Old 12-23-2009, 06:11 PM   #3121
kschu's Avatar
Trader Rating: 16 (100%+)
Send a message via MSN to kschu
Originally Posted by rosko View Post
3mm diff balls
thrust balls are 1.58mm
is it 1.58mm = 1/16" ??
Give the best while u can !
kschu is offline   Reply With Quote
Old 12-23-2009, 06:20 PM   #3122
LOW ET's Avatar
Trader Rating: 94 (100%+)
if this is a serious question,
1.58mm = 0.0622"
1/16" = 0.0625"
LOW ET is offline   Reply With Quote
Old 12-23-2009, 09:11 PM   #3123
smoke81's Avatar
Send a message via AIM to smoke81 Send a message via Yahoo to smoke81
Mrrcguy told me about the lightened irs diff rings.. They are the bomb
Dustin Layne
smoke81 is offline   Reply With Quote
Old 12-23-2009, 09:57 PM   #3124
eflite300 is offline   Reply With Quote
Old 12-23-2009, 09:59 PM   #3125
Originally Posted by LOW ET View Post
i thought i read somewhere that irs diff rings will fit the diff. anyone have a part # on what diff rings they're using?
also, when is top's online store going to be up and running?
The ones that are not lightened is DB4015(bmi number) they work as well if you can't find the lightened ones
Old 12-23-2009, 10:22 PM   #3126
smoke81's Avatar
The lightened ones work well mainly because they are flatter. Smooth them out in no time .
Dustin Layne
Old 12-23-2009, 10:57 PM   #3127
I have been using the Db4015 because that is alll the LHS had, it takes about 5 mins pre ring to get them sanded
Old 12-23-2009, 11:06 PM   #3128
Gianni's Avatar
1.58mm = 0.0622"
1/16" = 0.0625"
Hi
my photon 1/16 Muchmore Ceramic thrust balls and Muchmore 3mm Ceramic diffballs and very good the differential
Gianni is offline   Reply With Quote
Old 12-23-2009, 11:28 PM   #3129
P2
P2's Avatar
Trader Rating: 15 (100%+)
+1...been using the IRS lightened diff rings = smooth diff!!
TopRacingUSA | Team EPIC | Thunder Power | OD Racing
P2 is offline   Reply With Quote
Old 12-23-2009, 11:31 PM   #3130
kschu's Avatar
what is the diff between normal ring and lightened ring ???
weight or the smoothness quality ???
Old 12-23-2009, 11:35 PM   #3131
smoke81's Avatar
Not so much that I personaly noticed anything on the track... Its more they are just come closer to being true and flat straight out of the package(than the normal IRS rings). Your arm and fingers will think you
Dustin Layne
Old 12-24-2009, 02:23 AM   #3132
LOW ET's Avatar
regular diff ring: http://www.teamirsrc.com/irs511d.html
lite diff ring: http://www.teamirsrc.com/irs2511.html
Old 12-24-2009, 02:52 AM   #3133
kschu's Avatar
how u making them fit to your diff ??
Old 12-24-2009, 02:55 AM   #3134
LOW ET's Avatar
they go on just like normal
Old 12-24-2009, 04:50 AM   #3135
stiltskin's Avatar
Trader Rating: 101 (100%+)
At the top of the ring in the picture you can see the two notches that catch the flat side of the "D". They don't seat properly unless you rotate the ring to fall at that point.
Tony Rumple
Team EAM // Gravity RC
stiltskin is online now   Reply With Quote
