Old 09-07-2009, 01:48 PM   #2131
marcel p's Avatar
Send a message via MSN to marcel p
i now its a tight track . but a nice track to run on.
clean pasing is a bit tricky
PR racing
Powerstar/futaba 4px
Absima /vr racing
marcel p is offline   Reply With Quote
Old 09-07-2009, 03:25 PM   #2132
SammyZ's Avatar
Trader Rating: 138 (100%+)
Originally Posted by syndr0me View Post
I built up some TRF shocks with the red bits from Tamiya for my Photon, and the TOP springs would slide over the end of the retainers during a run. I was using the alum retainers, though. Maybe the plastic is better. It was frequent enough that I went back to using TRF springs as well.
so do the TOP springs fit loose on the TRF retainer? or do they not fit at all and just slide down the retainer?
Hotbodies USA
SweepRacing USA
SammyZ is offline   Reply With Quote
Old 09-08-2009, 04:15 AM   #2133
CraigM's Avatar
Trader Rating: 34 (100%+)
The plastic ones are fine
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 09-08-2009, 07:22 AM   #2134
SammyZ's Avatar
what?
the plastic retainer and optional aluminum retainer are the same size.
Just trying to figure out if those new TOP springs might fit the TRF shocks?
Hotbodies USA
SweepRacing USA
Old 09-08-2009, 04:52 PM   #2135
jlfx car audio's Avatar
Trader Rating: 35 (100%+)
i need the bellcrank for my car cant find anyone that has a spair for a race i have this weekend will pay $25 shipped for it if it can get here by sat (jackson ,TN) pm me please.
love the car its a monster i VTA me and a friend have put down some searous fast laps with our cars (he improved +2 sec faster from his last car , we both agree it is so much easier to set up )
jlfx car audio is offline   Reply With Quote
Old 09-08-2009, 06:01 PM   #2136
Official's Avatar
Anyone have a good setup for a technical track where sharp turning is needed without drifting the rear???
Tried alot of setup but still can't pull in like like using one way front...
Running on: ESC = RS PRO
Motor = Speedpassion 11.5T
Currently Steering is using No.9 and Mid set-up.
Track traction is high and temp is 28C ~ 33C.
Chassis :4WD = CEFX Photon,TA-05|2WD = Xevo, M05PRO, FF-03Pro, Kysho Evola M3, Kyosho V-One RRR Shimo, Team C TC02
ESC :Brushless - Tekin RS-Pro, Keyence Tachyon|Brushed - Tekin FX-Pro
www.hiro-seiko.com ; www.cefx.net
e-mail: officialracing@gmail.com
Official is offline   Reply With Quote
Old 09-08-2009, 07:18 PM   #2137
Got My Lipo only chassis(Foam Spec) in the mail today. Can someone from T.O.P. tell me why there are NOT balancing holes in the chassis?!
kobiwan is offline   Reply With Quote
Old 09-08-2009, 07:50 PM   #2138
Send a message via AIM to HenBeav
There ar holes in the shock tower for balancing
[URL]http://www.fastlanehobby.com[/URL]
Support your local Lowe's, Walmart and Layne Machine Works INC.
HenBeav is offline   Reply With Quote
Old 09-08-2009, 10:38 PM   #2139
CraigM's Avatar
what?
I can't say anything about the alloy ones because I don't have them, but I've used the kit TOP springs TRF shocks and plastic retainers with no problem - maybe the outside diameter is different from alloy to plastic
AVATAR THEIF
Old 09-09-2009, 12:10 AM   #2140
RC MARKET's Avatar
good setup keep again !
RC MARKET is offline   Reply With Quote
Old 09-09-2009, 12:25 AM   #2141
razzor's Avatar
balancing holes are on the shock towers not on the chassis.
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Old 09-09-2009, 02:30 AM   #2142
How do I balance it with the holes in the shock towers? Is there a balancing tool I need, or do I have to make my own?
Old 09-09-2009, 03:56 AM   #2143
tallyrc's Avatar
i just use the ends of two of my smaller wrenches and watch which tires come off the ground first...
WWW.STORMERHOBBIES.COM helping keep pan cars alive!
Turns out not where, but who your with that really matters... DMB
tallyrc is offline   Reply With Quote
Old 09-09-2009, 04:14 AM   #2144
well i will try to give my set up
it started out as the stock rubber setup as a base line
went to 3deg total rear tow
-1 camber in rear
0 in front
324 springs in front
289 in rear
5min ride height
2.5 active droop (when tire lift off the ground)
front shocks top center hole
rear insecond to bottom
rear camber links are in the inside (at kit height)
widened the front by 3mm total
rear arms to moved to front
added 40g under front bumper
car weights in at 1477g
no let on chassis to balence it
i moved the batt out side of the chassis to balance it
Old 09-09-2009, 09:15 AM   #2145
Does anyone know if T.O.P. has sent the carpet kits to the hobby shops that placed orders for them? E.J. Evens said they got then in on Thursday of last week I think.
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
