Soldering is not easy for me.
#31
This is the problem with people raised on cereal. Their education stops at the quotes on the back of the box. Just wait until they discover the bus tickets.
But there may be hope still. Let's see.
Here you go, malicious weather phenomenon, maybe you can learn something, (random find on internet after lengthy 2 second search, never heard of these guys, try to find the solder with 2% silver):
http://www.bhavanimetals.com/Solder_...ore_Solder.htm
#32
A substance applied to a surface to be joined by welding, soldering, or brazing to facilitate the flowing of solder and prevent formation of oxides.
It has nothing whatsover to do with changing the melting point of the solder. It is possible that someone might think it affects the melting point because the solder seems to melt easier when flux is used, but what is really happening is that the flux is cleaning the contact surfaces so the heat flows from the iron to the parts being soldered so much easier. That's why I use flux on every joint.
#33
The problem with using pure silver solder is that it has to be heated to the point that any Copper or Tin will melt long before you get it Soldered.
I use pure Silver Solder for Stainless Steel Driveshafts on my boats and you have to get the SS almost red hot (with flux) to get it to flow.
$.02
Just make sure you get Silver Solder for Electronics and use water based flux.
$.02
#34
I use flux as well. Flux also acts as a cleaner, and you can get all that black gunk off the solder point. Apply some, then heat it. You can see the residue flow towards the edges, cool off, and wipe with a towel. you will then get a really clean surface to work on. Same thing goes when you are joining things too. Soldering works without flux, but better with it.
For the iron, I use a Goot PX-201
http://www.howardelectronics.com/goot/px201.html
Small and powerful, it can get to max temp in less than 30sec. Recommended
#35
Maybe anyone can edit Wikipedia (that doesn't make it wrong), but the relevant definition of flux from the American Heritage Dictionary is:
Wikipedia is not bad, but it's far from a good scientific source of information. Likewise the dictionary. The problem with these is they are not written by specialists so you have to be careful when using it, and as far as I am concerned the information therein can not constitute hard evidence. They can be good starting points but take it easy. Some people know more than others.
Good luck.
#36
Suspended
#38
My soldering joints still suck haha.
I have practiced and practiced.
I just can't do it, they end up messy, when i apply solder to join the wires, i pull the iron away as soon as i melt the solder on to the wires but it drags the solder along with it, and creates sort of a wave looking joint, it looks craphouse.
I have a hot 60W iron and good silver based solder, Much More AG-4
What are all the tips on how to get a perfect solder joint?
#39
clean the tip
After looking at countless neat wiring jobs on a thread, I tried some rewiring myself. But it didn't go well. I watched youtube videos on how to solder Deans connectors and tried it but my solder would not melt easily. The silicon cover on the wire melted before the solder liquified. Sometimes the heat shrink tube shrunk before it was in place because of the high temp on the wire and sometimes the heat shrink was too small to fit over the soldered spot because I made it too big. It was a mess.
I shortened the servo to receiver wires, esc to receiver wires, and got rid of the esc - motor plug. I replaced the Tamiya plugs with Deans. I completed the job but my car still doesn't look like the ones I have seen on the other thread.
What could I be doing wrong? Do I just need more practice?
Also the hottest spot on my soldering iron is not at the very tip. It is at the point where it starts to taper into the cone rather than at the tip of the cone. Should I get another soldering iron? Are there better ones? It is cheap and old but I have not used it much.
But I had fun. Before I realized I had spent four hours working on the car.
You have to keep the tip clean and tinned. I like to use the copper sponge type cleaner. Its works well and the temp doesn't drop on the iron. And get a good wire snip so you can cut and trim the wires good and don't forget shrink tubing.
#40
This thread helped me tremendously. Thank you all.
I decided for the servo wires it is a lot easier to just use shrink wrap to shorten it (zig-zag inside) without splicing. And tape it on the chassis using double sided tape or wedge it between the receiver and the ESC.
Keeping the tip clean is very important and putting solder on both sides is important also..
I tried out flux and it makes the job easier.
Thank you again!
Thank you again!
#41
Another note on splicing: Whenever I need to splice wires, I flare out the ends so they look like a cone. this keeps the strands a fair distance apart. I use the third hand to hold both, press them together, then remove one side and give it a good twist.
#43
Not sure on the much more solder, but I used to use deans solder before they discontinued it. Now I use the Novak racing one and it's very good and melts nice while creating nice solid joints. I use a hakko soldering station with the novak solder and have to say it's been pretty good for me.
#44
If the iron is pulling the solder away from the joint that is because the solder was not flowing onto the materials to be joined because of the presence of oxides. Flux removes the oxides. Flux in the solder won't do as good a job as flux applied separately beforehand.
#45
Solder is solder. Brand names don't make any difference. just make sure you get the stuff for electronics instead of the stuff for plumbing. You can also get silver content solder and that can be picked up for fairly cheap.
