material on the hex. Use the inner bearing that is provided with the cvd set. I would also make sure you locktite all the set screws and place heat sink tubing when your done. Just a side note, the pins and barrows are unique to these cvd's. If you loose a pin you will have to source it out yourself. They only sell complete sets. Hope this helps
AJ DiPirro
T.O.P. Racing U.S.A. / Serpent America / EA Motorsports / Team Epic / Trinity
P3 Graphics / RC3 Grafix / Adco Paving Inc / Team Butter
AdamD is offline   Reply With Quote
Old 02-07-2010, 02:47 PM   #3529
Trader Rating: 21 (100%+)
Speedtech is showing a replacement coupler and pin kit for the DCJ's.
Thanks to pops
TLR, Fantom, Horizon, Spektrum, Trackside
Brian L is offline   Reply With Quote
Old 02-07-2010, 06:28 PM   #3530
stiltskin's Avatar
Trader Rating: 102 (100%+)
I know that alot of people question the durability of a car so I thought I'd give an update on the Photon. I bounce off enough stuff during the day, just trying to steal that extra inch or two from the line. This week I went through the car and found some interesting stuff. I had bent a screw on the front arm pin holder. Arm was still good. I also suffered from a broken rear hinge pin, but once again the arm was still good. I've had the car for about 5 months now and still haven't broken any plastic pieces. (minus one steering bellcrank without a servo saver) Great performance and very durable car. Doesn't hurt that it costs $100 less than the other high performance cars on the market.
Tony Rumple
Team EAM // Gravity RC
stiltskin is offline   Reply With Quote
Old 02-08-2010, 02:47 AM   #3531
marcel p's Avatar
Send a message via MSN to marcel p
strange?
nobody here is mentioning the breaking of arms.
only hinge pins i think.
PR racing
Powerstar/futaba 4px
Absima /vr racing
marcel p is offline   Reply With Quote
Old 02-08-2010, 04:42 AM   #3532
Originally Posted by marcel p View Post
strange?
I broke 2 arms yesterday
Just bad luck. An Xray driver told me that Xray is stronger and the next head he drove he broke his arm
I have had the Xray and I can say the TOP is strong.
The C hubs I didn't brake wile I broke several Xrays C hubs.
I have broken only 1 steering block and 1 rear arm.
The rear arm was because an other driver drove in tom me from the side.
http://www.mikky32.com
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
mikky32 is offline   Reply With Quote
Old 02-08-2010, 05:35 AM   #3533
About C-joint blade, it looks promising, strong, very thick, and the wear is minimal.
BUT
it was getting wider and suddenly missing during a run (yeah it is my fault, i forgot to replace it although i knew it would snap off), damaged my red diff outdrive.
do you guys suffer the same problem (c blade getting wider)?
TOP Racing
krat is offline   Reply With Quote
Old 02-08-2010, 06:07 AM   #3534
Sal Amato's Avatar
R/C Tech Charter Subscriber
Trader Rating: 26 (100%+)
Although the durabilty is really good on these parts check out what I just came across http://www.redrc.net/2010/02/t-o-p-p...bs/#more-27823
360 RC SPEEDWAY 2.0
AWESOMATIX USA-SANWA--BSR--TEAM SCREAM --SWEEP RACING USA--TQ WIRE--ROCHE USA--LRP
Sal Amato is offline   Reply With Quote
Old 02-08-2010, 07:24 AM   #3535
Anyone know if there is going to be any updates on the steering bellcrank in alu. i am getting pretty tired of changing these now and yes i am running the kimbrough servo saver
*Sanwa M12*Hitec*
*TLR Eight 3.0*Fusion X3LFM*
Team_Elli is offline   Reply With Quote
Old 02-08-2010, 07:30 AM   #3536
racer x 1's Avatar
lol I broke one! butt then again full speed down the straight and pushing out in the sweeper after the straight will do that. i will say that it was one hall of a hit and im honestly surprised that nothing else broke on the car consider its was 13.5 with a tekin. i love this car!!!!!!!!!!!!
Matt Bell
Old 02-08-2010, 07:44 AM   #3537
I never broke a bell crank. I use the TOP servo saver. Best I ever had.
I drive also a Tekin with a 10,5T
No car can survive these collisions.
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
Old 02-08-2010, 08:35 AM   #3538
marcel p's Avatar
i broke few arms, rear weel blocks and hinge pins
6 front arms ,3 rear arms, 2 weel blocks, 3 hinge pins.
2 beldcranks.
2 hard hits for the rest soft taps.
almost drove a jear with no problems but the last 4 weeks al of this
with my arp 1,5 jears no problems .
more britle as my arp or just bad luck
its just how you hit things.
some real hard hit you think its dead and you just drove off
PR racing
Absima /vr racing
Old 02-08-2010, 09:34 AM   #3539
stiltskin's Avatar
strange?
I wasn't trying to imply that the arms were breaking. Quite the opposite. I was surprised that a metal hinge pin would break and the arm survived.
Tony Rumple
Old 02-08-2010, 10:28 AM   #3540
hey guys new to the photon, do the longer axles go in the back or the front?
Originally Posted by mikky32 View Post
Longer in the front
So are these the newest versions for the front?
T.O.P. Racing "Photon" 1/10 EP Touring Car-trp-po-sdt021rd_1-1-.jpg
James "Nel" Nelson
SpeedWorld Raceway & Hobbies | DesotoRacing.com | R1 Wurks
neltime64 is offline   Reply With Quote
