Old 12-06-2009, 03:37 PM   #2971
stiltskin's Avatar
Trader Rating: 102 (100%+)
Originally Posted by Sigearhead View Post
They are both soft just different shapes.
Thank you. That's what I was looking for.
Tony Rumple
Team EAM // Gravity RC
stiltskin is offline   Reply With Quote
Old 12-06-2009, 09:56 PM   #2972
RaceAce701's Avatar
Trader Rating: 84 (99%+)
who has a foam top deck and foam wing posts in stock
The Skid Marks -- 24 Heures Du Jackson 9/22-23/2011
"Go for broke or go home broke"
"If it ant broke your not trying"
Alex "ACE" Kubilus
ACE design works
RaceAce701 is offline   Reply With Quote
Old 12-07-2009, 01:47 AM   #2973
I wanted to buy a kit but i see that almost all parts are back order at Amainhobby for more than 2 weeks. I really worry about the support for this car...:/ Can someone say me if there are a lack of parts for it or not? I live in france and get part for Us car is already a pain even if they are in stock so i dont want to spend tons of week waiting parts to run...
Last edited by CoCoLapin; 12-07-2009 at 02:23 AM. Reason: Try to correct my engrish
CoCoLapin is offline   Reply With Quote
Old 12-07-2009, 02:18 AM   #2974
test drove my photon over the weekend and i must say it is a very good car... in fact, it felt nicer than my xray....
josh and ej's setups were pretty good as baselines to work off from... i need not need too deviate much to find a setup i like...
overall, the car is freaking stable and planted.... the transition from corner to corner was smooth.... corner speed was amazing... i could hold my throttle a wee bit more in the corners... in summary, i had a pleasant driving experience....
katze is offline   Reply With Quote
Old 12-07-2009, 07:05 AM   #2975
MAD916's Avatar
We have the wings and post in stock, but sold all 3 of our top decks this weekend. Top USA is great and really trying to get on top of the parts issue. overwhelming sucsess has caught the factory by suprise. I will say everytime Michale has said the new parts or kit orders will be here... they have.
We got an overnight package from them delivered to another track this last friday so we could support the other Top drivers THANKS.... They are just experiencing some growing pains.....
By the Way I put the Foam Car on the 1st run of the podium at the NWIC Round #2 this weekend, my first down and out in two... what a great car...
Timezone Raceway Park " on-road outdoor european style road course.
Timezone II 60'x100' indoor carpet track. Host of the ROAR 2011 Carpet Nat's.
Timezonehobbies.com your new source for online RC products.
MAD916 is offline   Reply With Quote
Old 12-07-2009, 07:50 AM   #2976
darrenoakley's Avatar
Default Spool pulley
Originally Posted by stiltskin View Post
I haven't had any issues with the stock spool and plastic outdrives. They did come out with the steel outdrives that people seem to like. TiR has a titanium spool for use with the yokomo pulley and Rosche also has one anodized red. I'm looking to get the rosche spool myself.
I have fitted the TIR Titanium racing spool and used the Top one way pulley and it fits fine.
Well please with the spool quality.
Has anyone else had problems with rear hub M3 set screw for the ball stud stripping the plastic in the hub (2nd one). Probably me doing it up to much, I have now put a m3 grub screw in the spare hole hopefully this will help strengthen it as the two holes are quite close.
Great car though simple things to get over.
darrenoakley is offline   Reply With Quote
Old 12-07-2009, 04:27 PM   #2977
adamge's Avatar
darren, I have stripped the plastic threads in one rear hub so far. I'm not exactly sure how I caused that, other side hub and replacement hub have been fine so far.
When someone is intent on excelling in an otherwise laudable manner, does he not desire to inflict pain on others by means of his exalted status and enjoy the envy he arouses? Is there not an anticipated delight in an artist's ability to defeat his artistic rivals, which heightens his euphoria in creation?
-Nietzsche
adamge is offline   Reply With Quote
Old 12-07-2009, 05:49 PM   #2978
smoke81's Avatar
Send a message via AIM to smoke81 Send a message via Yahoo to smoke81
That should fix it for sure.
Dustin Layne
smoke81 is offline   Reply With Quote
Old 12-07-2009, 07:45 PM   #2979
odpurple's Avatar
Filling the empty hole with another set screw will really help the stripping problem. Remember to use as long a set screw as possible for the ball, the closer to bottoming out in the hole the better
odpurple is offline   Reply With Quote
Old 12-07-2009, 07:57 PM   #2980
RaceAce701's Avatar
i just put a long screw in and made sure it bottomed out and then cut the head off and slotted what was left so i can remove it easily.
i moved the ackram up to the furthest most hole and it made a big difference on turn in i finally got the car exsctly wear i want it
now i can start working on the foam car
Alex "ACE" Kubilus
ACE design works
Old 12-08-2009, 07:29 AM   #2981
Default Rear hub
Will try the set screw instead of grub screw.
Makes sense really.
Running 1.5Deg camber all round at the moment would it be worth going to 2Deg. (Rubber carpet) or stick with what i am at. Only been racing 5 months so still loads to learn. All comments welcome.
Old 12-08-2009, 08:16 AM   #2982
E.J. Evans's Avatar
Send a message via Yahoo to E.J. Evans
Makes sense really.
It depends on what your car is currently doing. If the rear is stepping out, then try going to 2 deg. Remember, when changing toe angles you will need to re-adjust camber.
T.O.P. Racing | APEX Hobbies | R1 | Solaris | NorCal Hobbies |
Solaris Racing Products (SRP) Solaris Spec Tires!
www.solarisrp.com | www.apexhobbies.com | www.topracingusa.com
E.J. Evans is offline   Reply With Quote
Old 12-08-2009, 09:58 AM   #2983
Not really stepping out just seems to dip at the front and go lose at the rear under braking and turning together. Have ordered some harder springs to try on the front.
Just really getting used to what all the adjustments do on this great car.
Old 12-08-2009, 02:19 PM   #2984
Sigearhead's Avatar
Trader Rating: 68 (100%+)
Does anyone know how much the center battery weight weighs?
Sigearhead is offline   Reply With Quote
Old 12-08-2009, 02:23 PM   #2985
30 grams
grouchy is offline   Reply With Quote
