Old 12-15-2009, 02:42 PM   #3016
Trader Rating: 80 (100%+)
Send a message via AIM to cpatel529 Send a message via Yahoo to cpatel529
Anyone have any pictures of their electronics mounted in their car? I am going to be using the following:
Motor: Team Epic/Trinity Nemesis 17.5
ESC: Orion/KO Propo Vortex
Servo: KO Propo 951
Battery: Trinity 5000 mA
Where are you mounting the personal transponder?
Also, can I get a link to to a medium bite asphalt setup? Was trying to find EJ's or Larry's setups but my search didnt provide any results.
Thanks! Look forward to getting my Photon in the next couple days.
Chi
Chirag Patel (San Diego, CA)
cpatel529 is offline   Reply With Quote
Old 12-15-2009, 03:24 PM   #3017
sosidge's Avatar
My layout - although I have the Lipo mounted differently now for balance, the electronics are all in the same basic place. The PT has had its ears cut off to fit in front of the cells.
Because I use the relatively big Much-More/Speed Passion ESC and a 1/10th servo, I have to mount the receiver on top of the servo. With your smaller equipment you might get it all on the lower deck.
Old 12-15-2009, 03:34 PM   #3018
here is my layout.
I placed the receiver on the battery site so I dont need much weight to balance the car.
With light weight body shell Im at 1340g
greets
T.O.P. Racing "Photon" 1/10 EP Touring Car-file.jpg
Lutz is offline   Reply With Quote
Old 12-15-2009, 04:14 PM   #3019
Send a message via AIM to goop
Servo: KO Propo 951
Chi
you know that the ko 951 is a 1/12 scale servo
Hurricane Motorsports
Team Trinity
TOP Racing - Gravity Rc - Contact tires - KO Propo - Competition Electronics
goop is offline   Reply With Quote
Old 12-15-2009, 04:17 PM   #3020
Its a 1/12 servo that Josh and others have used in the Photon due to its high torque, fast speeds, and small size. Josh used it at the Reedy Race. It was discussed earlier in this thread.
Chi
Old 12-15-2009, 04:24 PM   #3021
Chi
yes i know but if you crash alot i would not recommend that servo as the gears are not meant for that type of punishment
Team Trinity
Old 12-15-2009, 07:35 PM   #3022
kschu's Avatar
Trader Rating: 16 (100%+)
Send a message via MSN to kschu
Just wonder if anyone try the new option - Axle ring ?? do it work well in preventing the axle pin come loose??
Give the best while u can !
kschu is offline   Reply With Quote
Old 12-15-2009, 07:45 PM   #3023
stiltskin's Avatar
Trader Rating: 99 (100%+)
I haven't had any issues with stock. Is this a problem?
Tony Rumple
Team EAM // Gravity RC
stiltskin is offline   Reply With Quote
Old 12-15-2009, 07:45 PM   #3024
schreff's Avatar
Send a message via AIM to schreff
If you're talking about the red axle covers, Larry and I ran them this past weekend. If you're having any sort of trouble with pins falling out (which we didn't have to begin with), this will eliminate the possibility permanently.
-Jason Schreffler-
TLR|Horizon Hobby|Spektrum|AKA|Team CRC|CR Graphics|TQ Wire|Radio Impound Podcast
schreff is offline   Reply With Quote
Old 12-15-2009, 07:56 PM   #3025
kschu's Avatar
so this option only applicable for rear use??
Old 12-15-2009, 07:57 PM   #3026
rosko's Avatar
goop... i have'nt tried it yet just built it stock just to get a feel for it , i will try it tommorrow though.
rosko is offline   Reply With Quote
Old 12-15-2009, 08:10 PM   #3027
schreff's Avatar
That depends on if you're running the kit drive shafts front and rear. If you are, you can use the pin covers front and rear. There is even a little paper in the package making sure to notify the end user not to screw the top set screw into the steering block too far... or it will scrape the cover.
I personally only use them in the rear as I'm running the Atomic 416 LCD style shafts up front.
-Jason Schreffler-
Old 12-15-2009, 08:31 PM   #3028
stiltskin's Avatar
Who sells these?
Tony Rumple
Old 12-15-2009, 08:47 PM   #3029
schreff's Avatar
Originally Posted by stiltskin View Post
Who sells these?
http://store.hkshobby.com/product_in...oducts_id=6094
You can find them at RC Mart as well.
You do have to do a little work to make them properly fit though.
1. You have to use the 5x10x3 bearing they come with on the inside of the steering blocks.
2. You have to sand/dremel the back side of the hexes so that, once you clamp them down, the axle doesn't bind the bearings.
3. Shave the caster block out so that the axle can spin freely without hitting the caster block. This is something we always had to do on Losi blocks so it was nothing new to us.
The pins in these axles are pretty weak. A good shot will break them. It's best to find some 1.4mm metal steel rod to replace the crappy pins. We had to get 1.6mm rod and sand it down to fit, which has worked out great. Makes them much more reliable. We're also using Losi LCD shrink tubing to add a 2nd level of security for the pins not to fall out... even though they're locked in with a set screw.
-Jason Schreffler-
Old 12-15-2009, 08:48 PM   #3030
M-Technic's Avatar
Trader Rating: 15 (100%+)
Who sells these?
I've seen them over at www.speedtechrc.com
RCAmerica | Xray | Hudy | Radiopost | Speed Passion USA | Trinity | P3 Graphics
M-Technic is offline   Reply With Quote
SEO by vBSEO 3.5.0
