Old 10-25-2009, 10:41 PM   #2536
smoke81's Avatar
Send a message via AIM to smoke81 Send a message via Yahoo to smoke81
Originally Posted by L.Fairtrace View Post
Try the exact setup I posted a couple pages ago.
Yes I that would be a wise thing to do :P Tried it today, and it was pretty awsome.. I had to make a few changes to fit me, and our slick conditions. By far the best car i'd had in a long time..
Dustin Layne
smoke81 is offline   Reply With Quote
Old 10-26-2009, 04:03 AM   #2537
BagofSkill's Avatar
Hi Larry,
I've been running your setup for 2 weekends now. It's generally very good (thanks!)- but I'm trying to get a bit more front end in the car, especially in the low speed corners. It just feels like I'm having to coast for too long in the twisty sections. I'd like the car to carry a bit more speed and maybe rotate a bit more. This is a indoor carpet track with medium grip.
Any suggestions?
BagofSkill is offline   Reply With Quote
Old 10-26-2009, 04:48 AM   #2538
Luke Hobson's Avatar
Send a message via MSN to Luke Hobson
if you want the rear to rotate more i would stand rear shocks up on the tower by one hole.
Luke Hobson
Awesomatix - Xenon - Godzilla Paint - Moorespeed - ToniSport - MBmodels
http://luke-hobson.blogspot.com/
Luke Hobson is offline   Reply With Quote
Old 10-26-2009, 05:45 AM   #2539
BagofSkill's Avatar
Cheers Luke. The car is not bad in any sense and I've been trying to fix it by adding grip to the front rather than taking it from the rear, but that option is still open to me.
What setup have you been running for UK carpet tracks?
Old 10-26-2009, 05:58 AM   #2540
yokemad's Avatar
@Luke
do you use standard rubber car @indoor carpet ?
or thicker chassis and top deck?
cheers
yokemad is offline   Reply With Quote
Old 10-26-2009, 08:46 AM   #2541
hey guys,
I'm running STD bottom and top decks, and medium front wing but std rear. This makes the flex of the car much more equal front to rear I feel.
I'm working on desgning a few parts I want to test, but we'll see how they come along in time.
Luke
Luke Hobson
Old 10-26-2009, 12:24 PM   #2542
BagofSkill's Avatar
hey guys,
Luke
Luke, are you running the middle post on the medium wing?
So you found the front was a bit soft on flex? What were your symptoms or how has it changed the car?
Old 10-26-2009, 02:00 PM   #2543
luke check your PM buddy!
Green Speed is offline   Reply With Quote
Old 10-26-2009, 02:57 PM   #2544
stiltskin's Avatar
Trader Rating: 99 (100%+)
What changes did you make. I tried his setup and the back end will not stay in place. My car is completely stock. Our track is still low on traction for now.
Tony Rumple
Team EAM // Gravity RC
stiltskin is offline   Reply With Quote
Old 10-26-2009, 03:43 PM   #2545
jeppesen's Avatar
Thumbs up
I'm running in 17.5 rubber class on carpet.
And have been very happy with the car, winning races, the last one i won all qualifies and the 3 finals! it was on a medium grip track with sorex tyres.
Were running 2s lipo and minimum 1300 gram weight, i have settled about 1340 gram, and there is no sign on grip roll, just lots of corner speed
I am running almost the basic rubber set-up, with only a few changes that have helped the car to be even more easy to drive.
PM for set-up if interrested.
jeppesen is offline   Reply With Quote
Old 10-26-2009, 06:30 PM   #2546
Regional Moderator
mrrcguy's Avatar
Trader Rating: 25 (100%+)
Ive studied and compared your set-up to mine and I have one question. Is there a particular reason you run the 1.2mm/3hole pistons vs the 1.0mm/3 hole pistons? Or, is that just what you grabbed.
I have been running the 1.0/3hole with lighter oil.
mrrcguy is offline   Reply With Quote
Old 10-26-2009, 07:19 PM   #2547
Jerry P's Avatar
Trader Rating: 44 (100%+)
What shops carry the Photon?
Jerry P
Awesomatixusa - Side Piece Racing - LRP - Sweep Racing Tires - Mike L Designs - TQ Wires - Crispy Critters Raceway
www.awesomatixusa.com
Jerry P is offline   Reply With Quote
Old 10-26-2009, 07:32 PM   #2548
Ron Goetter's Avatar
Trader Rating: 17 (95%+)
Send a message via AIM to Ron Goetter
A-main is showing them in stock. Better hurry if you want one they go fast.
http://www.amainhobbies.com/product_...ar-Rubber-Spec
The Goat... B-Mainer Fo' life
-Awesomatix USA-ROCHE USA-Team CRC-ORCA-SIDE PIECE RACING-TEAM DAK-EA Motorsports-VP Fuel-Trains and Lanes-CR Graphics-TQ Wire-Horsham RC-rugburn anyone?
Shut up and Race!!!!
Ron Goetter is offline   Reply With Quote
Old 10-26-2009, 08:29 PM   #2549
MAD916's Avatar
We have 2 rubber and 1 foam in stock.
Timezone Raceway Park " on-road outdoor european style road course.
Timezone II 60'x100' indoor carpet track. Host of the ROAR 2011 Carpet Nat's.
Timezonehobbies.com your new source for online RC products.
MAD916 is offline   Reply With Quote
Old 10-27-2009, 12:57 AM   #2550
RC MARKET's Avatar
http://rcmarket.com.hk/index.php?cPa...a&filter_id=73
RC MARKET is offline   Reply With Quote
SEO by vBSEO 3.5.0
