Old 08-09-2009, 09:26 AM   #1801
Originally Posted by Josh Cyrul View Post
Wow... You guys are killing me.....
Changing the spacers inside/outside does not change leverage... The shock position is the shock position on the suspension arm (point of instance). It will change the shock angle to the tower....
Shims at the bulkhead w/narrow hex - Slightly longer camber link, slightly increased shock angle and outer hinge pin position closer to center line/contact patch of the tire - Usually generates less contact patch/tire scrub which allows the rear tires to work easier and generate more grip. The car will be smoother, more rear traction (especially in the center of the corner) and the rear tires should overheat less in high temp or high load conditions.
Less shims at the bulkhead w/wide hex or shims - Of course, opposite as above. Makes the car more aggressive and loads the tire contact patch harder which can make the car over rotate in the center of the corner.
There's always a balance to this to generate steering vs rear grip. In 1/8 gas racing it can make a huge difference to the rear tire wear. I personally always try to run as narrow rear hexes as possible and then try to make the car steer. If it won't steer, wider rear hexes are a last resort.
John,
Any reply or feedback on that? LOL
Whats up Josh. You need start practicing with Lipo 12 scale at MSI before Vegas. I'll run some Mod with you.
Jeremy Otis is offline   Reply With Quote
Old 08-09-2009, 09:37 AM   #1802
Send a message via AIM to John St.Amant Send a message via MSN to John St.Amant Send a message via Yahoo to John St.Amant
Originally Posted by Jeremy Otis View Post
John,
E Alo' Le Ulo' !
Pro-Line Racing , Boca Bearings , Competition Heat.
Team Durango DEX210, DEX410V3, DESC410R, DNX408
Futaba FAAST 2.4 4PkS, LRP, Tekin, Xcellorin
John St.Amant is offline   Reply With Quote
Old 08-09-2009, 11:47 AM   #1803
Hey guys, I had a request to make up some aluminum rear hubs for the Photon. Feedback has been very good. I have a few sets still available. PM me for more info if interested. You can check them out @ http://home.earthlink.net/~cbradshaw25/id40.html
teamtamale is offline   Reply With Quote
Old 08-09-2009, 12:10 PM   #1804
RC MARKET's Avatar
$50 ?
RC MARKET is offline   Reply With Quote
Old 08-09-2009, 01:03 PM   #1805
Vicko's Avatar
Trader Rating: 14 (100%+)
hey did anyone posted the lb rating for the Top springs yets.
I use some Hara springs of the same G or lighter but it still feels stiffer then
the top springs of the same rating or higher.
the Hara slivers are 13.9lb/250g but feels stiffer then the top 306g that came with the kit??
Vicko is offline   Reply With Quote
Old 08-09-2009, 01:17 PM   #1806
I have a friend that wants the link to that presentation for the Photon. I can not find it . Does anyone have the link to it ? Please and thank you
Old 08-09-2009, 02:17 PM   #1807
Luke Hobson's Avatar
Send a message via MSN to Luke Hobson
the presentation was still on the TOP USA page last week.
As for springs, I've never liked the feel of hara springs. Generally I stick to tamiya or hpi springs.
Off hand I think the rated lbs of the 306 is 16.9.... Same as hpi but due to material it runs a little bit softer.
So far I've not once been far off the hpi equivalents of the kit springs.
Btw the rated lbs of the springs is in the manual
Hth
Luke
Luke Hobson
Awesomatix - Xenon - Godzilla Paint - Moorespeed - ToniSport - MBmodels
http://luke-hobson.blogspot.com/
Luke Hobson is offline   Reply With Quote
Old 08-09-2009, 03:50 PM   #1808
THeGame's Avatar
Send a message via AIM to THeGame
Here you go..
PS-TR15550 Shock Spring (14 x 1.5 x 5.50) 393gf/mm , 22.0lb/in
PS-TR15575 Shock Spring (14 x 1.5 x 5.75) 367gf/mm , 20.5lb/in
PS-TR15600 Shock Spring (14 x 1.5 x 6.00) 344gf/mm , 19.2lb/in
PS-TR15625 Shock Spring (14 x 1.5 x 6.25) 324gf/mm , 18.1lb/in
PS-TR15650 Shock Spring (14 x 1.5 x 6.50) 306gf/mm , 17.1lb/in
PS-TR15675 Shock Spring (14 x 1.5 x 6.75) 289gf/mm , 16.2lb/in
PS-TF17625 Shock Spring (13 x 1.7 x 6.25) 626gf/mm , 35.0lb/in
PS-TF17650 Shock Spring (13 x 1.7 x 6.50) 591gf/mm , 33.1lb/in
PS-TF17675 Shock Spring (13 x 1.7 x 6.75) 560gf/mm , 31.3lb/in
PS-TF17700 Shock Spring (13 x 1.7 x 7.00) 532gf/mm , 29.8lb/in
PS-TF17725 Shock Spring (13 x 1.7 x 7.25) 507gf/mm , 28.3lb/in
PS-TF14575 Shock Spring (13 x 1.4 x 5.75) 347gf/mm , 19.4lb/in
PS-TF14600 Shock Spring (13 x 1.4 x 6.00) 325gf/mm , 18.2lb/in
PS-TF14625 Shock Spring (13 x 1.4 x 6.25) 306gf/mm , 17.1lb/in
PS-TF14650 Shock Spring (13 x 1.4 x 6.50) 294gf/mm , 16.2lb/in
PS-TF14675 Shock Spring (13 x 1.4 x 6.75) 274gf/mm , 15.3lb/in
Team Gravity Rc - G's R/C Raceway and Hobbies - Waldorf RC - TheTrack
THeGame is offline   Reply With Quote
Old 08-09-2009, 04:55 PM   #1809
PitNamedGordie's Avatar
Send a message via AIM to PitNamedGordie Send a message via Yahoo to PitNamedGordie
I bought a set. Goop had them made and brought some to The Track. They are very nice!
☆ The Track @ Harbor Hobbies ☆ www.harbor-hobby.net ☆
PitNamedGordie is offline   Reply With Quote
Old 08-09-2009, 04:58 PM   #1810
THeGame's Avatar
Is there a problem with the stock hubs ?
Old 08-09-2009, 05:10 PM   #1811
There's no problem with the durability of the Photon. Actually it's pretty bullet proof. I stripped a rear hub after I clipped a board going into the sweeper and cartwheeled into a cinder block wall. The next weekend Goop showed me these...so I bought a pair.
Old 08-09-2009, 05:31 PM   #1812
PS-TF14675 Shock Spring (13 x 1.4 x 6.75) 274gf/mm , 15.3lb/in[/QUOTE]
TY...
Old 08-10-2009, 01:51 AM   #1813
beaim's Avatar
Trader Rating: 8 (90%+)
Send a message via MSN to beaim
hey guys,
can someone teach me how to fit in smc c max li-po using banana plug.
if got pic more nice.thanks in advance.
beaim is offline   Reply With Quote
Old 08-10-2009, 04:39 AM   #1814
I'm not ire you cab fit that lipo in.
I run the GM lipo and it has the bannana plugs lowered and still only just fits.
You may have to bend a battery cell bar. Then solder a bannana tube on to that.
I hope that makes some sense for you.
Luke Hobson
Old 08-10-2009, 04:47 AM   #1815
CraigM's Avatar
Trader Rating: 34 (100%+)
Originally Posted by beaim View Post
hey guys,
4700s? you can either solder up an L-shaped plug (clearance might still be an issue) or space the weight tray out a few mm from the mounts. The center part of the lipo tray under the top deck has slots so you can slide it out to take the plug outside the line of the top deck
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
SEO by vBSEO 3.5.0
