Old 12-12-2009, 04:58 PM   #3001
LOW ET's Avatar
Trader Rating: 95 (100%+)
Originally Posted by stiltskin View Post
His original setup is posted on page 164. Front spool: dash down two clicks forward. Rear diff: dash down two clicks back.
ok, i have that setup also. i wasn't sure if that's what he used on the halloween setup too.
LOW ET is offline   Reply With Quote
Old 12-12-2009, 07:14 PM   #3002
kschu's Avatar
Trader Rating: 16 (100%+)
Send a message via MSN to kschu
ROCHE TOP Photon spool on Ebay now
EBAY
Give the best while u can !
kschu is offline   Reply With Quote
Old 12-13-2009, 06:07 PM   #3003
Default bellcrank
Hi,
Does anyone know if TOP is making an aluminum steering bellcrank for the PHOTON or a tougher plastic one.This weekend there were four Photon and all suffered with broken bellcranks,and all the cars were equipped with servo savers.
grouchy is offline   Reply With Quote
Old 12-13-2009, 08:58 PM   #3004
rosko's Avatar
i broke one and another guy at the track and we both had servo savers. thats the only thing ive broken, seems to be the weak spot. the rest of the car seems very durable. be nice to see the 20t pulleys in aluminun also
rosko is offline   Reply With Quote
Old 12-13-2009, 09:06 PM   #3005
adamge's Avatar
Heavier and more expensive parts are your thing, eh?
When someone is intent on excelling in an otherwise laudable manner, does he not desire to inflict pain on others by means of his exalted status and enjoy the envy he arouses? Is there not an anticipated delight in an artist's ability to defeat his artistic rivals, which heightens his euphoria in creation?
-Nietzsche
adamge is offline   Reply With Quote
Old 12-13-2009, 10:09 PM   #3006
Regional Moderator
mrrcguy's Avatar
Trader Rating: 25 (100%+)
Originally Posted by grouchy View Post
Hi,
Check to make sure that the servo and the bell crank are not able to touch at any point of the throw. The stock bell crank is plenty durable if the build is correct. I have three Photons all with the stock and original bell cranks. I have probably 350 packs on the cars as a whole running both carpet and asphalt and have not experienced one bell crank failure.
mrrcguy is offline   Reply With Quote
Old 12-14-2009, 01:19 AM   #3007
CraigM's Avatar
Trader Rating: 34 (100%+)
Run a kimbrough or TOP servo saver too, whatever you are using might be too hard and causing the breakages
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 12-14-2009, 08:35 AM   #3008
Goingfast's Avatar
Trader Rating: 29 (100%+)
+1
Everybody is ignorant, only on different subjects.
AE 12R5.1,Tekin RS PRO
17.5 super stock T.O.P PHOTON , TAMIYA M05 Mini
CEFX.. High Velocity Racing Motor
Goingfast is offline   Reply With Quote
Old 12-14-2009, 09:19 AM   #3009
Q you dont experience any failures because you fail to hit things like the rest of us mortals do.
Dondor is offline   Reply With Quote
Old 12-14-2009, 02:24 PM   #3010
rosko's Avatar
i welcome option parts just not new kits every year
Old 12-14-2009, 02:49 PM   #3011
Regional Moderator
mrrcguy's Avatar
I think you are giving me way to much credit on that one Thomas. But you have only seen me run asphalt so that may explain it.
Thanks though.
Old 12-14-2009, 03:50 PM   #3012
schreff's Avatar
Send a message via AIM to schreff
Originally Posted by CraigM View Post
+1
Make sure you're using the Kimbrough 201 servo saver. It's the mid size one that has different adapters for each servo type.
-Jason Schreffler-
TLR|Horizon Hobby|Spektrum|AKA|Team CRC|CR Graphics|TQ Wire|Radio Impound Podcast
schreff is offline   Reply With Quote
Old 12-15-2009, 04:00 AM   #3013
Default Gamma and Beta Springs
Hi guys,
I am running the asphalt version and my lhs has run out of the gamma springs for rubber kits... what is left are all beta foam springs...
a question: what are the differences between these springs and the handling characteristics... can i try foam springs on rubber setup and if yes, what can i expect the handling to be different from using rubber springs? my guess is that the difference will be minimal but i might be wrong...
katze is offline   Reply With Quote
Old 12-15-2009, 10:55 AM   #3014
rosko's Avatar
this car kind of fells like a corally phi on the track but better very impressed with this car.(running foams).
Old 12-15-2009, 12:34 PM   #3015
Send a message via AIM to goop
how was that setup i sent you
Hurricane Motorsports
Team Trinity
TOP Racing - Gravity Rc - Contact tires - KO Propo - Competition Electronics
goop is offline   Reply With Quote
