T.O.P. Racing "Photon" 1/10 EP Touring Car
#2821
This reminds me that I should really get around to building the Photon I picked up while over there. Sat in it's box for 3 weeks now.
#2822
I was in Hong Kong recently and I got to see Vincent's car with a prototype chassis that had the area where the motor sinks into the chassis completely removed as the partial cut out weakens the carbon fibre. I believe the next generation of the chassis will be like that so I don't like your chances of them doing that for the battery tape.
#2823
Which part do you not understand?
#2824
Isn't there too much flex if you cut out completely that part? It's like cutting the chassis in two.
Or there is someting like a bridge connecting the two parts?
#2825
You get a strange flex with so much cut out.
Are there more changes? What did they do on the other side to keep the chassis in balance?
Do you have photo's of it?
#2826
hi i'm new to the photon game i'm looking for a foam top deck
i went trough some shop and can't find it on stock do you know any shop having stock
#2827
There is a U shaped piece that bolts to the chassis that goes around the cut-out. The design provides equal flex from both sides of the chassis. Keep in mind that this is still a prototype
#2828
#2830
Whit no carbon on that place, you can lower the motor even more.
And as you see that 3mm is a big deal for Xray to move the motor more to the center, than this is also an improvement.
I'm now trying to make an other motor mount. I want to try to move my motor more to the center. Just like Xray. It's already very close to the center but I think that it can move an other 2 or 3mm.
Also will the mounting be lower just like Xray.
I will post some CAD pictures when the design is ready.
Maybe I also make some other inner bulkheads so I can mount my top plate with M3.
#2831
Last edited by sosidge; 11-19-2009 at 08:18 AM. Reason: Answered a post from 3 months ago by mistake
#2832
just thought i would show a pic of what ive done to my photon.
ps. flipping the top deck and wings upside down works a treat.
Attachment 521914 Attachment 521916
Is it whit tape mounted to the bottom plate?
Does it stay on his place after a hit?
#2835
Hi guys.
This weekend i was out racing, it was a great weekend with good racing, but i had a little problem, i had way too much grip, there were finals from A to E in the 17.5 rubber class, with 3 photons i the A-main and 2 in the B-main.
It was a photon that won , and became second, i was 6th, i copyed my set-up so it was like the winning car, used the same addhesive (the same bottle), and we race on control tyres.
I had grip roll problems, the two others didnt, the car was slow because of to much grip, we all run the rubber chassis, all stock from the box.
I have been thinking that my chassis is too soft?
Have you heard of such a problem??
And what chassis to bye for rubber carpet racing on medium grip tracks?
