Old 11-11-2009, 12:59 PM   #2731
odpurple's Avatar
Originally Posted by PitNamedGordie View Post
It depends...The setups that utilize the foam chassis are for high bite carpet. For low to medium bite carpet the regular chassis is fine.
True. Thanks Steve
odpurple is offline   Reply With Quote
Old 11-11-2009, 01:07 PM   #2732
BagofSkill's Avatar
Hi All,
I posted a few pages back about my bowed chassis.....
After building it all up piece by piece and checking for flatness in between I've traced the problem to the top deck. It's 0.6mm too short! I measure the didtance between inside hole centre on the top deck to be 154.2mm and the bulkhead holes are 154.8mm apart centre to centre.
I've attached a picture which illustrates the problem. Every other screw on the chassis/bulkhead/wings is done up and the chassis is flat. Both belts are off and the diffs are out/dampers off. As has been said before the countersunk design of all parts means you can't build tweak in or out of the car.
Can anyone compare lengths with me? Particulary I'm intersted if a new top deck might sort it if I have a duff one.
T.O.P. Racing "Photon" 1/10 EP Touring Car-photon-deck-003.jpg
BagofSkill is offline   Reply With Quote
Old 11-11-2009, 01:13 PM   #2733
THeGame's Avatar
Send a message via AIM to THeGame
Originally Posted by BagofSkill View Post
Hi All,
I have flipped the top deck and am running bottom head screws.. this should fix your problem..
Team Gravity Rc - G's R/C Raceway and Hobbies - Waldorf RC - TheTrack
THeGame is offline   Reply With Quote
Old 11-11-2009, 01:16 PM   #2734
marcel p's Avatar
Send a message via MSN to marcel p
Hi All,
i have the same problem with the top deck
PR racing
Powerstar/futaba 4px
Absima /vr racing
marcel p is offline   Reply With Quote
Old 11-11-2009, 03:18 PM   #2735
stiltskin's Avatar
Trader Rating: 102 (100%+)
Car was good today but I've still got work to do. I think the chassis flexes too much on the carpet and causes a very aggressive feel. I didn't get to play with shock fluids today, but I will by this weekend. Car did come around pretty good throughout the day, I just need to calm it down a little. Overall good day with the car.
Tony Rumple
Team EAM // Gravity RC
stiltskin is offline   Reply With Quote
Old 11-11-2009, 03:35 PM   #2736
THeGame's Avatar
stiltskin, did you try larry's foam setup from the gate race he posted..
Old 11-11-2009, 04:20 PM   #2737
stiltskin's Avatar
I'm running rubber tires. My problem right now is too much steering. I guess it should be easier to get rid of steering than it is to find steering. The traction is pretty low right now, so I'm probably wasting alot of time anyway. At least I'll have a good low/medium traction setup by the time I'm done.
Tony Rumple
Old 11-11-2009, 04:30 PM   #2738
JimmyMac's Avatar
Go ahead and waste all the time you want. It'll be better for me when yall start carpet season up there!
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
JimmyMac is offline   Reply With Quote
Old 11-11-2009, 04:32 PM   #2739
stiltskin's Avatar
Thanks Jimmy. You're the greatest.
Tony Rumple
Old 11-11-2009, 04:49 PM   #2740
Any and all practice is good...key....is to keep track or remember what adjustments do what. lol!
Schuurspeed / Aero-model / Gear One / LG1
www.OHRCR.com
Gitsum is offline   Reply With Quote
Old 11-11-2009, 04:54 PM   #2741
stiltskin's Avatar
You got that right.
Tony Rumple
Old 11-11-2009, 04:54 PM   #2742
Trader Rating: 40 (100%+)
Just wanting to hear some opinions, I plan on running rubber tires on carpet, so should I go for the rubber edition kit or the foa
edition and just add a spool? Or if someone can point me to a out of the box rubber setup for carpet that'd be great!
AndysD8 is offline   Reply With Quote
Old 11-11-2009, 05:04 PM   #2743
stiltskin's Avatar
Both kits cost the same. The foam kit comes with a front diff ($50 option), the rubber kit comes with a spool ($20) I would get the foam kit and pick up a spool with it. If you decide to run outside, the rubber chassis is also cheaper than the foam chassis so you save on the conversion. M2C.
Tony Rumple
Old 11-11-2009, 05:05 PM   #2744
You could go either direction really. If you plan on just doing rubber indoors and out get the rubber kit. If you might do some foam and rubber get the foam kit. Keep in mind if you use the foam kit in rubber it is stiff which in turn can make the car edgy. Either way you can't go wrong as there are very good setups for both already to be had.
www.OHRCR.com
Old 11-11-2009, 05:13 PM   #2745
All we run around here is indoor carpet, rubber tires. I had just heard and not sure if there is any truth to it, that out of the box the rubber spec is great on asphalt but not so much on carpet. For those running the rubber spec on carpet, what wing and top deck are you using? I'm just curious how a out of the box foam edition, with a spool does with rubber on carpet. If I'm getting on anyones nerves with all the questions, I apologize! Just want to make the right choice with my first "new" car!
