Old 04-28-2009, 11:12 AM   #286
RC MARKET's Avatar
T.O.P. Racing "Photon" 1/10 EP Touring Car-rx8intoptc.jpg
RC MARKET is offline   Reply With Quote
Old 04-28-2009, 11:37 AM   #287
Regional Moderator
mrrcguy's Avatar
Trader Rating: 25 (100%+)
Originally Posted by i am cornholio View Post
the tc5 does come with aluminum diff though...
Oh, ok.
mrrcguy is offline   Reply With Quote
Old 04-28-2009, 01:51 PM   #288
Originally Posted by RC MARKET View Post
The TOP with a Tekin RX8 speedo and redline motor.
That's a fast combination.
I love it.
http://www.mikky32.com
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
mikky32 is offline   Reply With Quote
Old 04-28-2009, 02:11 PM   #289
well i hope it is better than the ARP
seams this one of mine just wont go around lefts !!!
right from it being built it had this problem !!!
no one can help so back to the TRF415 !!!
needs sorting or i will sell it on !!!
the set up is identical as the one on TOP racing USA but still not good !!!
sidecarphil1 is offline   Reply With Quote
Old 04-28-2009, 06:21 PM   #290
E.J. Evans's Avatar
Send a message via Yahoo to E.J. Evans
sidecarphil1, shoot me an email at [email protected] let's see if we can figure out what's wrong with your ARP.
EJ
T.O.P. Racing | APEX Hobbies | R1 | Solaris | NorCal Hobbies |
Solaris Racing Products (SRP) Solaris Spec Tires!
www.solarisrp.com | www.apexhobbies.com | www.topracingusa.com
E.J. Evans is offline   Reply With Quote
Old 04-28-2009, 11:07 PM   #291
decibels's Avatar
some problems can be caused by some issues when building!! first thing make sure all of your suspension arms move freely when shocks are not on. second make sure that all your shocks are equal in rebound. Third make sure that your stabiliser mounts are all equal and that when you put on the arm mount it moves freely as well. and last make sure the car is not tweaked. This means if your droop is set correct under the arms then if you lift up the front end from the center then both wheels should lift off equally. If not you need to adjust your rear springs to compensate. screw up one side and loosen the other slightly. Repeat this for the rear. When finished try car on the track!! if problems are fixed then happy racing. and if you notice your springs are wound very differently side to side then use this to help equal out the weight balance. when weight balance is correct then this should equal out the springs side to side. Also remember that your car after having big crashes will need to be rechecked again for tweak or just loosen and re-tighten your chassis. hope this is helpful.
Team Wave Speedies
Thunder power lipo's
flying fox rc
!!And an idiot with a controller!!
decibels is offline   Reply With Quote
Old 04-29-2009, 10:39 AM   #292
razzor's Avatar
This is essentially what the spec of the 2 chassis will be.
Foam Spec car.
Essentially this car has extra bracing to stiffen the chassis.
It has a 3mm chassis and 2.5mm top deck.
1.4mm stabiliser bars
Front shock spring 560gf/mm . 31.3 lb/in
Rear shock spring 306gf/mm . 17.1 lb/in
Front ball diff.
Rubber Spec car.
Does not use the stiffening posts as the Foam Spec car.
This chassis has a 2.5mm chassis and a 2mm top deck for more flex to generate traction.
1.2mm stabiliser bars.
Front shock spring 344gf/mm . 19.2 lb/in
Front spool.
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Old 04-29-2009, 11:30 AM   #293
RC MARKET's Avatar
I love it.
RX8 210 Amps ESC in Touring car !
i'm waitting shipment on touring car feel !
Old 04-29-2009, 12:14 PM   #294
XxRONNxX's Avatar
I love it.
Kevin Jelich (Reedy Race Open Champion) told me he ran that combo because it had the strong fan and it ran cooler.
XxRONNxX is offline   Reply With Quote
Old 04-29-2009, 12:56 PM   #295
RC MARKET's Avatar
Perfect
Old 04-29-2009, 03:11 PM   #296
A Tekin in a TOP. Best combo ever.
I drive a Tekin RS Pro in my TOP and it's going verry good.
Have tested today an other setup and i loved it.
Car is even better than last month. So i hope that i will beat my personal record.
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
Old 05-02-2009, 06:26 PM   #297
Ron Goetter's Avatar
Trader Rating: 17 (95%+)
Send a message via AIM to Ron Goetter
EJ YGPM
The Goat... B-Mainer Fo' life
-Awesomatix USA-ROCHE USA-Team CRC-ORCA-SIDE PIECE RACING-TEAM DAK-EA Motorsports-VP Fuel-Trains and Lanes-CR Graphics-TQ Wire-Horsham RC-rugburn anyone?
Shut up and Race!!!!
Ron Goetter is offline   Reply With Quote
Old 05-02-2009, 06:51 PM   #298
JamesReilly's Avatar
Trader Rating: 57 (100%+)
Hey Ron,
Is this better, LOL. I could ask the same of you, did you take a wrong turn at Albuquerque, Bugs?
Reilly Paint ([email protected])
JamesReilly is offline   Reply With Quote
Old 05-02-2009, 07:15 PM   #299
Vicko's Avatar
Trader Rating: 14 (100%+)
Yo MVP dose this mean u are leaving the house of Losi???
Vicko is offline   Reply With Quote
Old 05-02-2009, 07:22 PM   #300
Originally Posted by JamesReilly View Post
Hey Ron,
No comment......
