Old 09-26-2009, 03:20 AM   #2296
amnesia's Avatar
Originally Posted by HenBeav View Post
I rather have too hard than too soft
My wife has the same sentiments
Anyway, believe it or not, the hinge pins on the Xray T2 are the same diameter and length
Who'd have thought, eh ??
.-= T.O.P. Photon =-.
Titanium Racing (Team TR Driver) / Tekin RS Pro / Novak Ballistic 13.5t / Spektrum
www.titaniumracing.com
amnesia is offline   Reply With Quote
Old 09-26-2009, 11:27 PM   #2297
DENNIS STORTI's Avatar
Trader Rating: 42 (94%+)
Send a message via AIM to DENNIS STORTI
Well another great day with the Photon, the car performed great I TQ'ed 17.5 by over a lap on the field and still made quite a few brain fade bobbles. In the amain again way out front with about 1 min to go i had a speed control knocked out because of some aggressive driving and getting into trouble
but great day i will get a new pair of calipers and put my setup up or maybe fairtace can give it it started as his setup that we tweaked a bit for my style
DENNIS STORTI is offline   Reply With Quote
Old 09-27-2009, 05:03 AM   #2298
stiltskin's Avatar
Trader Rating: 101 (100%+)
What size wheel and diff bearings are used in the car?
What are the stock spring rates from the kit?
Tony Rumple
Team EAM // Gravity RC
stiltskin is offline   Reply With Quote
Old 09-27-2009, 10:58 AM   #2299
RC MARKET's Avatar
5x10x4 & 10x15x4mm
RC MARKET is offline   Reply With Quote
Old 09-27-2009, 11:15 AM   #2300
I got my own Photon yesterday and I started with the setup that I had on the car that I borrowed this Sunday.
After a few laps I changed some small things.
Now my car has a lot of steer even with the holes in my front tires.
The car is great.
http://www.mikky32.com
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
mikky32 is offline   Reply With Quote
Old 09-27-2009, 11:21 AM   #2301
amnesia's Avatar
The car is great.
I found that the default setup in the manual is a great place to start. I think the only thing I have changed is the toe to 0 degrees, and the diff washers to )))))) rather than ()()().
Old 09-27-2009, 12:15 PM   #2302
I now but I used a car from a club member. He made small changes to get some more steer on the car.
I started with his setup and after testing I found a better setup for our track.
Now I changed very small things and that was more because of the tires.
They were almost gone.
Also do I love an other setup than the standard setup.
This setup works better for me and yesterday the club member drove with my setup and was very happy with it. He found that the car has more steer and is still stable.
We have new coating on our tarmac and coating has a different grip than on other tracks.
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
Old 09-27-2009, 12:30 PM   #2303
stiltskin's Avatar
Originally Posted by RC MARKET View Post
5x10x4 & 10x15x4mm
Thanks.
Stock spring rates?
Tony Rumple
Old 09-27-2009, 07:50 PM   #2304
beaim's Avatar
Trader Rating: 8 (90%+)
Send a message via MSN to beaim
can anyone tell me x ray t2 diff outdrive can fit in photon? because both price around the same. if fitted, x ray t6 diff i think more durable. thanks
beaim is offline   Reply With Quote
Old 09-27-2009, 09:26 PM   #2305
Do you mean the Spool Cups ? No they are different If its the spool cups you mean get the aluminum ones and problem solved they are solid and i havent even seen wear yet and i have at least 20 plus runs with not one issue.
Old 09-27-2009, 09:31 PM   #2306
smoke81's Avatar
Send a message via AIM to smoke81 Send a message via Yahoo to smoke81
Just to add to that.. You also want the V2 spool... Its made out of harder plastic and I believe the hole through the center is smaller so the screws really bite in. I know the spool i'm running right now has a lot of laps on it. It was used before I got it
Dustin Layne
smoke81 is offline   Reply With Quote
Old 09-27-2009, 09:35 PM   #2307
Yeah i forgot about the spool shows it hasnt been an issue lol
Here is a dark video of my car it is real good I know i trust Fairtrace when it comes to setup My car is on rails
http://www.youtube.com/watch?v=BGJIxhFimic
Old 09-27-2009, 09:40 PM   #2308
beaim's Avatar
i dun have single problem even with v1 spoll what i mean is rear diff outdrive.
mine almost need to replace. just seeking option.
Old 09-28-2009, 12:54 AM   #2309
RC MARKET's Avatar
Thanks.
Stock spring rates?
ok
http://rcmarket.com.hk/index.php?cPa...sort=2a&page=2
Old 09-28-2009, 01:36 AM   #2310
HVAC25000's Avatar
Trader Rating: 19 (100%+)
Not sure how that helps him?
Shock Spring (14 x 1.5 x 6.00) 344gf/mm , 19.2lb/in - Rubber Spec. Std
Shock Spring (14 x 1.5 x 6.50) 306gf/mm , 17.1lb/in - Rubber Spec. Std
Shock Spring (13 x 1.7 x 6.75) 560gf/mm , 31.3lb/in - Foam Spec. Std
Shock Spring (13 x 1.4 x 6.25) 306gf/mm , 17.1lb/in - Foam Spec. Std
P.S. If anyone has a photon they want to get rid of, let me know, I'm in the market for a used one.
HVAC25000 is offline   Reply With Quote
