HPI Pro 3
#92
HPI is coming out with there 3piece integrate motor mount&shaft mount hop-up. part #60062. Unfortunately it won't be available here in the US... only in Japan. Along with the other cool stuff...
see: http://www.hpiracing.co.jp/nobrands/index.html
Found someone in Japan that is getting me all the Blue stuff for the Pro3.... with all the things going on... maybe awhile before I get it plus he's in the military stationed overthere. Let's have Peace before I get my parts and pieces... he he he..
When I do get my blue parts... I'll try to get some pics and post...
Blue is Better....
Blue is Better....
#93
spring for pro 3
which spring do ur pro 3 using? i want fast (but dont push) and stable in corner ! thx!
#94
Stanley: I use HPI grey spring (#6852). You may also use SpeedMind yellow spring as an alternative.
#95
To Fai
Fai ! grey spring........is that hard or soft? i m using HPI blue now...... front and rear also use grey? how is that feeling? fast?stable? and how about speedmind yellow? hard or?
#96
Stanley: HPI grey is the hardest. Your blue is #6757 or #6851??
SpeedMind Yellow is also the hardest...
#98
The "normal" schedules have been interrupted as a result of the recent terrorist actions in NYC. Passenger air travel is back on schedule for most airlines/locations, and I suspect that freight is also returning to predictable schedules. Actual shipping time from supplier to you may vary depending on locations and how many "touches" a package receives in the supplier's shipping process.
#100
Good news everyone.. Cross Racing is back in the USA.
Schumacher will be the US distributor.
Cross has some nice stuff for the PRO3.
see: www.http://www.rc-cross.com/page/frame.html
#102
I've had a Pro3 for about a month now. I like the car alot, and I've had pretty good luck with it, only breaking one A-arm. Spare parts aren't always available at my LHS though, and I'd like to lay in a supply of spares so that I can minimize downtime. Any suggestions on what spares I should focus on?
Thanks,
Thanks,
#103
Lots of arms, possibly the hubs, c-block, steering knuckle, shock towers. hinge pins in case they fall out and you can't find them.
everything else should hold out just fine.
Did you contact HPI about getting the revised set of arms? They were giving away 4 pairs of front and rears long while ago along with the revised diffs. Don't know if that offer is still good... you may want to contact there customer service and find out.
good luck with your Pro3.
#105
kansasracer: I don't have the "Cross" spur gear holder but I have a chance to hold it on my hand... it's quite heavy...
