Old 11-12-2009, 01:12 PM   #2761
LOW ET's Avatar
Trader Rating: 96 (100%+)
i'm putting this rubber kit together and ran across some things,
i've got two .20mm shims that came in the bag of hardware for the axles but they're not noted in the assembly manual. do these go on the rear axles between the bearing and the drive pin for the hexes? they seem to have more slop then the fronts.
i also got four aluminum axles, i thought it was going to be two steel for the front and two aluminum for the rear
LOW ET is offline   Reply With Quote
Old 11-12-2009, 01:22 PM   #2762
Yes, those shims are for rear axles.
Cheers.
Fastfreddy74 is offline   Reply With Quote
Old 11-12-2009, 01:46 PM   #2763
BagofSkill's Avatar
Yeah, despite the advertised spec the rubber kits not come with aluminium front axles. No one has said why. Seems to have been a change for the 2nd batch of kits.
Just make sure you put the two shorter shafts in the back and the longer ones in the front.
BagofSkill is offline   Reply With Quote
Old 11-12-2009, 04:20 PM   #2764
Luke Hobson's Avatar
Send a message via MSN to Luke Hobson
out of both the kits I had, (one in April/may and one in september) both had steels up front..
Luke
Luke Hobson
Awesomatix - Xenon - Godzilla Paint - Moorespeed - ToniSport - MBmodels
http://luke-hobson.blogspot.com/
Luke Hobson is offline   Reply With Quote
Old 11-12-2009, 07:41 PM   #2765
Piyo Piyo's Avatar
Any axles (I mean the universals part that connected to tyres) from other brands that I can used? Tamiya or XRAY?
Thanks.
VIOLA ARIELLE & FLOREN ISABELLE
Piyo Piyo is offline   Reply With Quote
Old 11-13-2009, 01:03 AM   #2766
BagofSkill's Avatar
My kit, bought 20th September, came with ally shafts and V2 spool with additional steel cups.
I've seen/heard of half a dozen others with ally, only yours with steels Luke. Maybe it's luck of the draw or what's in stock when the kits are being bagged.
Old 11-13-2009, 05:36 AM   #2767
stiltskin's Avatar
Trader Rating: 102 (100%+)
How's the version two spool holding up? Any issues with the steel cups?
Tony Rumple
Team EAM // Gravity RC
stiltskin is offline   Reply With Quote
Old 11-13-2009, 07:24 AM   #2768
The v2 spool with the steel cubs works fine for me.
No play and the cubs are strong.
http://www.mikky32.com
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
mikky32 is offline   Reply With Quote
Old 11-13-2009, 07:30 AM   #2769
stiltskin's Avatar
Thanks. I'm still running the plastic cups and I am debating between the steel cups or the Roche spool with the Yokomo gear. I've got about twenty plastic cups and an extra spool, so I'm not in a big hurry.
Tony Rumple
Old 11-14-2009, 10:19 AM   #2770
LOW ET's Avatar
so when is the optional belt tensioner needed? my belts feel fine with out it but it is a new kit.
also what turnbuckle wrench you guys using with the steel turnbuckles? seems to be a 3.5mm or something.
Old 11-14-2009, 01:49 PM   #2771
adamge's Avatar
Low, I see no signs of needed a belt tensioner. After moderate use, my belts still are tight even with the diff in the middle position. Lots of diff movement left.
I'm using my Xray 3&4 mm turnbuckle wrench, the 4mm end. It's larger than ideal, but works.
When someone is intent on excelling in an otherwise laudable manner, does he not desire to inflict pain on others by means of his exalted status and enjoy the envy he arouses? Is there not an anticipated delight in an artist's ability to defeat his artistic rivals, which heightens his euphoria in creation?
-Nietzsche
adamge is offline   Reply With Quote
Old 11-14-2009, 02:00 PM   #2772
sosidge's Avatar
I'm using a wrench that I got in an old Yokomo kit - I think it is a Lunsford. Seems to be the right size.
On the topic of belt tension, I have my front belt on three notches loose. Needed to be loose otherwise the tension would literally bend the chassis up (sans topdeck). Rear is in the middle. Seems OK for 13.5.
Old 11-14-2009, 02:09 PM   #2773
yokemad's Avatar
How about TIR spool....
what you guys think about it ?
I'm thinking about to order one for 416 and tamiya one also made by same material like photon version...
any feedback welcome
yokemad is offline   Reply With Quote
Old 11-14-2009, 03:58 PM   #2774
stiltskin's Avatar
Carpet season just started for us. Lipo 2.5 chassis on it's way. Life is good.
Tony Rumple
Old 11-14-2009, 05:05 PM   #2775
Default 13.5 fdr
Hey Stiltskin,
Do you know a good FDR for a Tekin 13.5 in my rubber photon?
thank you
grouchy is offline   Reply With Quote
