Old 11-21-2003, 11:57 PM   #16
Scrad's Avatar
Trader Rating: 15 (100%+)
I use a supply that puts out 14 and it works just fine. I break in motors and run my lathe.
Scrad is offline   Reply With Quote
Old 11-23-2003, 02:29 AM   #17
dtm's Avatar
Send a message via ICQ to dtm
Default Re: Recommended 20amp powersupply
Originally posted by rc-zombies
Looking to get one soon.
I was reading the specs on the charger is says 20amp power supply is recommended...
can I get away using a 14amp power supply? I have Integy's SHE power supply.
lmk thanks in advance.
It will work fine...unless you plan on charging your batteries at 15A......or run 2 chargers at 8A...
Anyway, your supply will safely "trip" the first time it comes across a motor draw of more than 14A, at that point you can decide whether it is worth handing over the extra dough for a larger supply.
dtm is offline   Reply With Quote
Old 11-23-2003, 02:31 AM   #18
cHckbOY5's Avatar
Send a message via AIM to cHckbOY5
is this thing worth the money?
cHckbOY5 is offline   Reply With Quote
Old 11-23-2003, 03:23 AM   #19
JDM_DOHC_SiR's Avatar
Trader Rating: 30 (100%+)
Every dime
Best charger I have bought
Ȼ4.5 Centro+α ◊ ȻT4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
DȻ4-LE ◊ 12R5.2+RDS
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
charging hillbillyrcer Micro and Mini Scales 9 01-16-2008 02:58 AM
Charging ? NitroMaxx3.3 Nitro On-Road 7 06-18-2007 01:57 PM
need help with charging please mikezilla Australian Racing 9 04-11-2006 04:17 AM
Charging. How to? Mossie Australian Racing 14 01-27-2004 01:32 PM
SEO by vBSEO 3.5.0
