Rollout For 12th Scale with Tamiya TZ Super Stock
Depends on the track... I geared mine 39mm rollout. It was on a short technical track.
The internal gear ratio is 1:1 okay? Because there is no gear system and what not. You can still use gear chart. Choose the pan car option or just manually enter 1.0 in the internal gear ratio spot
Everything else is the same?!
No idea... sorry... visit www.teamcrc.com they've got tires and if you cant see it there email them and ask
No, they're not common. Most (every?) other 1/12th scale cars use a through-axle design that uses three bolts to secure the wheel to the hub. The Kawada is a proprietary design and the wheels are their own. You have to find a source for Kawada wheels. I'm not saying it's bad, but you're limited on options.
