Old 11-16-2009, 01:19 PM   #2791
Originally Posted by Team STPN View Post
Do you have any pics of that set up?
Not at the moment. I am out of town for work and wont be back for at least a week. Will try to get them up as soon as I get back. Turned out really well but I also use very small electronics ( Futaba 9550 servo, Tekin RS Pro, Mini spektrum receiver, Duo2). I even shorten qll my wires to minimize the weight on the left side. also run the TP 5000 40c lipo.
Schuurspeed / Aero-model / Gear One / LG1
www.OHRCR.com
Gitsum is offline   Reply With Quote
Old 11-16-2009, 01:21 PM   #2792
Trader Rating: 68 (100%+)
Originally Posted by mrrcguy View Post
The Photons put down some good runs in Dallas this weekend at the Fall Classic. Myself and Dustin Layne finished 2nd and 3rd in 17.5 Rubber, and 4th and ? in 13.5 Rubber.
Congrats to Chris Adams for the 17.5 win, and to Mike Dumas for the 13.5 win.
Good running with you Q,had a blast running with Dumas 1 mistake and that was it
SpeedZone Batteries
steve eaves is offline   Reply With Quote
Old 11-16-2009, 01:41 PM   #2793
Regional Moderator
mrrcguy's Avatar
Trader Rating: 25 (100%+)
Ya you put in some hella strong runs! See ya soon Im sure. By the way if you took any pics of the track would you please post them. I intended to but my memory card appears to be on the blink. I figure people would like to see that monster layout and giving Mikes a little exposure wouldnt hurt either.
mrrcguy is offline   Reply With Quote
Old 11-16-2009, 02:16 PM   #2794
Trader Rating: 40 (100%+)
Were you running the foam or rubber car? I'd be very interested in seeing your setup as I'm on the fence about which car to get foam or rubber for running rubber on carpet.
AndysD8 is offline   Reply With Quote
Old 11-16-2009, 02:23 PM   #2795
LOW ET's Avatar
Trader Rating: 95 (100%+)
just about everyone has a rubber car and there are a few foam cars out there now. most of the guys with the rubber cars have upgraded some parts to make it perform the way they want.
if you get a rubber kit you'll most likely get the foam lipo chassis, and foam top deck.
if you get a foam kit you'll most likely get the spool, rubber wings, and the foam lipo chassis.
now keep in mind none of these extra parts are mandatory but it make the car perform just that very little bit better.
if you're on the fence about what brand car to get, don't hesitate to get the photon it's like a work of art! (and i have very high standards)
LOW ET is offline   Reply With Quote
Old 11-16-2009, 02:39 PM   #2796
This is about the best answer I have seen yet! Definitely give consideration to what class or classes you will be running as well.
www.OHRCR.com
Old 11-16-2009, 03:07 PM   #2797
Regional Moderator
mrrcguy's Avatar
Uh, yep!
If you will run all high traction carpet with foam tires, get the foam car.
If you run a mixture of asphalt and carpet with rubber tires, get the rubber car.
Old 11-16-2009, 03:20 PM   #2798
Chris Adams's Avatar
Thanks Q!
TEXASEOS.net, RcAmerica, Xray, Hudy, Protoform, Orca, Avid, 2mm Designs
Texas EOS 2017!
Chris Adams is offline   Reply With Quote
Old 11-16-2009, 03:47 PM   #2799
theisgroup's Avatar
www.youtube.com/mikeshobbyshop if you are looking for videos of the mains. also get to see the layout
yang lai
Team Tamale | Team Tekin | RCAmerica | Speedmerchant | Speedzone RC | EA Motorsports | Ko Propo USA | eXpress Motorsports | Parma/PSE
theisgroup is offline   Reply With Quote
Old 11-16-2009, 03:51 PM   #2800
L.Fairtrace's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to L.Fairtrace
Why are there only 4 people in the main?
T.O.P Racing - Awesomatix USA - EaMotorsports - BSR Racing Tires - Orca - TQ Wire - Solaris Racing Tires - Side Piece Racing
Horsham RC. Where champions practice Failing. I'm your everything.....
L.Fairtrace is offline   Reply With Quote
Old 11-16-2009, 03:57 PM   #2801
theisgroup's Avatar
that was foam sedan. just starting back up in the south.
yang lai
Old 11-16-2009, 04:18 PM   #2802
Regional Moderator
mrrcguy's Avatar
The Foam sedan class just did not get a showing. 17.5 Rubber was weak also. But the 13.5 Rubber class was solid!
http://www.youtube.com/mikeshobbyshop#p/u/4/GAnnnpvclAI
Old 11-16-2009, 04:44 PM   #2803
Oh right on, the video just says Stock touring or whatever so I assumed it was rubber.
Old 11-16-2009, 04:53 PM   #2804
theisgroup's Avatar
you would have know if you would have come down.
Sir, you have an open invitation for the Fourth Annual Fall Classic. Same weekend next year.
yang lai
Old 11-16-2009, 05:50 PM   #2805
CarlosG.'s Avatar
Send a message via Yahoo to CarlosG.
Are you sure about that? I will make plans to go next year if it will be the same weekend.
CarlosG. is offline   Reply With Quote
