As a person who only has a year under my belt racing in TC, one of the most important things I have learned is free up the drive train in any car. I have one of the first TC5's what I did was installed metal shielded aftermarket bearings, I got a set of the world's cvd from Ti racing, which I do not think you can get anything from them lately as most people have been taken advantage of. I also use the exotek layshaft bearing supports, also I removed every other tooth from the belts.
One of the best setups I have found for a short asphalt track is Ryan Cavalieri's 2007 Reedy Race setup, I made two small changes to the car, I changed the fronts springs to blue, and raised the rear outer camber link up 1mm.
Team Magic E4RS
Associated TC5
