Old 11-23-2009, 06:17 AM   #2866
Originally Posted by RC MARKET View Post
New screw
Is that the new screw for the top plate?
http://www.mikky32.com
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
mikky32 is offline   Reply With Quote
Old 11-23-2009, 06:35 AM   #2867
masher's Avatar
Hi Josh
Please explain to us why there are different springs for rubber and foam, surely a 16lbs spring is a 16lbs spring, also why the diameter difference?
Please... Thanks.
masher is offline   Reply With Quote
Old 11-23-2009, 11:03 AM   #2868
odpurple's Avatar
Yes, and they take a 2mm wrench-much better!
odpurple is offline   Reply With Quote
Old 11-23-2009, 11:29 AM   #2869
Great I want them. The ones I have now I must keep changing.
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
Old 11-23-2009, 12:07 PM   #2870
amnesia's Avatar
These are good replacements for the top deck screws...
http://www.titaniumracing.com/produc...660&menu_ID=50
.-= T.O.P. Photon =-.
Titanium Racing (Team TR Driver) / Tekin RS Pro / Novak Ballistic 13.5t / Spektrum
amnesia is offline   Reply With Quote
Old 11-23-2009, 01:09 PM   #2871
P2
P2's Avatar
Trader Rating: 15 (100%+)
Do you have any in stock????
TopRacingUSA | Team EPIC | Thunder Power | OD Racing
P2 is offline   Reply With Quote
Old 11-23-2009, 02:01 PM   #2872
odpurple's Avatar
EJ is flying in from Hong Kong with them, just for you
Old 11-23-2009, 02:02 PM   #2873
RC MARKET's Avatar
the new one is 2.6x7mm w/2mm hex
& support camber link plate !
RC MARKET is offline   Reply With Quote
Old 11-23-2009, 05:19 PM   #2874
I need help with a vta car setup. I run at msi racing in Detroit on carpet. I have a stock rubber chassis the only changes I have made are 45 oil in front and35 in rear shocks.
First of all with the stock springs the ride height is 5.5 and the rear is 6 without adding any preload to them.
Second I am not used to running a spool but it had a monster push to it.
I forgot that I am not running swaybars.
To try to make it turn in I layer the front shocks 2 holes and stood up the rears one. I also went to a 11 insert on the bell crank and pulled the silver spacer out of the toe setting in the rear.
Any help is appreciated
Chuck
Rough_necked is offline   Reply With Quote
Old 11-23-2009, 05:57 PM   #2875
Regional Moderator
mrrcguy's Avatar
Trader Rating: 25 (100%+)
Chuck
No problem Chuck. Visit www.tchub.info were you will find my VTA set-up which is for Asphalt but it also does quite well for low grip carpet. I am working on a set-up for medium grip but its not done yet.
About what you posted above... If you cant get proper ride height with the stock shocks and springs then you must have something assembled wrong. I am currently running the 367 springs in the front and the 289 rears. I have no issues running all the way down to 5mm or lower.
mrrcguy is offline   Reply With Quote
Old 11-23-2009, 06:19 PM   #2876
Any ideas where it could be built wrong or could it be that you are running the lower roll center that is giving more shock adjustability?
Old 11-23-2009, 06:33 PM   #2877
LOW ET's Avatar
Trader Rating: 95 (100%+)
anyone know how much this center lipo weight weighs? http://www.amainhobbies.com/product_...er-Lipo-Weight
on average, how much weight is everyone adding to make weight?
LOW ET is offline   Reply With Quote
Old 11-23-2009, 06:57 PM   #2878
adamge's Avatar
Crap, I weighed mine before putting it in the car and now forget the weight. I think it was 40g.
When someone is intent on excelling in an otherwise laudable manner, does he not desire to inflict pain on others by means of his exalted status and enjoy the envy he arouses? Is there not an anticipated delight in an artist's ability to defeat his artistic rivals, which heightens his euphoria in creation?
-Nietzsche
adamge is offline   Reply With Quote
Old 11-23-2009, 07:16 PM   #2879
Thirtybird's Avatar
Chuck
Chuck, now I guess I know who bought that other Photon that was in the case! If you're going to be there this (or any) Wednesday night, seek me out (I usually sit in the back of the track, front row, back to the track), Dark Red Camaro with the Gold #13 on the side. I'll be happy you share my Photon VTA setup for the track with you. I'm not sure why you are pushing, my car has more front end grip than you can shake a stick at.
Racing a Kawada SV-10 in 2010
http://omgitsakawada.blogspot.com/
The VTA Photon! (Inactive - back to the Kawada!)
http://vtaphoton.blogspot.com/
Thirtybird is offline   Reply With Quote
Old 11-23-2009, 08:17 PM   #2880
RaceAce701's Avatar
Trader Rating: 83 (99%+)
Chuck
im in the same boat when i run VTA the car just wont turn in it pushes horibly but it is great from the center off
even in stock rubber trim it pushes
(im running larry's setup but running cs 27's)
would a stiffer chassis and top deck help free the car up
The Skid Marks -- 24 Heures Du Jackson 9/22-23/2011
"Go for broke or go home broke"
"If it ant broke your not trying"
Alex "ACE" Kubilus
ACE design works
RaceAce701 is offline   Reply With Quote
