Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 11-06-2009, 08:06 PM   #2656
i think their more in the tc5 price range which is pretty good
BRANDINI
rosko is offline   Reply With Quote
Old 11-06-2009, 08:09 PM   #2657
L.Fairtrace's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to L.Fairtrace
Parts are in the TC5/Losi pricerange and I haven't seen a Lipo that didnt fit out of the box.
T.O.P Racing-Team Express-Horizon Hobby-Parma/PSE
BSR-Spektrum-Thunder Power-Team Tekin
Horsham PA RC Carpet Racing 2009... RISES FROM THE ASHES. COME GET RUGBURN
L.Fairtrace is offline   Reply With Quote
Old 11-06-2009, 08:10 PM   #2658
Originally Posted by mrrcguy View Post
Hearing that so many guys were running new tires every run is kinda frustrating. Id hate to see this happening at all the races. Thought we were past those days. Anyway, knowing that you ran fewer sets that most, what was the wear like. How many runs did it take for the seam to go away?
Keven didn't run new tires every run. In fact if I remember correctly the rounds he ran new tires were the rounds Larry TQed in. He did put on a new set for the main. Keven and Larry had an incredible 4th qualifier. Keven got an early .3 advantage and they ran at about the same separation the rest of the way matching lap times. On the second to last lap Keven tapped a corner which caused him to hit the outside barrier and Larry captured TQ. I really wish we could have seen what would have happened in the main had it not been for Larry's bad luck on this first lap. It would have been a heck of a race.
or8ital is offline   Reply With Quote
Old 11-06-2009, 08:27 PM   #2659
I had the advantage in that qual early with a couple 10.9s up front then I rolled my car and had a 12.4 second lap and worked my way back till I got into the lead on the 2nd or 3rd to last lap. When they announced I was leading I backed it off a little bit so I didnt screw up. I wish I didnt though cause I would of loved to get the 33 lapper. But needless to say Kevin and I had good battles all weekend, I'm very pleased with being able to run with him, if only I didnt forget to put a screw back in my c hub after checking my front driveshafts before the main. Doh.
Old 11-06-2009, 08:31 PM   #2660
You two put on a great show all weekend. Very fun to watch!
Old 11-06-2009, 08:35 PM   #2661
Thanks man I enjoyed it very much.
Old 11-06-2009, 08:37 PM   #2662
Kwikvdub's Avatar
Trader Rating: 29 (100%+)
Send a message via AIM to Kwikvdub
Your so cool Larry!!....... See you tomorrow!
Alex Valdes
Express Motorsports / TQ Racing / Larcher Paintworks / Jackson RC / Horsham RC
Kwikvdub is offline   Reply With Quote
Old 11-07-2009, 03:18 AM   #2663
Originally Posted by Fastfreddy74 View Post
Just a quick question:
Does anyone know if Associated's 48p spur gears fits on the photon?
No one?
Fastfreddy74 is offline   Reply With Quote
Old 11-07-2009, 04:30 AM   #2664
LOW ET's Avatar
Trader Rating: 24 (100%+)
No one?
which associated spurs? if you're talking about the kimbrough spurs they should work from what i've been reading. i'll let you know in a few days
LOW ET is offline   Reply With Quote
Old 11-07-2009, 05:07 AM   #2665
Thank you ET, i'm referring to associated's part numbers no.3921 (69T), no.3922 (72T) and no.3923 (75T)
Cheers!
Old 11-07-2009, 07:40 AM   #2666
CockyDuck's Avatar
Hey Bro,
I am not sure about associated spurs but i know for sure kimborough spurs works on photon. Just a little mod to rim the holes on the spurs by just a little bit. Works well for me.
Cheers
@@@_________________________Jon's AutoMart______________________________@@@
1WD ON --- Kyosho MotorBike
2WD ON --- M-03S, M-03M, M-03L, M-03R, M-04M, M-04L, M-05Pro, F103RM, CRC Knife.
4WD ON --- TT-01D, TA-05, MR-4TC SD CM, PRO 4, TOP Photon.
4WD OFF --- Manta Ray, Cold Buster, DF-03, ZX-5 FS.
CockyDuck is offline   Reply With Quote
Old 11-07-2009, 08:54 AM   #2667
LOW ET's Avatar
Cheers!
those should work, they're kimbrough spurs.
and according to others and cocky duck the kimbroughs work with a little reaming of the holes in the spur.
Old 11-07-2009, 09:55 AM   #2668
Thanks guys!
Right now i'm using a 78T corally spur on the photon, i was looking for some smaller spurs to match the same diameter as the stock 100T 64P spur.
Old 11-07-2009, 10:02 AM   #2669
Thanks! Where are people in the USA getting their parts from though? My lhs says he can't get them. Might be cause he's trying to get me to go the tc5r route but Ive already got one and don't really like it. I was wanting a newer design tc and I feel the top photon is exactly that! I don't mind making an order and having some spares on hand but amain is limited on what they actually have in stock. Where else can I order parts for the photon online? Also, what seems to break on the car? What do I need to have in my bag at the track? Thanks!
AndysD8 is offline   Reply With Quote
Old 11-07-2009, 10:07 AM   #2670
amnesia's Avatar
I ran my Photon at the new 1350g weight last night on carpet with rubber tyres.
All I can say is WOW !!!
Sooo much faster, handling was superb (even using the previous 1500g setup), turning was like it was thought-controlled.
Best bit was that the motor isn't under so much load with the reduced weight so I can probably gear up another couple of teeth on the pinion for even more speed.
.-= T.O.P. Photon =-.
Tekin RS Pro / Ballistic 13.5t / Scanner / Demon LiPo / Spektrum TX
amnesia is offline   Reply With Quote
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
008-Racer
Forum Jump
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
