Old 07-20-2009, 09:16 AM   #1516
Send a message via AIM to John St.Amant Send a message via MSN to John St.Amant Send a message via Yahoo to John St.Amant
Originally Posted by Thirtybird View Post
Craig, I know I'm not the guy you were asking for help from, but looking at your setup sheet raises one question, and I may have a point of help for you...
The question I have is : Your setup sheet indicates that the front of your front arm is mounted lower than the rear. I've never seen a car setup in that fashion, and it seems like it could cause you problems. Wouldn't that reduce caster, and in turn cause steering problems?
The point I have is : Your steering ackerman is set long/#11 which based on the chart Josh posted would be
24mm Length - 11mm Insert 4.78 9.13 13.04 16.5 19.48
This is on the high side of the ackerman adjustments for the car. Quoting Josh : "Higher initial ackerman makes the car easier to drive, and more balanced through the run. Sometimes though, if you use too much ackerman you will just have slow lap times and a lazy/understeering car."
perhaps shortening the bellcrank and/or switching to a lower numbered insert would help you find more steering.
Yup/// and decrease the front droop...
Pro-Line Racing , Boca Bearings , Competition Heat.
Team Durango DEX210, DEX410V3, DESC410R, DNX408
Futaba FAAST 2.4 4PkS, LRP, Tekin, Xcellorin
John St.Amant is offline   Reply With Quote
Old 07-20-2009, 12:49 PM   #1517
tpczx6's Avatar
Anyone looking for a kit I seen two in stock at Speedworld on Saturday give him a call on Tuesday and I sure he will ship them.
http://www.speedworldraceway.com/
RcAmerica--Xray---Hudy----KO PROPO USA---ORCA---GRAVITY RC
Motiv------Apexrc----- AVID
SWEEP Racing USA
Mike's Hobbyshop in Dallas (RIP)
Nor-Cal Hobbies [The Race Place]
tpczx6 is offline   Reply With Quote
Old 07-20-2009, 01:48 PM   #1518
wayne breault's Avatar
Default Servo mount
I'm trying to mount my servo, it's a Futaba S9550, I'm using the forward servo mount position. I put a 2mm shim. The servo tie rod looks stiarght. My problem is the bell crank is hitting the top servo tab and the ball cup is hitting the edge of the servo. Should I cut off the servo tab and drimel the servo case a little?
Now the next problem is I mounted the sway bars a, 1.4mm in the rear and a 1.6mm in the front when I put the collers on and I push up on the rear or front arms a little bit the collers are rubbing the dog bone. Should I put the coller on the end of the sway bar and unscrew the sway bar adjuster higher?
Would appraciate any help.
Wayne
wayne breault is offline   Reply With Quote
Old 07-20-2009, 02:23 PM   #1519
PitNamedGordie's Avatar
Send a message via AIM to PitNamedGordie Send a message via Yahoo to PitNamedGordie
Some of the guys at my track have been shimming out 6mm and you won't have to dremel....or you can mount in the rear position. I was looking for a servo mount from someone that I can use so I won't have to shim so much. But with my small electronics I may just go back to mounting in the rear position.
☆ The Track @ Harbor Hobbies ☆ www.harbor-hobby.net ☆
PitNamedGordie is offline   Reply With Quote
Old 07-20-2009, 02:26 PM   #1520
bukil's Avatar
Trader Rating: 39 (100%+)
Wayne
Ack Wayno I thought you were going to get the 009. Heard good things about this car. I can't wait to see it this Sunday. Go hellhounds? Now that you actually own one, I wonder if Lee is getting one too .
Are you going to keep your old Xray?
~Mark
bukil is offline   Reply With Quote
Old 07-20-2009, 02:27 PM   #1521
Thirtybird's Avatar
Wayne
The best recommendation I've heard on the servo is to use a live beaver to trim off the tab and part of the case of the servo to prevent that....
RE: your sway bar, it sounds like you have the short ball cup (10.5) attatched to the suspension arm instead of the long ball cup (14.5) or you are missing the 2.5mm spacer under the ball that joins the two. A pic would definately help.
Racing a Kawada SV-10 in 2010
http://omgitsakawada.blogspot.com/
The VTA Photon! (Inactive - back to the Kawada!)
http://vtaphoton.blogspot.com/
Thirtybird is offline   Reply With Quote
Old 07-20-2009, 02:30 PM   #1522
AdamD's Avatar
Originally Posted by CraigM View Post
I gave all of these a go today, but the best result was from going up in sway bars to 1.4 front and rear. The car was quite good at the club meet today (I won the main) but I'm still after more steering, particularly exit steering on power, but I also find I cant get on power as early as some mid corner in tight turns. I've attached my setup if it's any help
I was incorrect yesterday with my setup advice. With the reduced caster in the front you will enter a corner better ,but you will lose some mid-corner and exit steering. Less up travel , not more is also correct. Sorry for the mistake.
AJ DiPirro
T.O.P. Racing U.S.A. / Serpent America / EA Motorsports / Team Epic / Trinity
P3 Graphics / RC3 Grafix / Adco Paving Inc / Team Butter
AdamD is offline   Reply With Quote
Old 07-20-2009, 05:41 PM   #1523
CraigM's Avatar
Trader Rating: 34 (100%+)
0.5mm of antidive was pretty standard on my last car, and when I first put it on this car I liked it a lot. The reduction in castor is fairly slight, so you can normally get the steering back pretty easily
As for the ackerman, maybe I'm wrong but I thought the forward position with insert 11 would be lower initial ackerman than any of the middle values, so I'll have more steering not less. That's how the chart looks and how it feels on the track anyway
yep I figured that was what you meant. Its funny, on the tamiya 6mm of droop on the droop blocks was basically zero up travel, on the TOP it's 2-3mm. I guess the thicker deck has something to do with it.
All this experimenting is great fun, I don't know about anyone else but I've found this car so responsive to setup changes, and it just seems fast regardless of what you do
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 07-20-2009, 05:46 PM   #1524
Send a message via AIM to goop
[QUOTE=CraigM;6092514]0.5mm of antidive was pretty standard on my last car, and when I first put it on this car I liked it a lot. The reduction in castor is fairly slight, so you can normally get the steering back pretty easily
actually in his setup he is running kickup which adds caster
Hurricane Motorsports
Team Trinity
TOP Racing - Gravity Rc - Contact tires - KO Propo - Competition Electronics
goop is offline   Reply With Quote
Old 07-20-2009, 06:43 PM   #1525
I think the # is just a vernier , depending on where you measure it and the shape of the part. Either way , The front end should droop a little bit from ride height,
Old 07-20-2009, 08:35 PM   #1526
CraigM's Avatar
nope it's antidive. FF is mid-down FR is mid up, so the hinge pins are lower at the front
Old 07-20-2009, 08:46 PM   #1527
[QUOTE=CraigM;6093468]nope it's antidive. FF is mid-down FR is mid up, so the hinge pins are lower at the front [/QUOTE
my bad i was reading it wrong it took me 3 times looking at it to figure it out. its been a long day
Team Trinity
Old 07-20-2009, 09:06 PM   #1528
CraigM's Avatar
look again its ff mid up and fr is mid down its on page 100
Maybe we are reading the sheet differently. To me it would logically go from highest RC setting to lowest, left to right:
high up, high down, mid up (FR), mid down (FF), low up, low down
These would be hinge pin positions, not the position of the mark on the eccentric inserts, so maybe that's the confusion. Anyway, I'm definitely running antidive
Old 07-20-2009, 09:42 PM   #1529
Thirtybird's Avatar
I read the part about "lower initial ackerman (closer # values) " and I thought the lowest initial ackerman setting was rear position (21) with a 9mm insert. That would put forward(24) with an 11mm as the third highest. One of us is misinterpretting what was said and I would love to get clarification
as for the anti-dive - I've always had cars with flat front suspension or kick-up...
Old 07-20-2009, 10:00 PM   #1530
CraigM's Avatar
I believe in order from most ackerman to least it goes
rear 12
rear 11
rear 10
rear 9
middle 12
middle 11
middle 10
middle 9
front 12
front 11
front 10
front 9
that's what I got from Josh's comment:
Those ackerman #'s are the difference in relation from inside/outside wheel travel from 0 degrees. Example - Going back to the chart 21mm crank (shortest setting) with a 12mm insert gives you an inside wheel angle of 25 degrees with the outside turning 17.65 = 7.35 degrees of ackerman at 25 degrees of inside wheel travel.
