Old 11-14-2009, 06:36 PM   #2776
stiltskin's Avatar
Trader Rating: 101 (100%+)
Originally Posted by grouchy View Post
Hey Stiltskin,
Do you know a good FDR for a Tekin 13.5 in my rubber photon?
thank you
Depends on the size of your track. I was running about 4.37 on our 140x60 asphalt track with the Tekin RS. I haven't tried to find the right gearing on carpet yet. I may play around with it tomorrow and let you know what I come up with.
Tony Rumple
Team EAM // Gravity RC
stiltskin is offline   Reply With Quote
Old 11-14-2009, 06:40 PM   #2777
thank you
grouchy is offline   Reply With Quote
Old 11-15-2009, 05:07 AM   #2778
jeppesen's Avatar
When Fairtrace writes "2 up" in the droop box on a set-up sheet, what is it 2 up from??
Please PM me if there is a good idear behind.
Søren
jeppesen is offline   Reply With Quote
Old 11-15-2009, 05:24 AM   #2779
LOW ET's Avatar
Trader Rating: 94 (100%+)
Søren
up = up travel
i think he's setting droop like you would on a foam car.
LOW ET is offline   Reply With Quote
Old 11-15-2009, 05:36 AM   #2780
adamge's Avatar
Up from right height.
When someone is intent on excelling in an otherwise laudable manner, does he not desire to inflict pain on others by means of his exalted status and enjoy the envy he arouses? Is there not an anticipated delight in an artist's ability to defeat his artistic rivals, which heightens his euphoria in creation?
-Nietzsche
adamge is offline   Reply With Quote
Old 11-15-2009, 12:30 PM   #2781
haywood's Avatar
Trader Rating: 48 (100%+)
So if have have 4mm ride height he would be at 6 for droop?
Hobbywing / Team Scream / Progressive Rc / Ko Propo / MotivRc / Dri-Fit Mafia /
haywood is offline   Reply With Quote
Old 11-15-2009, 01:17 PM   #2782
stiltskin's Avatar
Measure your ride height. Let's say it's 5mm. Lift the chassis until the tires are just barely touching and measure your ride height at this point. The difference should be 2mm. It is known as uptravel, or the distance the chassis travels before the tires would come off the ground.
Tony Rumple
Old 11-15-2009, 01:48 PM   #2783
haywood's Avatar
Default Photon
What is the Photons internal gear ratio?
Old 11-15-2009, 01:54 PM   #2784
LOW ET's Avatar
2:1
Old 11-15-2009, 01:54 PM   #2785
marcel p's Avatar
Send a message via MSN to marcel p
[QUOTE=haywood;6602752]What is the Photons internal gear ratio?[/QUOTE
2.0 fdr
PR racing
Powerstar/futaba 4px
Absima /vr racing
marcel p is offline   Reply With Quote
Old 11-15-2009, 09:41 PM   #2786
kschu's Avatar
Trader Rating: 16 (100%+)
Send a message via MSN to kschu
hi, would like to ask. when you guys using the side weight brass set, will it rubbing on the track when cornering ???
Give the best while u can !
kschu is offline   Reply With Quote
Old 11-15-2009, 09:48 PM   #2787
L.Fairtrace's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to L.Fairtrace
Mine has not in any classes as of yet.
T.O.P Racing - Awesomatix USA - EaMotorsports - BSR Racing Tires - Orca - TQ Wire - Solaris Racing Tires - Side Piece Racing
Horsham RC. Where champions practice Failing. I'm your everything.....
L.Fairtrace is offline   Reply With Quote
Old 11-15-2009, 10:13 PM   #2788
+1 mine hasn't rubbed either. On a side note I was able to replace the middle weight with the long side weight. Placed it under the belt and moved all my extra weight from the electronics side to the battery side and balanced very nicely to 1440. Car feels dialed now!
LF...you have a pm
Schuurspeed / Aero-model / Gear One / LG1
www.OHRCR.com
Gitsum is offline   Reply With Quote
Old 11-16-2009, 01:14 PM   #2789
Team STPN's Avatar
LF...you have a pm
Do you have any pics of that set up?
Team STPN is offline   Reply With Quote
Old 11-16-2009, 01:16 PM   #2790
Regional Moderator
mrrcguy's Avatar
Trader Rating: 25 (100%+)
The Photons put down some good runs in Dallas this weekend at the Fall Classic. Myself and Dustin Layne finished 2nd and 3rd in 17.5 Rubber, and 4th and ? in 13.5 Rubber.
Congrats to Chris Adams for the 17.5 win, and to Mike Dumas for the 13.5 win.
mrrcguy is offline   Reply With Quote
