Old 12-30-2009, 05:25 AM   #3226
schreff's Avatar
Send a message via AIM to schreff
Originally Posted by Chris Furman View Post
So thinking about buying a Photon for Indoor Carpet only. Which one should I get and why?
Also what parts should I invest in other than the obvious arms and caster blocks?
If you're talking carpet only... I would suggest getting the foam kit. Reason being is that all of us have been using the foam car carbon pieces to run rubber tire. In fact, my 13.5 dedicated car is using the 3mm foam chassis plate, not the 2.5mm lipo, and the car has been awesome.
All you would need, in addition to the kit, is springs (393gm, 367gm, 306gm, and 289gm) and a spool. It's a lot cheaper going this route than buying the rubber car and getting the foam carbon parts (chassis and top deck), but to each his own. Either way will work.
The parts I usually break when I clobber stuff are caster blocks and steering blocks. You might want to get some rear hubs too, but if you put a set screw in the hole that's not used, you shouldn't have any problems.
-Jason Schreffler-
TLR|Horizon Hobby|Spektrum|AKA|Team CRC|CR Graphics|TQ Wire|Radio Impound Podcast
schreff is offline   Reply With Quote
Old 12-30-2009, 05:43 AM   #3227
Gianni's Avatar
Hi
I broke the steering bellcrank
I prepared it an aluminium steering bellcrank single AUDI A4 aluminium from the arm of suspension
easy and unbreakable
T.O.P. Racing "Photon" 1/10 EP Touring Car-p9080004.jpg   T.O.P. Racing "Photon" 1/10 EP Touring Car-p9090010.jpg
Gianni is offline   Reply With Quote
Old 12-30-2009, 06:13 AM   #3228
Did you use a servo saver when you broke it?
With that what you made now I will use a servo saver because els you damage your servo.
http://www.mikky32.com
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
mikky32 is offline   Reply With Quote
Old 12-30-2009, 06:19 AM   #3229
Gianni's Avatar
Christmas cup
my car on the start grid the 4.
ww.youtube.com/watch?v=ubo0Na_nWP0
Old 12-30-2009, 06:24 AM   #3230
Gianni's Avatar
no used servo saver but already installed the new Kimbrough
Old 12-30-2009, 06:35 AM   #3231
Gianni's Avatar
Originally Posted by Gianni View Post
Christmas cup
http://www.youtube.com/watch?v=ubo0Na_nWP0
Old 12-30-2009, 07:28 AM   #3232
Rick Vessell's Avatar
Originally Posted by wayne breault View Post
Can any of the team drivers explaine how to balence a ProTon from side to side? I was told to put 2 strings in both ends of the shock towers, so I did that, put my weight on the car and when I lift the car by the strings looked balenced but how can I be sure, I know the car was properly designed to be balanced without buying 4 corner scales. I keep on asking this question and nobody has really answered the question, they tell me to put the string on put not how to be sure its balanced. Thanks
It's easy, lift the car off the table fully loaded with wrenches or string. SLOWLY lower the car back down until the tires start to touch. If one side touches before the other, add/move weight to the lighter side. I did my car this way, simple!
Rick Vessell is offline   Reply With Quote
Old 12-30-2009, 07:31 AM   #3233
Originally Posted by L.Fairtrace View Post
I'm not saying its a bad thing just saying it isn't absolutely necessary to have a good car.
Originally Posted by schreff View Post
I'm with Larry on this one too. I haven't balanced a car either. In fact, just a few weeks ago, Mike Hanulec had a scale setup to check his T3 since it was freshly built. I put my car on just to see it if was way off... and to my surprise was dead on the money. This is with the weight tray full of lead (about 63 grams) and 21 grams of lead spread up the center of the car. If most of you have the weight setup that way, you should be fine.
Are you two still planning to attend the Novak? I'm hoping to make it myself.
Old 12-30-2009, 07:35 AM   #3234
schreff's Avatar
Hey Rick... We never really planned to go to the Novak. At this point, we're just getting into doing testing with the new Tekin software for 13.5 and getting some track time with Mod for Snowbirds. We have a lot to learn with all this wonderful HP.
-Jason Schreffler-
Old 12-30-2009, 07:43 AM   #3235
seaball's Avatar
R/C Tech Charter Subscriber
Send a message via Yahoo to seaball
schreffticles!
*** The Gate II - Home of Mike Wise ***
seaball is offline   Reply With Quote
Old 12-30-2009, 09:26 AM   #3236
Gotcha, I'm needing the track time myself. Mod should be fun with all of us 'regular' guys running it this year.
Old 12-30-2009, 12:05 PM   #3237
stiltskin's Avatar
Trader Rating: 102 (100%+)
The parts I usually break when I clobber stuff.
What do you mean YOU clobber stuff?
Tony Rumple
Team EAM // Gravity RC
stiltskin is offline   Reply With Quote
Old 12-30-2009, 12:19 PM   #3238
Ron Goetter's Avatar
Trader Rating: 17 (95%+)
Send a message via AIM to Ron Goetter
see 1:35 for an example http://www.youtube.com/watch?v=7ccbEh4LopI
The Goat... B-Mainer Fo' life
-Awesomatix USA-ROCHE USA-Team CRC-ORCA-SIDE PIECE RACING-TEAM DAK-EA Motorsports-VP Fuel-Trains and Lanes-CR Graphics-TQ Wire-Horsham RC-rugburn anyone?
Shut up and Race!!!!
Ron Goetter is offline   Reply With Quote
Old 12-30-2009, 12:25 PM   #3239
morris's Avatar
Trader Rating: 40 (100%+)
Originally Posted by Ron Goetter View Post
i love it...not schreff piping it but the racing.
AE/VIPER/XPERT/DIRTCHEAPRC.COM/JCONCEPTS
A big thx to all the tracks that I race at:cause if it wasnt for these guys..we wouldnt have a place to race our r/c cars!!!
morris is offline   Reply With Quote
Old 12-30-2009, 12:40 PM   #3240
stiltskin's Avatar
Thanks for bringing him back to mortality.
Tony Rumple
