Old 12-24-2009, 09:14 PM   #3136
smilekt's Avatar
Originally Posted by MikeHansen View Post
Hey Guys.
I'm a Danish Photon driver, and i've ordered the foam wings for my rubber Photon.
Has anyone tried these on a rubber Photon?
And how does it work?
My purpose with these wings, is to stiffen up the whole chassis. I've had some problems with grib-roll, on high traction tracks, and thought it might come from the soft chassis.
can use foam wing to stiff ur chassis .. very good for high grip traction
smilekt is offline   Reply With Quote
Old 12-24-2009, 09:14 PM   #3137
smilekt's Avatar
Originally Posted by rosko View Post
center pulley bearings are 5x10x4mm the rest are correct
correct
Old 12-26-2009, 06:08 AM   #3138
totally agree with that one. I used them at the ETS in Europe with rubber on high traction carpet and they gave me alot of cornerspeed through the entire corner rather than griproll. very effective. especially in combination with the Higher rollcenters and even the medium topdeck. worked very good for me
koney is offline   Reply With Quote
Old 12-26-2009, 12:48 PM   #3139
Exclamation Photon gear ratio
Hi peeps. I'm over here in europe and bought a photon to run in a series that allows the lrp 17.5T motor (brushless). carpet mit lrp vtec cpx tires. can anyone help me out with a gearing starting point (what pinion & spur gear??)
the race is next weekend and the car is on the way in the mail. I have some 48 pitch pinions and spur gears (zenon) from my Serpent S400. I think the car comes with 64 pitch spur but I don't have any of those pinions. i want to get the most out of that motor cause the track has a long straight, not very tight and I'm running lipos. thanks in advance for any help!
expatriate is offline   Reply With Quote
Old 12-26-2009, 03:56 PM   #3140
70/28 would be exactly 5.0
I think you mean the lrp-hpi-challenge?
Lutz is offline   Reply With Quote
Old 12-27-2009, 04:21 AM   #3141
Hey guys, Just moved over from a 008/009 to the Photon and was wondering about the camber links. Can somebody explain how a higher camber link affects the handling ?
I understand short/long and angled, but what does raising the whole link do ?
say 2.5mm (on the plate) and 2mm at the hub vs 4.5mm on the plate and 4mm at the hub.
Chris
CPD Racing
chris_dono is offline   Reply With Quote
Old 12-27-2009, 07:36 AM   #3142
Goingfast's Avatar
Trader Rating: 29 (100%+)
Chris
If you added more shims on the plate side ,it increase more low roll center...
Everybody is ignorant, only on different subjects.
AE 12R5.1,Tekin RS PRO
17.5 super stock T.O.P PHOTON , TAMIYA M05 Mini
CEFX.. High Velocity Racing Motor
Goingfast is offline   Reply With Quote
Old 12-27-2009, 11:44 AM   #3143
Has anyone tried fitting dcj drive shafts to the photon! If so could you run down how you did it and what parts are needed
bigdog is offline   Reply With Quote
Old 12-27-2009, 04:45 PM   #3144
sprintcarracer's Avatar
Trader Rating: 25 (100%+)
I am looking at buy this car for foam TC super stock racing. Can anyone tell me what makes this car better than the new T3 by Xray.
sprintcarracer is offline   Reply With Quote
Old 12-27-2009, 04:56 PM   #3145
adamge's Avatar
It's not really possible to say one is better than the other, in my opinion. However, to make the kits equal from a contents perspective, you'll need to add your own servo saver, shock oil, diff lube, and thrust bearing lube to the Photon kit.
When someone is intent on excelling in an otherwise laudable manner, does he not desire to inflict pain on others by means of his exalted status and enjoy the envy he arouses? Is there not an anticipated delight in an artist's ability to defeat his artistic rivals, which heightens his euphoria in creation?
-Nietzsche
adamge is offline   Reply With Quote
Old 12-27-2009, 05:02 PM   #3146
I guess my biggest questions is how strong are the palstic parts. Are they compairable to xray or are they as brittle as a corally steering block. Next are they easy to tune, how well do they responed to change and what is the fit and finsih like.
Old 12-27-2009, 05:04 PM   #3147
LOW ET's Avatar
Trader Rating: 96 (100%+)
perfect!
honestly, this is the BEST kit i've built so far.
LOW ET is online now   Reply With Quote
Old 12-27-2009, 05:31 PM   #3148
rosko's Avatar
i just got rid of my 009 and wanted to try the photon and as far as durability the photon is a tank as well as the 009. both cars are very good handling cars, but i think they feel different, i think the xray feels a tap bit more aggressive and very stable. the photon feels very smooth and easy to drive with really good corner speed as well as the xray. both cars are very close but i would give the nod to the photon just because i think its smoother and easier to drive for me anyway, but i have to say the xray 008/009 is a beast.
havent tried a t3 but i saw or8ital's at the track today and the car looked really really good.
rosko is offline   Reply With Quote
Old 12-27-2009, 05:35 PM   #3149
Thanks Rosko. I think im sold on the Photon.
Old 12-27-2009, 05:36 PM   #3150
jkirkwood's Avatar
BRANDINI's Photon, Losi, 009, Corally all have looked good.
SMC Racing | AKA Products | SANWA
jkirkwood is offline   Reply With Quote
