Old 11-23-2009, 08:29 PM   #2881
Rod M's Avatar
Originally Posted by LOW ET View Post
anyone know how much this center lipo weight weighs?
just weighed one still in its packet,
approx 30-31g
TOPRACING.NET.AU Australian Importer of:
T.O.P. Tokyo Hobbies Optional Parts,
Team Trinity , BL Motors and Tyre compound
Team Tekin , ESC's, motors,
Elangears, Chargers,
Rod M is offline   Reply With Quote
Old 11-24-2009, 12:13 AM   #2882
sosidge's Avatar
Originally Posted by RaceAce701 View Post
im in the same boat when i run VTA the car just wont turn in it pushes horibly but it is great from the center off
even in stock rubber trim it pushes
(im running larry's setup but running cs 27's)
would a stiffer chassis and top deck help free the car up
From what I'm hearing the Larry Fairtrace setup does push a lot unless you are on super-high traction. Try the car with the kit setting.
Even I found that the kit setting lacks steering - a tweak to the steering crank by putting it on the longest setting sorts that out. The car is a pretty good basis to work from them.
If you are on a particularly tight or low-traction layout you might find that the front diff makes the car a bit easier to drive than the spool.
Old 11-24-2009, 01:17 AM   #2883
If anyone is interested in my IIC set-up I would be happy to post it. But, how do you get the set-up sheet on a PDF or I guess I can scan it in.
Juan Aveytia is offline   Reply With Quote
Old 11-24-2009, 03:56 AM   #2884
BagofSkill's Avatar
Anyone able to help on this?
Originally Posted by BagofSkill View Post
Can anyone tell me what (48dp) gearing will fit in the Photon? I need a big spur/small pinion arrangement to bring the ratio down to around 8.5. Anyone know what fits? Can anyone confirm is 93/22 will fit?
BagofSkill is offline   Reply With Quote
Old 11-24-2009, 05:46 AM   #2885
European official Photon forum.. Enjoy..
Http://www.top-racing-europe.eu/forum
Ryo Saeba is offline   Reply With Quote
Old 11-24-2009, 05:56 AM   #2886
adamge's Avatar
Hey Juan. Blank setup sheet attached.
File Type: pdf Photon Modifiable Setup Sheet Rev1.pdf (342.2 KB, 135 views)
When someone is intent on excelling in an otherwise laudable manner, does he not desire to inflict pain on others by means of his exalted status and enjoy the envy he arouses? Is there not an anticipated delight in an artist's ability to defeat his artistic rivals, which heightens his euphoria in creation?
-Nietzsche
adamge is offline   Reply With Quote
Old 11-24-2009, 06:13 AM   #2887
I use at the moment a 84 48P gear and the gear can a bit bigger but not much. it's in his highest position. I think 86 is the max.
The motor has still enough space to use a bigger pinion.
http://www.mikky32.com
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
mikky32 is offline   Reply With Quote
Old 11-24-2009, 09:00 AM   #2888
1evo RRR Driver's Avatar
Send a message via AIM to 1evo RRR Driver
Can anyone tell me where I can look at a T.O.P "scythe" manual? Thanks in advance
"He's CHEATIN! cause Im CHEATIN! and He beat ME!" :) "D815 PILOT" /FUSION X3LCFM / M2c / ko propo RSX / M11x / Novarossi
1evo RRR Driver is offline   Reply With Quote
Old 11-24-2009, 09:20 AM   #2889
sosidge's Avatar
http://muchmoreracing.com/downloads/...t_view/gid,19/
Old 11-24-2009, 05:49 PM   #2890
29TC's Avatar
Send a message via ICQ to 29TC
Default Shock Length
Hi guys, I just got the photon....while building the shocks, the manual does not indicate how long the shocks should be..
Can someone measure the overall shock length after fully built (top to bottom)?
Thanks in advance.
29TC is offline   Reply With Quote
Old 11-24-2009, 06:09 PM   #2891
stiltskin's Avatar
Trader Rating: 101 (100%+)
Thanks in advance.
Mine are 63.00 mm long from very top to very bottom.
Tony Rumple
Team EAM // Gravity RC
stiltskin is offline   Reply With Quote
Old 11-24-2009, 06:42 PM   #2892
kschu's Avatar
Trader Rating: 16 (100%+)
Send a message via MSN to kschu
Good news..
Roche Heavy Duty photon spool will be ready to ship by next monday...
contact me for more details...
thanks
Give the best while u can !
kschu is offline   Reply With Quote
Old 11-24-2009, 10:23 PM   #2893
Hello all,
I was looking to getting a 416X, but the price is getting too steep. With the exchange rate these days, the car is almost $600 shipped
Looking for a good alternative and my fellow racers recommended me the Photon. What are the weakpoints on this car that I need to stock spares on? I'm sure the Chub and knuckles are on that list, but any other known issues?
Also, where is a good place that sells the kit and spares at a reasonable price?
redbones is offline   Reply With Quote
Old 11-24-2009, 10:31 PM   #2894
AdamD's Avatar
Originally Posted by redbones View Post
Hello all,
Car is very durable. Beside all the normal parts. I would get a Bell crank and a medium servo saver. You can place a order at Topracingusa@yahoo.com or Amain hobbies. Goodluck
AJ DiPirro
T.O.P. Racing U.S.A. / Serpent America / EA Motorsports / Team Epic / Trinity
P3 Graphics / RC3 Grafix / Adco Paving Inc / Team Butter
AdamD is offline   Reply With Quote
Old 11-24-2009, 10:59 PM   #2895
Thanks for the info!
I was reading through the manual, and noticed a lot of innovative designs implemented for ease of maintenance. The steering did kind of worry me, with the absence of a servo saver. You guys use the Kimbrough mediums?
Seems like making the motor as centered as possible is a trend with the new kits coming out (T3, 416X). Where does the Photon place in this respect?
I guess those top deck screws are also on my list.
