Old 12-21-2009, 06:16 PM   #3106
stiltskin's Avatar
Trader Rating: 99 (100%+)
Originally Posted by teogra View Post
Hi, you know if I needs use sway bars on carpet ( rubber tires ) with a foam kit..
I've got the rubber kit with the foam lipo chassis. I ran it with sway bars and it was very good. I ran it without the sway bars and it seemed to handle better, but the lap times were slower. I've put them back on.
Tony Rumple
Team EAM // Gravity RC
stiltskin is offline   Reply With Quote
Old 12-22-2009, 05:23 PM   #3107
stonedgti's Avatar
Trader Rating: 15 (100%+)
The new top deck screws are awesome. You can now crank the top deck on real tight without stripping the head.
BTW: Here a video of a Photon win. http://www.youtube.com/norcalhobbies.../1/rHpKOQYGWEs
Team Powers | ORCA | OD 12 Racing | NorCal Hobbies | JWerks | Sonic Racing | Team Gayzer | AYO Racing | Team Hastings | Uncle Larry Concepts | Moonlight Toys
stonedgti is offline   Reply With Quote
Old 12-22-2009, 09:57 PM   #3108
smilekt's Avatar
where can i get the screw .... ?
smilekt is offline   Reply With Quote
Old 12-23-2009, 12:41 AM   #3109
RC MARKET's Avatar
www.rcmarket.com.hk
RC MARKET is offline   Reply With Quote
Old 12-23-2009, 01:13 AM   #3110
stonedgti's Avatar
Or you can email or call Mike at TOP USA. They should have them in stock now.
Old 12-23-2009, 07:09 AM   #3111
kschu's Avatar
Trader Rating: 16 (100%+)
Send a message via MSN to kschu
something to share here...
Top Photon
anyone know the size of top photon bearing ??
5x10x4 for wheel ?
10x15x4 for diff ?
4x8x3 for center pulley ???
what size is the diff ball ??
wat size is the thrust ball ???
what else?
thanks
Give the best while u can !
kschu is offline   Reply With Quote
Old 12-23-2009, 08:40 AM   #3112
rosko's Avatar
3mm diff balls
thrust balls are 1.58mm
rosko is offline   Reply With Quote
Old 12-23-2009, 08:49 AM   #3113
rosko's Avatar
center pulley bearings are 5x10x4mm the rest are correct
Old 12-23-2009, 09:34 AM   #3114
LOW ET's Avatar
Trader Rating: 91 (100%+)
i thought i read somewhere that irs diff rings will fit the diff. anyone have a part # on what diff rings they're using?
also, when is top's online store going to be up and running?
LOW ET is offline   Reply With Quote
Old 12-23-2009, 09:55 AM   #3115
Default Foam Wings
Hey Guys.
I'm a Danish Photon driver, and i've ordered the foam wings for my rubber Photon.
Has anyone tried these on a rubber Photon?
And how does it work?
My purpose with these wings, is to stiffen up the whole chassis. I've had some problems with grib-roll, on high traction tracks, and thought it might come from the soft chassis.
MikeHansen is offline   Reply With Quote
Old 12-23-2009, 01:03 PM   #3116
Gianni's Avatar
Hi
use it H suspension mount
Gianni is offline   Reply With Quote
Old 12-23-2009, 01:49 PM   #3117
Regional Moderator
mrrcguy's Avatar
Trader Rating: 25 (100%+)
I am using the lightened IRS diff rings and they are a blessing! I dont have part # handy though.
mrrcguy is offline   Reply With Quote
Old 12-23-2009, 01:58 PM   #3118
LOW ET's Avatar
do you know if they're the large or small rings? they come in two sizes.
Old 12-23-2009, 02:04 PM   #3119
Regional Moderator
mrrcguy's Avatar
Ill get back to ya on that one.
Old 12-23-2009, 02:15 PM   #3120
LOW ET's Avatar
anyone using the top bolt in 5g weights? do they get threaded on or do you have to run the screw all the way through it and use a nut?
same with the center weight, thread on or screw/nut?
SEO by vBSEO 3.5.0
