Old 11-04-2009, 06:32 PM   #2626
stiltskin's Avatar
Trader Rating: 101 (100%+)
Just thinking out loud here. If you use the extra hard wings, there are several different tuning options. You can use all three standoffs (2 outside and 1 center), you can use just the outside standoffs, just the center standoff or none of them. 4 different options. Now I wonder how each would react or compare to the medium or hard wings.
Tony Rumple
Team EAM // Gravity RC
stiltskin is offline   Reply With Quote
Old 11-04-2009, 08:20 PM   #2627
Regional Moderator
mrrcguy's Avatar
Trader Rating: 25 (100%+)
Originally Posted by BagofSkill View Post
So, Is the verdict that the Foam chassis the best for Rubber Carpet, or is it just a matter of changing the top decks?
The regular rubber chassis will work fine for low to medium bite carpet, but if you will be running on the med-high or very high traction tracks you should absolutely pick up the 2.5mm "Foam" chassis.
The wings used are apparently debatable, so pick up some options.
mrrcguy is offline   Reply With Quote
Old 11-05-2009, 11:35 AM   #2628
Regional Moderator
mrrcguy's Avatar
Default Set-Up Sheet
Here is what I have come up with for high bite carpet. I ran this at Trackside last week with good results. The layout was nice and flowing and the traction was very good.
Only two guys have managed 27 lap runs (5 minutes) on the layout and this set-up brought me to a 26 5:01.26 Im 100% confident that I have a 27 lap set-up in steadier hands.
There is an error on the sheet that I will fix and re-post ASAP. For the suspension mount spacers in the front it should read FF=2.3mm / FR=1.4mm
File Type: pdf PHOTON SET-UP SHEET CARPET HIGH BITE.pdf (309.9 KB, 123 views)
Old 11-05-2009, 01:33 PM   #2629
Default 6 degree steering blocks
Are there any plans for the six(6) degrees steering blocks?
grouchy is offline   Reply With Quote
Old 11-05-2009, 01:59 PM   #2630
Hello all,
Just wondering what the teeth count is on the front/rear pulleys and center pulleys.
Cheerz
Obsidian is offline   Reply With Quote
Old 11-05-2009, 02:03 PM   #2631
PitNamedGordie's Avatar
Send a message via AIM to PitNamedGordie Send a message via Yahoo to PitNamedGordie
Originally Posted by Obsidian View Post
Hello all,
Cheerz
40 front/rear and 20 center.
☆ The Track @ Harbor Hobbies ☆ www.harbor-hobby.net ☆
PitNamedGordie is offline   Reply With Quote
Old 11-05-2009, 02:20 PM   #2632
Luke Hobson's Avatar
Send a message via MSN to Luke Hobson
just incase anybody is wondering, the foam 2.5 chassis doesn't really work on our tracks in the uk. The traction on the tracks we have (even maritime or rug racers) just isn't enough tbh
I've been experimenting with the wings, and so far, just added the front and rear medium wings, it's a good balance.
Hth
Luke
Luke Hobson
Awesomatix - Xenon - Godzilla Paint - Moorespeed - ToniSport - MBmodels
http://luke-hobson.blogspot.com/
Luke Hobson is offline   Reply With Quote
Old 11-05-2009, 02:30 PM   #2633
Regional Moderator
mrrcguy's Avatar
Hth
Luke
I could see that for sure.
I think its important to be clear about when to use a different chassis.
If you are running asphalt or low to medium traction carpet, the standard rubber chassis is the way to go as it is perfect.
If you will mainly be running on high bit or very high bite carpet the newer 2.5 "foam" chassis is going to be the way to go.
Old 11-05-2009, 05:00 PM   #2634
I have been asking this question for the longest while, still no answer
RROL and LOU`s where only real racers race.
Weapons of choice,NT1 2010 , X-Ray T3 x 2, X-Ray X10 X-Ray all the way baby.
Futaba 4pk,gq tires,jaco tyres,odonnel fuel,T-Power batteries, tekin and nova powered.
Don`t blame the car, when you know you can`t drive.
Sponsor, me , myself and I.
nitro ho is offline   Reply With Quote
Old 11-05-2009, 05:07 PM   #2635
Regional Moderator
mrrcguy's Avatar
I may be mistaken but I believe the answer has been given in the form of "no".
I think you will find that there is more than enough "room" for adjustment to get anything you want out of the car without the #6 blocks.
Old 11-05-2009, 05:23 PM   #2636
Ron Goetter's Avatar
Trader Rating: 17 (95%+)
Send a message via AIM to Ron Goetter
Why are you running 1mm of inboard toe-in in the front?
Also why only 1* of rear toe on rubber tires?
The Goat... B-Mainer Fo' life
-Awesomatix USA-ROCHE USA-Team CRC-ORCA-SIDE PIECE RACING-TEAM DAK-EA Motorsports-VP Fuel-Trains and Lanes-CR Graphics-TQ Wire-Horsham RC-rugburn anyone?
Shut up and Race!!!!
Ron Goetter is offline   Reply With Quote
Old 11-05-2009, 05:43 PM   #2637
Regional Moderator
mrrcguy's Avatar
Im not running inboard toe in the front.
I'll check the sheet for errors and get back to ya on this.
Old 11-05-2009, 06:04 PM   #2638
Regional Moderator
mrrcguy's Avatar
There is an error on the sheet that I will fix and re-post ASAP. For the suspension mount spacers in the front it should read FF=2.3mm / FR=1.4mm This gives some front arm sweep.
The limited (im not certain that those shims actually come out to 1*) rear toe should be used only if the grip is real good. You have to keep in mind that the Photons make huge amounts of traction. This being the case you can try things with this car that you may not get away with in other cars. No two car designs are the same much like no one persons set-up will suite all driving styles. I suggest that you put this exact set-up on your car (assuming your track has a good groove) and the tweak it a little at a time to best fit you.
I changed the rear toe to that amount just before qualifying. Earlier in the day when there was less compund layed down I had an additional .5mm shim at RR.
Old 11-05-2009, 06:48 PM   #2639
CockyDuck's Avatar
Hey Bro,
Just wanna confirm that the new thinner 2.5mm chassis is better for high bite carpet. I thot that with a thinner chassis it would means more flex thus more grip so tracks with low traction might work.
Pardon me if i am wrong. Still newbie.
@@@_______________________Jon's AutoMart___________________________@@@
T.O.P. RACING = TOP Photon Ex, Sabre FD-2 /// TAMIYA = M-03R/, M-04, M-05Pro, F103RM, FF-03 Pro, FF-03 EVO, TT-01D, TA-06 Pro,TRF-201 /// KYOSHO = MotorBike, DBX, ZX-5 FS /// YOKOMO = MR-4TC SD CM /// KM-01 /// VBC = DB 06 /// CRC = Knife, Gen X.
CockyDuck is offline   Reply With Quote
Old 11-05-2009, 07:07 PM   #2640
What adjustments are you talking about? If it is kick up,that is for off road cars.I don't see why Top can't make a six(6) degrees front c hub.Every other manufacturer makes them.
