Old 07-22-2009, 01:34 PM   #1561
LOW ET's Avatar
Trader Rating: 96 (100%+)
no word on the foam kits???
LOW ET is offline   Reply With Quote
Old 07-22-2009, 02:55 PM   #1562
CraigM's Avatar
Trader Rating: 34 (100%+)
Originally Posted by Luke Hobson View Post
Congratulations?
You may want to check you head fits out the door when u go to leave the house.....
Ducks and runs for cover lol!
It's tight but I think there is just enough clearance... I might break out the dremel just in case
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 07-22-2009, 04:34 PM   #1563
Send a message via AIM to goop
hey craig i do agree you are running antidive after looking at the setup sheet for a while i realized that the mounts go from H-L i thought for some reason it went the other way around L-H thats why i was saying you were running kickup.my bad.
Hurricane Motorsports
Team Trinity
TOP Racing - Gravity Rc - Contact tires - KO Propo - Competition Electronics
goop is offline   Reply With Quote
Old 07-22-2009, 08:31 PM   #1564
L.Fairtrace's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to L.Fairtrace
Pinion access
Ok heres how I have been getting my pinion on and off. I didn't have the patience for the belt and stuff.
It only works with a long wrench such as the top wrenches. And be careful with the tip but I have been changing my pinions like this since day 1 with the car and havent had a problem yet.
T.O.P. Racing "Photon" 1/10 EP Touring Car-1.jpg   T.O.P. Racing "Photon" 1/10 EP Touring Car-2.jpg   T.O.P. Racing "Photon" 1/10 EP Touring Car-3.jpg
Awesomatix USA - EaMotorsports - RocheUSA - MonTech - Sanwa - BSR Racing Tires - TQ Wire - Solaris Racing Tires - Side Piece Racing
180 and 360 Raceway. Best on the East Coast. Take your pick
L.Fairtrace is offline   Reply With Quote
Old 07-22-2009, 08:54 PM   #1565
Thirtybird's Avatar
Thanks for the tips folks, they made a difference! Larry, I tried that angle too, my wrench is just too short I'm going to just have to get used to using the bottom hole and taking the rear screws out of the upper deck to slide any pinion larger than 42 past it.
After racing the Photon for the first time tonight, I can absolutely say the car is already turning better times than my previous car and is very easy to drive.
I have to bring up the spur adjustment slot again - it has already cost me two spurs. First one was my lack of experience with how it adjusts and not tightening it enough... The second one - I got punted in the main tonight on lap one (a 99% chance of occurance in VTA), and when it was righted, I heard that chewy spur gear sound One side got knocked loose - the other side was still very tight. MY resolve is set to find thin little lock washers - I can't afford to lose $7 spurs this regularly...</RANT>
Still looking for tips on quick & easy spur gear changes
Racing a Kawada SV-10 in 2010
http://omgitsakawada.blogspot.com/
The VTA Photon! (Inactive - back to the Kawada!)
http://vtaphoton.blogspot.com/
Thirtybird is offline   Reply With Quote
Old 07-22-2009, 09:39 PM   #1566
Send a message via AIM to John St.Amant Send a message via MSN to John St.Amant Send a message via Yahoo to John St.Amant
Your car looked pretty good Joe. After I gropped that bad boy and you said something about those screws but I didn't look at it close enough. Hope to get mine from Marc @ MSI asap!
The 416 was great tonight but I still had too much gear on it.
Pro-Line Racing , Boca Bearings , Competition Heat.
Team Durango DEX210, DEX410V3, DESC410R, DNX408
Futaba FAAST 2.4 4PkS, LRP, Tekin, Xcellorin
John St.Amant is offline   Reply With Quote
Old 07-22-2009, 10:39 PM   #1567
ab1105's Avatar
Trader Rating: 20 (100%+)
Check our exclusive video with TOP's Josh Cyrul at R/C Evil Empire!
http://rcevilempire.com/2009/07/rcee...racing-photon/
Josh took the time to explain his background, the photon design, and racing. Thanks to Josh for his time.
ab1105 is offline   Reply With Quote
Old 07-22-2009, 10:51 PM   #1568
RC MARKET's Avatar
around end of this month
RC MARKET is offline   Reply With Quote
Old 07-22-2009, 11:01 PM   #1569
August....
Old 07-23-2009, 12:21 AM   #1570
razzor's Avatar
looking around 1st to 2nd week of August.
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Old 07-23-2009, 01:48 AM   #1571
Default undesteer
hello,
I have test the car and I have a little too much understeer on and off throthle in the midle of the corner, what can I do?
I have put harder springs front and rear and it works a little bit better, shall I take out the front swaybar?
Thank you
RC Racing addict
Roedor is offline   Reply With Quote
Old 07-23-2009, 04:04 AM   #1572
Rod M's Avatar
we had great results over the weekend running on carpet at the ACT state titles,
TOPRACING.NET.AU Australian Importer of:
T.O.P. Tokyo Hobbies Optional Parts,
Team Trinity , BL Motors and Tyre compound
Team Tekin , ESC's, motors,
Elangears, Chargers,
Rod M is offline   Reply With Quote
Old 07-23-2009, 04:58 AM   #1573
CraigM's Avatar
Originally Posted by Roedor View Post
hello,
Thank you
Flip the front arms and use the outside hole on the arm. If you are in the rear ackerman position, go up to the centre
Old 07-23-2009, 05:08 AM   #1574
CraigM's Avatar
Well done guys, a Photonic domination. You left someone out though
4) Craig McPhee (couldn't get a leave pass from the missus)
Old 07-23-2009, 07:30 AM   #1575
hello,
Thank you
Sweep the front arms back.... That will change to Ackermen too.
