Old 11-05-2009, 08:10 PM   #2641
PitNamedGordie's Avatar
Send a message via AIM to PitNamedGordie Send a message via Yahoo to PitNamedGordie
Originally Posted by CockyDuck View Post
Hey Bro,
Just wanna confirm that the new thinner 2.5mm chassis is better for high bite carpet. I thot that with a thinner chassis it would means more flex thus more grip so tracks with low traction might work.
Pardon me if i am wrong. Still newbie.
It should read 2.5mm lipo chassis, which is thicker than the 2.0mm rubber lipo chassis, which is the counter part to the standard 6 cell 2.5mm rubber chassis. Also I think the foam chassis is made out of stiffer carbon fiber.
Hope that made sense.
☆ The Track @ Harbor Hobbies ☆ www.harbor-hobby.net ☆
PitNamedGordie is offline   Reply With Quote
Old 11-05-2009, 08:23 PM   #2642
smoke81's Avatar
Send a message via AIM to smoke81 Send a message via Yahoo to smoke81
The chassis he is talking about is the same thickness as the stock chassis. It is made out of a different kind of carbon fiber, and its much much stiffer. Also doesn't have the cutt outs for round cells anymore. So in short your thinking is right about the flex. It just happens to be stiffer actually.
Dustin Layne
smoke81 is offline   Reply With Quote
Old 11-05-2009, 09:58 PM   #2643
mikel33's Avatar
Trader Rating: 2 (75%+)
Originally Posted by grouchy View Post
What adjustments are you talking about? If it is kick up,that is for off road cars.I don't see why Top can't make a six(6) degrees front c hub.Every other manufacturer makes them.
I wouldn't mind seeing some 6 degree hubs myself. I had asked the same question on the thread a while back so it doesn't seem likely. Xrays will work with a little trimming and a few well placed shims. I have a set but haven't tried them yet.
A question for Larry and the other drivers at the gate. In all honesty, how much difference did the tires make? I've seen a set of new 28's cover over a lot of handling issues. I'm not bashing or criticizing, but it does seem like a big performance gain compared to Vegas (Jaco's). If the car truly comes to life on carpet with the stiffer chassis I'm all for it. Most of my racing is done on Blues because the larger races I attend mandate them. So I am very, very interested in the tire aspect.
thanks
michael.
Michael Larson.
Village Idiot Racing
mikel33 is offline   Reply With Quote
Old 11-05-2009, 10:53 PM   #2644
L.Fairtrace's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to L.Fairtrace
I know for a fact that almost every driver in the A main ran a new set of tires every run. I only ran 2 sets of tires during 4 rounds and the mains and was just as fast as anyone else. Even faster. If we were running SJR's and everyone else was running Jacos I could see where your question might be valid but since everyone was on equal tires its pretty much a moot point. I had 1/20th the time on the car at the IIC as all the A mainers had plus I had issues with other things also, now that we have developed a proper setup you will see Top cars at or near the top of every big Super Stock race for a long time to come, no matter what the tire.
In the 4th round I'm pretty sure that the top 5 cars had brand new tires on their cars. Here are the laptimes. 4 A mainers from the IIC were at this race including 2 of the top 3 finishers and 2 of the top 3 qualifiers. Not every result will be similar because they are all very good drivers and racers but it just shows that the car is capable of running at the top.
4th Round Halloween Classic Laptimes
I ran the exact same setup I run at our track with Jacos and this setup is the fastest car at our track. I wish I actually had some newer jacos to try at the Classic because the car may have been just as fast. I personally like the feel of jacos on my car better but its about .1-.2 faster on Sorex based tires, but like I said everyone was on equal tires so it really doesnt matter.
T.O.P Racing - Awesomatix USA - EaMotorsports - BSR Racing Tires - Orca - TQ Wire - Solaris Racing Tires - Side Piece Racing
Horsham RC. Where champions practice Failing. I'm your everything.....
L.Fairtrace is offline   Reply With Quote
Old 11-05-2009, 11:19 PM   #2645
mikel33's Avatar
thank you.
Michael Larson.
Old 11-06-2009, 12:13 PM   #2646
CockyDuck's Avatar
Hey Bro,
Got it. Thanks for clarifying.
@@@_______________________Jon's AutoMart___________________________@@@
T.O.P. RACING = TOP Photon Ex, Sabre FD-2 /// TAMIYA = M-03R/, M-04, M-05Pro, F103RM, FF-03 Pro, FF-03 EVO, TT-01D, TA-06 Pro,TRF-201 /// KYOSHO = MotorBike, DBX, ZX-5 FS /// YOKOMO = MR-4TC SD CM /// KM-01 /// VBC = DB 06 /// CRC = Knife, Gen X.
CockyDuck is offline   Reply With Quote
Old 11-06-2009, 12:14 PM   #2647
CockyDuck's Avatar
Hey Bro,
Cheers
Old 11-06-2009, 02:37 PM   #2648
Just a quick question:
Does anyone know if Associated's 48p spur gears fits on the photon?
Fastfreddy74 is offline   Reply With Quote
Old 11-06-2009, 04:57 PM   #2649
LOW ET's Avatar
Trader Rating: 91 (100%+)
is anyone using the bolt on weights? if so, which one's?
LOW ET is offline   Reply With Quote
Old 11-06-2009, 05:26 PM   #2650
Regional Moderator
mrrcguy's Avatar
Trader Rating: 25 (100%+)
Do you know how many of the other guys in the main were running the SJR's?
mrrcguy is offline   Reply With Quote
Old 11-06-2009, 05:30 PM   #2651
Regional Moderator
mrrcguy's Avatar
Basically what I was getting at is, if you are looking to get more steering, you can get more than enough even without 6* blocks.
If it is steering you are looking for, feel free you post your set-up and we will be glad to give you some suggestions.
Old 11-06-2009, 05:36 PM   #2652
8-10 were running SJR's
Me, Kevin, Schreffler, Brad, Goetz, Chicky, Drew, Blackstock
Haynes and Martin were running Speedmind/Sorex.
Old 11-06-2009, 05:46 PM   #2653
Regional Moderator
mrrcguy's Avatar
Hearing that so many guys were running new tires every run is kinda frustrating. Id hate to see this happening at all the races. Thought we were past those days. Anyway, knowing that you ran fewer sets that most, what was the wear like. How many runs did it take for the seam to go away?
Old 11-06-2009, 08:59 PM   #2654
Trader Rating: 40 (100%+)
I've been thinking of ordering the photon, but i've got 2 questions. What size lipos are people able to run bone stock out if the box and where's a good place to order spares from? Just curious if spares were in the xray price range of say hot bodies cyclone price range
AndysD8 is offline   Reply With Quote
Old 11-06-2009, 09:05 PM   #2655
Unfortunately thats what happens when there is no spec tire and not tire limit, everyone is trying to get everything they can out of every run. Its a bummer I will agree. I wish for this series we would make a gentleman's agreement to run a set amount of tires say 2 per race. Its not like the tires were bad after a run but they were definitely slower by .1 at least. They probably stay the same for many runs after the first so a limit would solve most problems we are having.
Just on a side note, the 2 rounds I ran brand new tires were the 2 rounds I tqed, not to say I couldn't of done it the other rounds on used tires but I hit stuff those rounds or had lapped traffic problems.
I dont know how long it took for the seam to go away, I ground it off and broke the tires in for 8 or so laps in practice then ran them.
SEO by vBSEO 3.5.0
