Old 10-28-2009, 04:13 PM   #2566
stiltskin's Avatar
Trader Rating: 99 (100%+)
Originally Posted by amnesia View Post
Anyone know if there are alloy servo mounts in the pipeline ?
I managed to strip the standard plastic ones in a collision and I am finding it tricky to get some replacements
Alloy ones with two mounting holes (like the Xray ones) would be good - need to be offset a bit though so that a servo saver can be used.
I used two of the alloy motor plate supports TRP-TC-PCH014RD to hold the servo in place. I had to place one washer under each of them to get the correct height but it put the servo in the perfect place for use with a Kimbrough servo saver. No shimming required.
Tony Rumple
Team EAM // Gravity RC
stiltskin is offline   Reply With Quote
Old 10-28-2009, 05:27 PM   #2567
CraigM's Avatar
Trader Rating: 34 (100%+)
Originally Posted by BagofSkill View Post
It did come with 4 plastic and 2 steel spool outdrives though. I tried plastic first and stripped one (I race indoors carpet) but the current pair seem to be lasting ok!
I just picked up a V2 spool and alloy outdrives. Anyone know how the blades will last up front running 10.5 on asphalt?
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 10-28-2009, 07:58 PM   #2568
Regional Moderator
mrrcguy's Avatar
Trader Rating: 25 (100%+)
As long as you dont try to run the front track width to narrow you should not have any issues with the V2/Spool/Blades.
All Photon owners should make certain that they are running the V2 spool. The V2 is 100% better that the original spools.
mrrcguy is offline   Reply With Quote
Old 10-28-2009, 08:57 PM   #2569
odpurple's Avatar
The Version 2 Spool is made of harder material and the screw hole is smaller so it works a lot better than the original. Only the interim V2 spools that were supplied to TOP USA before production began have the silver marks on them (I know cuz I put em there) The current production V2 Spools are the same part number as the original ones but say "Spool Set Ver 2" on the header card
odpurple is offline   Reply With Quote
Old 10-28-2009, 08:59 PM   #2570
smoke81's Avatar
Send a message via AIM to smoke81 Send a message via Yahoo to smoke81
I've been running mine since IIC on a crazy tight small carpet track atleast twice a week (13.5). Haven't lost a blade yet.
Dustin Layne
smoke81 is offline   Reply With Quote
Old 10-28-2009, 10:49 PM   #2571
You actually have to go fast first.....
Schuurspeed / Aero-model / Gear One / LG1
www.OHRCR.com
Gitsum is offline   Reply With Quote
Old 10-28-2009, 10:54 PM   #2572
smoke81's Avatar
That problems been fixed :P The car has been great!
Dustin Layne
Old 10-28-2009, 10:58 PM   #2573
Don't think the problem was the car but maybe the nut behind the wheel....lol!
www.OHRCR.com
Old 10-28-2009, 11:02 PM   #2574
DENNIS STORTI's Avatar
Trader Rating: 42 (94%+)
Send a message via AIM to DENNIS STORTI
i modded mine with xray mounts drilled and counter sunk the chassis for xray mounts behind the servo
the pics are posted a few pages back
DENNIS STORTI is offline   Reply With Quote
Old 10-29-2009, 02:05 AM   #2575
amnesia's Avatar
Cheers !
There were no silver marks on my v2 spool either... got a TiR one now, so no need to worry anyway
.-= T.O.P. Photon =-.
Titanium Racing (Team TR Driver) / Tekin RS Pro / Novak Ballistic 13.5t / Spektrum
www.titaniumracing.com
amnesia is offline   Reply With Quote
Old 10-29-2009, 11:50 AM   #2576
Regional Moderator
mrrcguy's Avatar
Cheers !
The comment about the silver paint was an error on my part. I have edited that post .
Old 10-29-2009, 06:47 PM   #2577
Do you have image without the servo so I can see where the new holes are drilled? Thanks.
cvccsi is offline   Reply With Quote
Old 10-29-2009, 08:59 PM   #2578
veecee's Avatar
Originally Posted by RC MARKET View Post
Don't need use blade !
What about the alloy spool outdrives? Do you need to use a blade with those?
SMOKEM --- HIRO SEIKO --- YOKOMO
veecee is offline   Reply With Quote
Old 10-29-2009, 09:17 PM   #2579
Regional Moderator
mrrcguy's Avatar
With the aluminum (red anodized) outdrives you will use blades. With the steel (gray in color) no blades are needed.
Old 10-29-2009, 10:16 PM   #2580
veecee's Avatar
Thanks!
SEO by vBSEO 3.5.0
