Orion V2
#301
Originally posted by Mr. MR4
has anyone tried a modified (5mm web) vs touring (4mm web) with an 8turn (or something low like that). What did they think was better
dontfeelcold,
I have tried both the modified and the touring(Spashett version)on 1/10 touring. The touring version has definitely more power & is more aggressive. It really depends what class you are racing in. The Modified versions are mostly for off road.
dontfeelcold,
#302
i got a few questions i am hoping you guys can answer
1.what motor do you think is best for touring on carpet
2.what turn would be a good starting point
3.do you guys know when the mark rehnard motor will be relleased?
#303
Brakes..
I have a question .. I have been running 2 wheel Mod at or local track with a V2 11x2. And I dont know if its my motor or speedo or setup maybe. But I can not brake when the cars in the air.. At the end of the stright my brakes are ok I can get the car to spin-out.. But when the rear wheel are in the air I dont think the brake work aswell. I have a hard time bring the nose down after a Jump.
I'm running the LRP Comp 2 speedo and I'm running the stock Diode, going to try and put one or two more diodes on this weekend see if it helps.. Does Anyone have any thoguhts ???
#306
Moderator
I have acquired a peak surikarn edition V2 motor. I have one question about the motor:
How do I remove the bearing in the endbell for maintainance? I like to regularly remove the rear endbell bearing for maintainance and replacement, but I found the brush tubes arein the way!
Any idea's?
Any idea's?
#309
4mm or 5mm web?
hi guys, would you know what's the web of the HARA 8x2 motor? thanks.
#310
jygs the hara v2 comes with the 4mm web.
#311
hi people, i was just wondering if the small O-ring in the motors goes closest to the bearing, or under the shims. also does this motor run a phenolic washer?? cheers
#312
The small o-rings that go on the armature go on top of the motor shims.
This motor does not require a phenolic washer.
#313
Got this from the Orion Forums.
Blue - 5mm armature web, enduro brushes, off-road winds
Black - 4mm armature web, enduro brushes, touring winds
Green - 4 mm armature web, sprint brushes, off-road winds
Purple - 4mm armature web, Sprint brushes, touring winds
Sean
Sean
#314
hey people, when i go full throttle with my V2 motor the motor stutters really badly and then takes off. the comm has just been freshly cut and the motor is in perfect running condition. the ESC is a novak GTX.
#315
Trader Rating: 22 (100%+)
have you run it on a motor runner for a couple of minutes?
